Results 1,291 to 1,320 of 4610
Hi everyone, can anyone help me to solve how download video from musicplayon? http://en.musicplayon.com/play?v=740578 this video I've try lot of time from using lot of software such like coojah, getflv, etc, and as a newbie, I've totally no idea how to use rtmpexplorer to download the video. So anyone can help me? thks~
TubeDigger can download it
http://www12.zippyshare.com/v/96058974/file.html -
how to download
http://www.youtube.com/watch?v=Gob6Yv_SSAY
i try used ffmpeg but i dont know -
Can anyone help me download this video plz
http://watchabcfamily.go.com/pretty-little-liars/SH5547476/VDKA0_wjf7aq9j/under-the-gun
I used FFmpeg but its not working thanks alot -
how to download
i try used ffmpeg ,, but i dont know to complet -
ffplay version N-52045-g694fa00 Copyright (c) 2003-2013 the FFmpeg developers built on Apr 12 2013 16:54:51 with gcc 4.8.0 (GCC) configuration: --enable-gpl --enable-version3 --disable-w32threads --enable-av isynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enab le-iconv --enable-libass --enable-libbluray --enable-libcaca --enable-libfreetyp e --enable-libgsm --enable-libilbc --enable-libmp3lame --enable-libopencore-amrn b --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-libr tmp --enable-libschroedinger --enable-libsoxr --enable-libspeex --enable-libtheo ra --enable-libtwolame --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-li bvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --ena ble-zlib libavutil 52. 26.100 / 52. 26.100 libavcodec 55. 2.100 / 55. 2.100 libavformat 55. 2.100 / 55. 2.100 libavdevice 55. 0.100 / 55. 0.100 libavfilter 3. 53.101 / 3. 53.101 libswscale 2. 2.100 / 2. 2.100 libswresample 0. 17.102 / 0. 17.102 libpostproc 52. 3.100 / 52. 3.100 Input #0, hls,applehttp, from 'http://www.youtube.com/api/manifest/hls_playlist/ id/1a86fa62ffd24806/itag/96/source/youtube/ratebypass/yes/pfa/1/pbr/yes/hls_chun k_host/www.youtube.com/gir/yes/clen/3248226208/lmt/1347656498690111/maudio/1/cp/ U0hWSVVOVl9KU0NONl9NSFpHOkRsWC1tUVhkWXcx/playlist_type/DVR/pmbypass/yes/fexp/929 117,929121,929906,929907,929127,929129,929131,925720,925722,925718,925714,929917 ,929919,912521,931917,904830,919373,904122,919387,936303,900816,936301,912711,93 5000,921057,929309/sver/3/upn/bHu78Rj0yuE/cpn/jKEAeT1Ef4g4kNb-/ip/176.167.10.162 /ipbits/8/expire/1374538659/sparams/ip,ipbits,expire,id,itag,source,ratebypass,p fa,pbr,hls_chunk_host,gir,clen,lmt,maudio,cp,playlist_type,pmbypass/signature/57 2036F9CB73E2CCC31EF80C024B33FA4B1BE0E6.42CC45184775D0C5076A08276160F314126066A3/ key/dg_yt0/file/index.m3u8': Duration: 01:07:08.00, start: 95040.586022, bitrate: 1 kb/s Program 0 Metadata: variant_bitrate : 0 Stream #0:0: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p, 1920x1080 [SAR 1:1 DAR 16:9], 12.50 fps, 25 tbr, 90k tbn, 50 tbc Stream #0:1: Audio: aac ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 16 6 kb/s 95056.64 A-V: 0.118 fd= 140 aq= 0KB vq= 0KB sq= 0B f=0/0Last edited by chapun67; 22nd Jul 2013 at 14:26.
