Page 32 of 154
FirstFirst ... 22 30 31 32 33 34 42 82 132 ... LastLast
Results 931 to 960 of 4610
    Nov 2012
    Adelaide, South Australia
    Originally Posted by chapun67 View Post
    Brenton Nicholson
    use ffmpeg
    ffmpeg -i "http://channelhd-i.akamaihd.net/i/mpx/video/Nat_Geo_Channels/28/584/28909156_Clash_of_the_Cheetahs_WB_,180,66,22,15,0.mp4.csmil/index_0_av.m3u8?e=b471643725c47acd" -c copy -absf aac_adtstoasc t.mp4
    Many thanks. Worked a treat. Downloaded ffmpeg and unzipped it. I think this has been mentioned before but I copied the code to Notepad, saved it as a text file and renamed it to .bat. That way, while playing around, you don't have to keep entering the very long code, just the name of the .bat file. I started playing with computers before Windows came out so I knew my way around DOS a bit (although very rusty). Interestingly the video came out as 640 x 480, played as widescreen in VLC and MPC-HC but didn't fill the whole screen. I cropped it using Easiesestsoft Video Converter but this only let me crop the top and bottom. The conversion preview seemed to indicate the ouput was full screen (640 x 360) and it played fullscreen in MPC-HC but in VLC it played as 4:3? Played fine by forcing the aspect ratio to 16:9 (have now set this to default). Hard enough to get the downloads, let alone understand the vagaries of video files! Anyway, the challenge is now to figure out how the download code was generated. Thanks again.
    Feb 2005
    Canada
    Originally Posted by Seeker47 View Post
    Sometimes you really don't want to update a program (whether you were aware of this or not), as in the case of Tubedigger 3.1.2, or Replay Media Catcher
    Very true, hi buddy, can you point me to a copy of TubeDigger 3.1.2?
    Many thanks in advance.
  3. Hi
    Any idea on how to get rtmpe parameters to download this vid ? I've tried all rtmpdump guis with no succes. I only need the tool to use, I'll rewrite if necessary the code by myself.
    Regards
  4. Originally Posted by Washington View Post
    Hi
    Regards
    rtmpdump -r "rtmpte://vod.foire-colmar-tv.com/vod/foirecolmarTV/foirecolmarTV/Nicolas_Canteloup_2012" -o "low.flv"
  5. Originally Posted by chapun67 View Post
    Hi
    Regards
    Thank you ! But did you read my question ? I want someone to tell me the tool to use to get the parameters you used in the code. Please tell me how you managed it/.
    Regards
  6. hi everybody!
    I am trying to download a video with rtmpdump. May be you can help.
    I got the url of the video, but i always get the same error:
    ERROR: RTMP_Connect0, failed to connect socket. 111 (Connection refused)
    here is the video i want to download: http://videos.arte.tv/fr/videos/le-declin-de-l-empire-masculin--7361452.html
    here is the url i found using code source of the htmpl page opening xml file, then getting another url with an new xml file and with this rtmp url:
    rtmp://artestras.fcod.llnwd.net/a3903/o35/mp4:geo/videothek/ALL/arteprod/A7_SGT_ENC_08_045543-000-A_PG_HQ_FR?h=1bdc86a94dcdeb3b8ef02570e96b7d9c
    Have you got an idea whit what is wrong guys with the error message i get?
  7. Originally Posted by nightowl67 View Post
    hi everybody!
    HTML Code:
    rtmpdump -r "rtmp://artestras.fcod.llnwd.net:1935/a3903/o35" -a   "a3903/o35" -f "WIN 11,6,602,171" -W   "http://videos.arte.tv/blob/web/i18n/view/player_24-3188338-data-5168030.swf"   -p   "http://videos.arte.tv/fr/videos/le-declin-de-l-empire-masculin--7361452.html"   -C B:0 -y   "mp4:geo/videothek/ALL/arteprod/A7_SGT_ENC_08_045543-000-A_PG_HQ_FR?h=1bdc86a94dcdeb3b8ef02570e96b7d9c"   -o A7_SGT_ENC_08_045543-000-A_PG_HQ_FR.flv
    Use RTMPexploreX to get the code or to download it. If you live in France, the easiest way to get it is to use Captvty. You can find all those softwares and many others it in a ready to use multimedia toolkit called ReplayTV_Pack.
