The first video is not available. You might provide a new link.
Second:
Code:wget "http://pdvod.new.livestream.com/events/000000000028aff1/eddb6a91-fd21-470a-94bc-df2a550ea7f6_1756.mp4?start=24&end=6036&__gda__=1389490148_db18777726dfa26a589a81ea96b14991" -O 1756.mp4
Code:General Complete name : 1756.mp4 Format : MPEG-4 Format profile : Base Media Codec ID : isom File size : 763 MiB Duration : 1h 40mn Overall bit rate mode : Variable Overall bit rate : 1 066 Kbps Encoded date : UTC 2014-01-08 19:15:23 Tagged date : UTC 2014-01-08 19:15:23 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L4.1 Format settings, CABAC : Yes Format settings, ReFrames : 1 frame Format settings, GOP : M=1, N=60 Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 1h 40mn Bit rate mode : Variable Bit rate : 802 Kbps Width : 848 pixels Height : 480 pixels Display aspect ratio : 16:9 Frame rate mode : Variable Frame rate : 30.000 fps Minimum frame rate : 29.412 fps Maximum frame rate : 30.303 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.066 Stream size : 574 MiB (75%) Title : Mp4 Video Language : English Encoded date : UTC 2014-01-08 19:15:23 Tagged date : UTC 2014-01-08 19:15:23 Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 40 Duration : 1h 40mn Bit rate mode : Variable Bit rate : 256 Kbps Channel count : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Compression mode : Lossy Stream size : 183 MiB (24%) Title : p4 Audio Language : English Encoded date : UTC 2014-01-08 19:15:23 Tagged date : UTC 2014-01-08 19:15:23
Results 1,921 to 1,950 of 4610
Thanks Endoro!
You are great!
You mean I should use wget app? OK'! I download it right now!
But that first link..., that webinar what I want to record is streaming live so a link is valid only 50min!
I need to know how can I record it when it's going live
I was using DownloadHelper as a plugin for FX, SMRecorder, a TubeCatcher and nothing!
I get something looking like television picture with bad synchronization.
hello guys,
I'm trying to try this link: http://www.n-tvnow.de/deluxe-alles-was-spass-macht/thema-ua-mr-goldfinger.php?containe...yer=1&season=0
I have set up RTMPDumpHelper + RTMPDump properly but still no reaction.
any help for me?
thanks -
Hey! Do you know how can I download this video ? http://www.mtv.com/videos/misc/993354/ep-15-sneak-peek.jhtml
Apparently the video is hidden, but even being hidden it must be hosted on the website?
Thank you in advance ♥ -
Hello all, I am having problems downloading this video
-- linked removed--
It requires Hong Kong proxy.
apparently it is a wowza stream that uses RTMPS:// protocol.
I tried setting the port listening to 443 on rtmpdumphelper,
and rtmpsuck / rtmpsrv both give me handshake problems.
Thank you.Last edited by ron007; 22nd Jan 2014 at 12:10.
great work
i found this but can't figure out correct play path
http://token.tvb.com/stream/vod/rtmps/1/3175/000000317479.mp4?feed
http://data.tvb.com/pdes/video_file/000000317479.json
and securetoken "#etd%hv0#wb@1" -
i found those two http links, but not the secure token.
chapun67, please tell us the secrets thanks. I just tried to find m3u8 through ADBlock Plus on firefox but came up empty.
lol nice you are the man....i tried to rename rtmps to rtmpe / http but couldn't continue after that.
New user here. Thank you ahead of time for whomever can help me. Trying to download
http://www.cmt.com/videos/orange-county-choppers-104-the-ardbeg-trike/1718318/full-episode.jhtml
No luck so far. Thanks again -
how do I download a microsoft silverlight streamed video? it's blocked.
that's what I've got:
mms://[ip server]/[user]/132382/12321442121251_000.wmv?ticket=000001982149&id=552121292&crc=834343484Last edited by Bazinga; 15th Jan 2014 at 18:15.
this is mms stream not silverlight try use Replay Media Catcher
for silverlight streams use -> ISM Downloader -
thank you, but replay media catcher didn't work. At least not with its monitoring tool.
I had to install silverlight in order to play the stream. Is it really a mms stream?
GetFLV recognize it, but it is getting a 0 byte file. -
Hi, http://www.youtube.com/watch?v=_BWPbIdFlvs how can I download this video above and why DownloadHelper can't do this? I hadn't any problem with Youtube till that file.
janbar
try
Code:http://ru.savefrom.net/#url=http%3A//www.youtube.com/watch%3Fv%3D_BWPbIdFlvs
it's password protected and I can't give you the password because it's not mine.
all I can say is that every software I've tried keep doing the same. They find the archive, its size and its location but they can't download it due to "Socket Error #10060, connect timeout". -
WOW! Chapun67 Biiiig thnx!
So, can you explain it now why it happens like that? What they ( Youtube.com)did and what a free tool I can use to achieve the same like your link did?
EDIT: Well.... - "Не удалось выполнить запрос. Пожалуйста, повторите попытку." <-- it's look it didn't work?
How to download a rtmp stream from a website
By krb214 in forum Video Streaming DownloadingReplies: 2Last Post: 26th Jul 2011, 19:08 -
Need some advice on how to download certain rtmp streams
By aveceux in forum Video Streaming DownloadingReplies: 3Last Post: 13th Jun 2011, 09:45 -
Free DivX Pro Software Download
By MJA in forum Video ConversionReplies: 11Last Post: 18th Dec 2010, 08:21 -
RTMP Flash file help?
By xiaofan in forum Newbie / General discussionsReplies: 0Last Post: 3rd Jun 2007, 09:16
ass