example
Code:ffmpeg -i "http://www.youtube.com/api/manifest/hls_playlist/ id/1a86fa62ffd24806/itag/96/source/youtube/ratebypass/yes/pfa/1/pbr/yes/hls_chun k_host/www.youtube.com/gir/yes/clen/3248226208/lmt/1347656498690111/maudio/1/cp/ U0hWSVVOVl9KU0NONl9NSFpHOkRsWC1tUVhkWXcx/playlist_type/DVR/pmbypass/yes/fexp/929 117,929121,929906,929907,929127,929129,929131,925720,925722,925718,925714,929917 ,929919,912521,931917,904830,919373,904122,919387,936303,900816,936301,912711,93 5000,921057,929309/sver/3/upn/bHu78Rj0yuE/cpn/jKEAeT1Ef4g4kNb-/ip/176.167.10.162 /ipbits/8/expire/1374538659/sparams/ip,ipbits,expire,id,itag,source,ratebypass,p fa,pbr,hls_chunk_host,gir,clen,lmt,maudio,cp,playlist_type,pmbypass/signature/57 2036F9CB73E2CCC31EF80C024B33FA4B1BE0E6.42CC45184775D0C5076A08276160F314126066A3/ key/dg_yt0/file/index.m3u8" -c copy t.ts
No i dont know where i but it
1/ i download ffmpeg from http://ffmpeg.zeranoe.com/builds/
2/ i unzip the downloder file then bult new floder in C
and copey 4 file into it
3/ open my firfox and play my video and filtr to m3u8 .. Then i see long url for it ,, here i dont know do any think
Please explain me what do i have to do after thes
Sorry for my weack ENGLISH -
ffmpeg -i "http://content.uplynk.com/b7926b0de0754f069f6bc732535dd5a5/g.m3u8?exp=1374600472&ct=a&eid=10001505&oid=3605f191611c4f129693c83bd79c35b8&iph=dddf987b60637c5e4cfae3b3be40cc72146614de4dbb126a1dc0864334ff91da&sig=61b274d5d1acaafe28f28afae89f964635125a94149cd8ac542ffe9b2fbe259d&pbs=8236864912ae41a3a85f161d27019e6f" -c copy t.ts
[hls,applehttp @ 025e7a60] Could not find codec parameters for stream 2 (Audio: mp3 ([21][0][0][0] / 0x0015), 0 channels, s16p): unspecified frame size Consider increasing the value for the 'analyzeduration' and 'probesize' options Input #0, hls,applehttp, from 'http://content.uplynk.com/b7926b0de0754f069f6bc73 2535dd5a5/e.m3u8?exp=1374642289&ct=a&eid=10001505&oid=3605f191611c4f129693c83bd7 9c35b8&iph=86eaadd0950d3528e49b26afacd204728964ae3436b2962f7f06019e821367af&sig= 021784788fd34f4c6ae24a63a2a863bb7f16a832a62be9217a768ce85b9da38d&pbs=c4d06587a58 b474eb779b088f91e16f6': Duration: 00:43:32.00, start: 0.000000, bitrate: 0 kb/s Program 0 Metadata: variant_bitrate : 0 Stream #0:0: Audio: aac ([15][0][0][0] / 0x000F), 48000 Hz, stereo, fltp, 87 kb/s Stream #0:1: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p, 704x396, 15 fps, 23.98 tbr, 90k tbn, 60 tbc Stream #0:2: Audio: mp3 ([21][0][0][0] / 0x0015), 0 channels, s16p Output #0, mpegts, to 't.ts': Metadata: encoder : Lavf55.2.100 Stream #0:0: Video: h264 ([27][0][0][0] / 0x001B), yuv420p, 704x396, q=2-31, 15 fps, 90k tbn, 30 tbc Stream #0:1: Audio: aac ([15][0][0][0] / 0x000F), 48000 Hz, stereo, 87 kb/s Stream mapping: Stream #0:1 -> #0:0 (copy) Stream #0:0 -> #0:1 (copy) Press [q] to stop, [?] for help frame= 952 fps=0.0 q=-1.0 size= 2997kB time=00:00:40.14 bitrate= 611.5kbits/ frame= 1145 fps=862 q=-1.0 size= 3605kB time=00:00:48.17 bitrate= 613.0kbits/ frame= 1337 fps=625 q=-1.0 size= 4208kB time=00:00:56.19 bitrate= 613.4kbits/ frame= 1529 fps=512 q=-1.0 size= 4803kB time=00:01:04.21 bitrate= 612.7kbits/ frame= 1626 fps=449 q=-1.0 size= 5112kB time=00:01:08.22 bitrate= 613.8kbits/ frame= 1722 fps=404 q=-1.0 size= 5411kB time=00:01:12.23 bitrate= 613.7kbits/ frame= 1818 fps=371 q=-1.0 size= 5713kB time=00:01:16.24 bitrate= 613.8kbits/ frame= 1914 fps=345 q=-1.0 size= 6010kB time=00:01:20.25 bitrate= 613.5kbits/ frame= 2010 fps=325 q=-1.0 size= 6311kB time=00:01:24.26 bitrate= 613.5kbits/ frame= 2106 fps=309 q=-1.0 size= 6609kB time=00:01:28.27 bitrate= 613.3kbits/ frame= 2202 fps=294 q=-1.0 size= 6908kB time=00:01:32.28 bitrate= 613.2kbits/ frame= 2299 fps=283 q=-1.0 size= 7199kB time=00:01:36.29 bitrate= 612.4kbits/ frame= 2395 fps=256 q=-1.0 size= 7492kB time=00:01:40.30 bitrate= 611.8kbits/ frame= 2491 fps=249 q=-1.0 size= 7790kB time=00:01:44.32 bitrate= 611.8kbits/ s -
Hi! Chapun67!