  8. Originally Posted by Washington View Post
    Hi
    Regards
    Regards
    use firefox>use HxD>open RAM>plugin-container.exe>search "rtmp"
  9. Thanks dude, but your command doesn't work, i still get the same error message:
    RTMPDump v2.4
    (c) 2010 Andrej Stepanchuk, Howard Chu, The Flvstreamer Team; license: GPL
    Connecting ...
    i use linux, tat is why i try to download it with rtmpdump. I can't use any windows stuff.
    hi everybody!
    HTML Code:
  10. Originally Posted by nightowl67 View Post
    RTMPDump v2.4
    Connecting ...
    You can ran those softwares on Linux through Wine. The code I gave you worked fine with rtmpExplorerX_2.5 (one of the softwares inside ReplayTV_Pack).
  11. Originally Posted by chapun67 View Post
    Hi
    Regards
    Regards
    Thank you for the tip, but I don't understand why I don't get the parameters. Yet I followed your method step by step : when I seach "rtmp", I see many lines of rtmpe but no one includes "rtmpte://vod.foire-colmar-tv.com/vod/foirecolmarTV/foirecolmarTV/Nicolas_Canteloup_2012"
    Here is a part of the code :
    *@NetConnection.Connect.CertificateAPIError...NetConnection.Connect.CertificateInvalid....NetConnection.Connect.CertificateRevoked....NetConnection.Connect.CertificateUntrustedSigner....NetConnection.Connect.CertificatePrincipalMismatch..NetConnection.Connect.CertificateExpired....NetConnection.Connect.SSLHandshakeFailed....NetConnection.Connect.SSLNotAvailable...NetConnection.Connect.ProxyAuthFailed...401.200.CONNECT %s:%d HTTP/1.1 .....CONNECT %s:%d HTTP/1.1......rtmpt...rtmpte..rtmps...rtmp....rtmpe...rtmfp...NetConnection.Connect.NetworkChange./close../.../send.............P?count...other...audio.../idle...X-RTMPT-Max-Pipelined-Requests../open/1./fcs/ident2.rtmfp:..127.0.0.1...fpadWait....fpadOnly....fpadZone....uri.fpadPort....combinePackets..CONNECTOnly.best....HTTP....proxyType.......!WõkÕ‹XlÕ‹XlÕ‹Xl+XõkÕ‹XlÕ‹XlÕ‹XlÕ‹XlA©õkÕ‹Xlwjõk”jõk[jõk
    What did I wrong ?
  12. Originally Posted by Washington View Post
    *@NetConnection.Connect.CertificateAPIError...NetConnection.Connect.CertificateInvalid....NetConnection.Connect.CertificateRevoked....NetConnection.Connect.CertificateUntrustedSigner....NetConnection.Connect.CertificatePrincipalMismatch..NetConnection.Connect.CertificateExpired....NetConnection.Connect.SSLHandshakeFailed....NetConnection.Connect.SSLNotAvailable...NetConnection.Connect.ProxyAuthFailed...401.200.CONNECT %s:%d HTTP/1.1 .....CONNECT %s:%d HTTP/1.1......rtmpt...rtmpte..rtmps...rtmp....rtmpe...rtmfp...NetConnection.Connect.NetworkChange./close../.../send.............P?count...other...audio.../idle...X-RTMPT-Max-Pipelined-Requests../open/1./fcs/ident2.rtmfp:..127.0.0.1...fpadWait....fpadOnly....fpadZone....uri.fpadPort....combinePackets..CONNECTOnly.best....HTTP....proxyType.......!WõkՋXlՋXlՋXl+XõkՋXlՋXlՋXlՋXlA©õkՋXlwjõk”jõk[jõk
    What did I wrong ?
    CDATA[0x000000]]>
  13. Originally Posted by Washington View Post
    Hi
    Regards
    Regards
    What did I wrong ?
    http://pastebin.com/9sFYAYDw
  14. Thank you, dude ! As you can see, I did not get the same data as yours. That means I did something wrong. I may have missed a step.
    1) I used Firefox and went to read the vid
    2) I ran HxD
    3) I opened RAM
    4) I choosed "plugin-container.exe"
    5) I then searched for the keywords "rtmp", "vod"
    What did I miss ? Why don't I have the same results as yours ? Do you I an idea on how to fix the problem ?
  15. Originally Posted by Washington View Post
    2) I ran HxD
    3) I opened RAM
    press F3
  16. I have tried everything on these forums, but I can't get anywhere. What's the command to get the video from this URL?
    http://www.menshealth.com/video/relationships/stand-out-crowd#/video/sex_women/created/d/1
  17. Hi guys,
    can anyone help me download this video:
    http://capitulostelenovelashd.blogspot.com/2012/08/por-ella-soy-eva-capitulo-22.html#more
    It is geo blocked but I use proxy and every program (TubeDigger, StreamTransport, HiDownloader) recognizes it, but I cannot download it in HD and at the beginning of download process, file has 680MB but during download process it lowers down until 180MB and video has lower resolution.
