In GetFLV to show two lines instead of one.
Code:http://tpr199196sec-vh.akamaihd.net/z/secure/,SPE_-_Central_Europe/69/438/PROLAG00404-...l/manifest.f4m?hdnea=st=1380720588~exp=1380721218~acl=/*~hmac=2c02540620ad6e40e25e78be69c20196ceaf9915ac0f0be2b297d22120d05ace&g=UQUMUVOBXUOT&hdcore=3.0.3The flv to start downloading and then just give an error message. Pictures in the Annex. Please adviceCode:http://tpr199196sec-vh.akamaihd.net/z/secure/,SPE_-_Central_Europe/69/438/PROLAG00404-...IcsdCRIxs3X84m?guid=UQUMUVOBXUOT&hdntl=exp=1380807020~acl=%2f*~data=hdntl~hmac=3c23819c0d497a1b210d0ce3cd7093632cbf564950e4dd54efeb7523104d67d5
				Results 1,591 to 1,620 of 4610
	Thanks for your help CristianoA
 But I'm a newbie with ffmpeg and i'm having some problems. After a nice, warm google session, I achieved this:And I'm having this error:Code:ffmpeg -i https://videos30ios-vh.akamaihd.net/i/1703_11292012_ISO_ATUA_CNJ_2013_AULA_01_Pt_IV_ok...f68378c5085d63 -c copy -absf aac_adtstoasc t.mp4
 Could you help me a little more to get this video?Code:[applehttp @ 0x8dce100] Estimating duration from bitrate, this may be inaccurate Seems stream 0 codec frame rate differs from container frame rate: 59.94 (60000/1001) -> 1000.00 (1000/1) Input #0, applehttp, from 'https://videos30ios-vh.akamaihd.net/i/1703_11292012_ISO_ATUA_CNJ_2013_AULA_01_Pt_IV_ok.mp4/master.m3u8?hdnea=st=1380726356~exp=1380726856~acl=/*~id=4hbeb0ejhqieimfscsmf3hmb33~hmac=e69b9d7bd85ee545be4d9dac046d52a02595c8ccff6de1d027f68378c5085d63': Duration: 00:30:30.00, start: 10.108311, bitrate: N/A Stream #0.0: Video: h264 (Main), yuv420p, 400x300 [PAR 1:1 DAR 4:3], 1k tbr, 90k tbn, 59.94 tbc Metadata: variant_bitrate : 430000 Stream #0.1: Audio: aac, 44100 Hz, stereo, s16 Metadata: variant_bitrate : 430000 Unrecognized option 'c' Failed to set value 'copy' for option 'c'
	this is trickier than i thought. i tried to detect the stream with rtmpdumphelper but it doesnt want to show up. is there anyway i can just paste that code from helper manually into rtmpdump and let it use port 80?
 EDIT: I got it to work in another browser! Thanks so much for all your help!!! *__*Last edited by robza171; 2nd Oct 2013 at 14:50.
	CristianoA, thanks so much! Finally I got it. The problems that I had was because my version of ffmpeg was outdated and I'm using Linux, so the version that you indicated doesn't work. I had a lot of problems to install the dependecies, but now the command that you suggested is working fine.
 sysanin, the link above shows "File is deleted.", could you re-upload?
	@CristianoA
 Could you please give some detail on how to install and use ffmpeg in windows, I've never used this tool and also not very familiar with command line.