I sent you my account. I tried many ways to download but still failed. Please help! -
Could someone please help me with a working code to get this video to download in rtmpdump?
rtmpe://cp10740.edgefcs.net/ondemand/mtvnorigin/gsp.originmusicstor/reencode/mtv.com/onair/rw_rr_challenge/dailies/289990_1299345770000_768x432_1700_m30.mp4
I tried to use the previous code seeing that it was the same http://media.mtvnservices.com/player/prime/mediaplayerprime.2.3.10.swf but it still doesnt work giving me:
C:\Users\Robin>rtmpdump -r "rtmpe://cp10740.edgefcs.net/ondemand/mtvnorigin/gsp.
000_768x432_1700_m30.mp4" -W "http://media.mtvnservices.com/player/prime/mediapl
ayerprime.2.3.10.swf" -o "Dailies1.flv"
RTMPDump v2.4
(c) 2010 Andrej Stepanchuk, Howard Chu, The Flvstreamer Team; license: GPL
Connecting ...
WARNING: HandShake: Type mismatch: client sent 6, server answered 9
INFO: Connected...
ERROR: RTMP_ReadPacket, failed to read RTMP packet body. len: 20515 -
rtmpdump -r "rtmpe://cp10740.edgefcs.net/ondemand/mtvnorigin/gsp.originmusicsto r/reencode/mtv.com/onair/rw_rr_challenge/dailies/289990_1299345770000_768x432_17 00_m30.mp4" -W "http://media.mtvnservices.com/player/prime/mediaplayerprime.2.3. 10.swf" -o "Dailies1.flv" RTMPDump v2.4 GIT-2012-12-30 (Compiled by KSV) (c) 2010 Andrej Stepanchuk, Howard Chu, The Flvstreamer Team; license: GPL Connecting ... WARNING: HandShake: Type mismatch: client sent 6, server answered 9 INFO: Connected... Starting download at: 0.000 kB INFO: Metadata: INFO: duration 111.87 INFO: moovPosition 32.00 INFO: width 768.00 INFO: height 432.00 INFO: videocodecid avc1 INFO: audiocodecid mp4a INFO: avcprofile 77.00 INFO: avclevel 30.00 INFO: aacaot 2.00 INFO: videoframerate 23.98 INFO: audiosamplerate 22050.00 INFO: audiochannels 2.00 INFO: trackinfo: INFO: length 2679000.00 INFO: timescale 23976.00 INFO: language eng INFO: sampledescription: INFO: sampletype avc1 INFO: length 2466816.00 INFO: timescale 22050.00 INFO: language eng INFO: sampledescription: INFO: sampletype mp4a 7894.673 kB / 46.67 sec (41.7%)
Hello.
I used rtmpdump-2.4-git-010913 to capture video at
http://www.ndtv.com/video/player/the-buck-stops-here/the-secularism-debate-just-a-medi...ixation/284320
I watched patiently as the video capturing seemed real - with increasing "xx% downloaded" message.
After 9hours, It said "Download completed" , file size 1.6GB, duration 54 minutes.
When I played the file, all I had was repeat of 1st 4minutes of video with out of sync audio - a total junk.
It seems there is no way to capture such videos using free software.Last edited by ConverterCrazy; 27th Jul 2013 at 04:48. Reason: typo
Hello.
I need to download streams from www.drnajeeblectures.com https://members.drnajeeblectures.com/videos/615 (after logging in)
Here is the link. rtmpe://streaming.vzaar.com:1935/
File name: vzaarvzcc53targetvzcc53108033374f799bfa8dff3db3d93 4.flv
I am unable to get a full link
Can someone please make me the command for rtmpdump
Thanks.Last edited by colliderz; 27th Jul 2013 at 08:23.
Sir that is is the whole issue. URL Snooper is not picking up any RTMP link. I got the link by GetFLV. Would it help if I provide you by the user/password for the account?
How to download a rtmp stream from a website
By krb214 in forum Video Streaming DownloadingReplies: 2Last Post: 26th Jul 2011, 18:08 -
Need some advice on how to download certain rtmp streams
By aveceux in forum Video Streaming DownloadingReplies: 3Last Post: 13th Jun 2011, 08:45 -
Free DivX Pro Software Download
By MJA in forum Video ConversionReplies: 11Last Post: 18th Dec 2010, 07:21 -
RTMP Flash file help?
By xiaofan in forum Newbie / General discussionsReplies: 0Last Post: 3rd Jun 2007, 08:16