    This one, on the same site downloads perfectly:
    http://capitulostelenovelashd.blogspot.com/2012/08/por-ella-soy-eva-capitulo-20.html
    Please help!
  18. Originally Posted by llaallaalllaaa View Post
    I'm not sure whether the video is in HD or not, but I'm currently downloading it with Internet Download Manager.
    This is the URL that the video is downloading from:
    rtmp://cp31851.edgefcs.net/ondemand/mp4:univisionflash/media/12/08/15/120815_573/120815_2727964_Por_Ella_Soy_Eva_Capitulo_22_134515 3608_500.mp4
  19. Originally Posted by mike20021969 View Post
    Hi,
    thanx for your fast reply. I downloaded all previous episodes, and all were in HD. This one, when I watch it in mozilla looks like HD, but when I download it, it looks awfull (180MB, video bitrate 18) and all others are in 1280x720 (2138 bitrate). Also all other episodes I downloaded, were not geo blocked. This is the first one. Maybe video is not HD, but why in mozilla it looks way much better?
  20. Originally Posted by llaallaalllaaa View Post
    It's probably not in HD. I couldn't see an HD option on the player for this particular episode.
    Normally, there is usually an option for people to view in low or high definition when watching online.
  21. Originally Posted by mike20021969 View Post
    Well, it should be as this site embeeds it from the site where all videos are in HD. What confuses me is that during download, size of the file is getting bigger (the one that should be downloaded, the source)
  22. Originally Posted by chapun67 View Post
    2) I ran HxD
    3) I opened RAM
    press F3
    Thank you very much for your help. I followed the vid you posted, but didn't manage to get the same results. I kept it and hope it will help me for other streams.
    Regards
  23. Edit: I tried StreamTransport and it looks like it's downloading
    Hi, can I get some help downloading these 2 videos? I got the rtmp url sources (I think) but can't figure out how to get the video.
    http://ww3.tvo.org/video/162279/christopher-hitchens
    http://ma156-r.analytics.edgesuite.net/9.gif?a=S~b=9c1e67f75e9bf1686~c=04D999AFEC4634044DDE151F6608D756E6223169~d=66D174EC8C54AB5EA3853AAC977C6C12391210F2~e=1~f=R~g=0~h=1.2~i=1.1~k=F340706C9D5027C78C7A5733A6293E164DB757A9~am=D~_ac=ds/rtmp/ondemand/&mp4:1351824783/1351824783_889234858001_855299-01020929-01225507-480x360-900k.mp4&1364004000000&7cf3ae8469ccf7fc380b0f826da32633~ag=ww3.tvo.org~al=Windows%207~dx=0.574~en=Christopher%20Hitchens~pd=756015080001~_tt=Christopher%20Hitchens~_cd_1557=18140038001~cm=Limelight~v=0~w=449~aa=brightcove.fcod.llnwd.net~ab=a500/e1/uds/rtmp/ondemand/&mp4:1351824783/1351824783_889234858001_855299
    And
    http://ww3.tvo.org/video/163826/axis-evil
    http://ma156-r.analytics.edgesuite.net/9.gif?a=P~b=9c1e67f75e9bf1686~c=B0FC31246D7183431F2BCC652570ABF31FC91DC1~d=66D174EC8C54AB5EA3853AAC977C6C12391210F2~e=2~f=R~g=0~h=1.2~i=1.1~k=5047BB00EFA424DDDEDC51E7CACED002FBA161DC~am=D~_ac=ds/rtmp/ondemand/&mp4:1351824783/1351824783_672223775001_907589-480x360-900k.mp4&1364004000000&7cf3ae8469ccf7fc380b0f826da32633~ag=ww3.tvo.org~al=Windows%207~dx=5.16~en=The%20Axis%20of%20Evil~pd=756015080001~_tt=The%20Axis%20of%20Evil~_cd_1557=18140038001~cm=Limelight~m=PL~n=8230470.4662:9~o=5025342.7472:9~p=46825972.4082:9~q=20432.6229:9~r=94276:9~s=94261:9~t=0:9~u=0~v=4879~w=5938~x=5166~y=4800~z=0
    I used URL Snooper/Chrome on win7
  24. CaNANDian