	I get this when using your method
 Code:C:\>ffmpeg\ffmpeg.exe -i "http://vodnickindiacom-vh.akamaihd.net/i/motu_patlu/se ason1/episode12/web/mehnat_ki_kamayee_ep_12_part_1-2000000.mp4/master.m3u8?hdnea =st=1380827972~exp=1380828062~acl=/*~hmac=9c1a23bf7a2fec16ab51ea210397b2407f5825 eef8619111a98caf89bca2f53a" -c copy out.ts ffmpeg version N-56704-g3e0c78b Copyright (c) 2000-2013 the FFmpeg developers built on Sep 27 2013 18:01:57 with gcc 4.8.1 (GCC) configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-av isynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enab le-iconv --enable-libass --enable-libbluray --enable-libcaca --enable-libfreetyp e --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --ena ble-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-l ibopus --enable-librtmp --enable-libschroedinger --enable-libsoxr --enable-libsp eex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-aa cenc --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavp ack --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib libavutil 52. 46.100 / 52. 46.100 libavcodec 55. 33.101 / 55. 33.101 libavformat 55. 18.104 / 55. 18.104 libavdevice 55. 3.100 / 55. 3.100 libavfilter 3. 87.100 / 3. 87.100 libswscale 2. 5.100 / 2. 5.100 libswresample 0. 17.103 / 0. 17.103 libpostproc 52. 3.100 / 52. 3.100 [http @ 024c8800] HTTP error 403 Forbidden http://vodnickindiacom-vh.akamaihd.net/i/motu_patlu/season1/episode12/web/mehnat _ki_kamayee_ep_12_part_1-2000000.mp4/master.m3u8?hdnea=st=1380827972~exp=1380828 062~acl=/*~hmac=9c1a23bf7a2fec16ab51ea210397b2407f5825eef8619111a98caf89bca2f53a : Input/output error
	Download? Why? Silverlight
 'http://200.177.228.82/Enfase_Enfase_OD/128730/114524_130223_072632_000.wmv?ticket=000001493931&i d=47345272&crc=1494012696' -H 'Accept: */*' -H 'Connection: keep-alive' -H 'Accept-Encoding: gzip,deflate,sdch' -H 'Referer:http://v3.webcasters.com.br/visualizador.aspx?CodTransmissao=128730' -H 'Host: 200.177.228.82' -H 'Accept-Language: pt-BR,pt;q=0.8,en-US;q=0.6,en;q=0.4' -H 'User-Agent: Mozilla/5.0 (Windows NT 6.1) AppleWebKi
	Anyone how to get this as a single MKV, TS, FLV or MP4???
 I get serperate FLV files with VSO Downloader, but these FLV files don't playing.
 Maybe do anyone have a sollution to combine is to a single working video file?
 Thanks!
 Code:http://kalturahd-vh.akamaihd.net/z/content/r71v1/entry/data/279/612/1_x67vh8ql_1_,lqv6b3ik,f1eb11kq,a58webjg,qxzec0zu,_1.mp4.csmil/manifest.f4m?g=YRFCRUESIDVU&hdcore=3.1.0&plugin=aasp-3.1.0.43.124
	Maybe you can help me with the links too  . .
 http://watchabc.go.com/castle/SH559040/VDKA0_yrss1i1f/valkyrie?cid=abc_ss6_csl
 http://watchabc.go.com/castle/SH559040/VDKA0_hmtbbl1q/dreamworld
	Here: http://www.disneychannelgemist.nl/violetta-aflevering-11/
 Thanks for helping me!
	Hello , i have two videos which i can.t downoad them..i tried many video downloaders but nothing , maybe someone can help .Thanks
 http://www.biziday.ro/2013/10/03/ora-de-business-joi-3-octombrie-2013/
 http://www.seenow.ro/movie-ora-de-business-61748
 the first two are the same video but different websites
 http://www.ubs.com/microsites/wm-capabilities/en/tailoredadvice/portfolio-management.h...tott1-Flash-DT
 second
	first video
 http://www40.zippyshare.com/v/48896627/file.html
 http://www40.zippyshare.com/v/22853092/file.html
 http://www40.zippyshare.com/v/45824334/file.html
 http://www40.zippyshare.com/v/67784146/file.html
 http://www40.zippyshare.com/v/29248189/file.html
 second video
 http://www40.zippyshare.com/v/31172795/file.html
  How to download a rtmp stream from a websiteBy krb214 in forum Video Streaming DownloadingReplies: 2Last Post: 26th Jul 2011, 19:08
  Need some advice on how to download certain rtmp streamsBy aveceux in forum Video Streaming DownloadingReplies: 3Last Post: 13th Jun 2011, 09:45
  Free DivX Pro Software DownloadBy MJA in forum Video ConversionReplies: 11Last Post: 18th Dec 2010, 08:21
  RTMP Flash file help?By xiaofan in forum Newbie / General discussionsReplies: 0Last Post: 3rd Jun 2007, 09:16
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