    rtmpdump -r "rtmp://brightcove-41.fcod.llnwd.net:1935/a500/e1/uds/rtmp/ondemand" -a "a500/e1/uds/rtmp/ondemand?videoId=889246743001&lineUpId=&pubId=18140038001&playerId=756015080001&affiliateId=" -f "WIN 11,6,602,180" -W "http://admin.brightcove.com/viewer/us20130319.1040/federatedVideoUI/BrightcovePlayer.swf" -p "http://ww3.tvo.org/video/162279/christopher-hitchens" -C B:0 -C S:mp4:1351824783/1351824783_889234858001_855299-01020929-01225507-480x360-900k.mp4&1364007600000&0a520f1759c5689c09b6906657af64c7 -y "mp4:1351824783/1351824783_889234858001_855299-01020929-01225507-480x360-900k.mp4?videoId=889246743001&lineUpId=&pubId=18140038001&playerId=756015080001&affiliateId=" -o "1351824783_889234858001_855299-01020929-01225507-480x360-900k.mp4.flv"
    rtmpdump -r "rtmp://brightcove-84.fcod.llnwd.net:1935/a500/e1/uds/rtmp/ondemand" -a "a500/e1/uds/rtmp/ondemand?videoId=672230986001&lineUpId=&pubId=18140038001&playerId=756015080001&affiliateId=" -f "WIN 11,6,602,180" -W "http://admin.brightcove.com/viewer/us20130319.1040/federatedVideoUI/BrightcovePlayer.swf" -p "http://ww3.tvo.org/video/163826/axis-evil" -C B:0 -C S:mp4:1351824783/1351824783_672223775001_907589-480x360-900k.mp4&1364007600000&0a520f1759c5689c09b6906657af64c7 -y "mp4:1351824783/1351824783_672223775001_907589-480x360-900k.mp4?videoId=672230986001&lineUpId=&pubId=18140038001&playerId=756015080001&affiliateId=" -o "1351824783_672223775001_907589-480x360-900k.mp4.flv"
  25. Originally Posted by CaNANDian View Post
    Internet Download Manager can download these EASILY
  26. Member
    Jan 2013
    Heaven
    I've strange behavior on some sites. rtmpsrv is downloadin' upon 2-3% percent then is redownloadin' by portion.
    Metadata of the file also not present. Using rtmpdump 2.5
    It's a kind of downloadin' by parts <14.1%.....15% then 12.1 again and again.
    What is needed to understand....handshake updated?!
    I think I have found the answer: http://lists.mplayerhq.hu/pipermail/rtmpdump/2010-May/000878.html
    FMS 3.5 servers send the following two controls to let the client know when the server has sent a complete buffer. I.e., when the server has sent an amount of data equal to m_nBufferMS in duration. The server meters its output so that data arrives at the client in realtime and no faster.
    LE: Now video seems to download good by using -v but it's downloadin' real-time...
  27. Member
    Jan 2013
    Heaven
    What did you removed from the original rtmpdump form to download with IDM?
    EDIT: Apologise for double post...
  28. Originally Posted by medico View Post
    I didn't remove or do anything.
    IDM captures the url automatically and presents a download button so you can download it.
    (IDM wont download protected content though).
    These are the 2 urls from IDM:
    rtmp://brightcove-41.fcod.llnwd.net:443/a500/e1/uds/rtmp/ondemand?videoId=889246743001&lineUpId=&pubId=18140038001&playerId=756015080001&affiliateId=/mp4:1351824783/1351824783_889234858001_855299-01020929-01225507-480x360-900k.mp4?videoId=889246743001&lineUpId=&pubId=18140038001&playerId=756015080001&affiliateId=
    rtmp://brightcove-84.fcod.llnwd.net:443/a500/e1/uds/rtmp/ondemand?videoId=672230986001&lineUpId=&pubId=18140038001&playerId=756015080001&affiliateId=/mp4:1351824783/1351824783_672223775001_907589-480x360-900k.mp4?videoId=672230986001&lineUpId=&pubId=18140038001&playerId=756015080001&affiliateId=
  29. Member
    Jan 2013
    Heaven
    Mine says: Name:  Image%202013-03-27%20at%2011.14.19%20AM.png
  30. Originally Posted by medico View Post
    That's because you do not need to enter that URL into IDM. In fact, I wouldn't be surprised if the video location URL changes (like on YouTube).
    So, all you need to do is go to the web page where the video is, and click play on the flash player.
    Then, this button appears:
    Click on the green arrow to download the video (an additional window will then appear so you can change any parameters).
    If you're happy with the settings, click "Start Download".
