Page 153 of 154
FirstFirst ... 53 103 143 151 152 153 154 LastLast
Results 4,561 to 4,590 of 4610
    Feb 2006
    Originally Posted by 7PWpNxx5 View Post
    just use yt-dlp & the firefox browser addon called "the stream detector" use it to grab the MPD
    and download the video.
  2. Nice work and fast as always october262. Thank you a million times
  3. Can someone help me with this one ?
    https://tvvision.no/playepisode.php?ep=402051
    Thanks in advance
  4. there is a "new" way to get these now, though i have been using it for a while now. if you use VLC, you can just load the m3u8 link into it, and save the video locally.
    to get that m3u8 link, you only need to right-click the page with the video, and click Inspect. then go to the Network tab, and look at the entries in a subtab named XHR. when you first load the page, it should be mostly empty. if not, just clear it. but as soon as you click play, pause it again right away, and the FIRST entry at the top should be the m3u8 file link. it is auto-generated with a hash authorization code which expires, so i cannot just give it to you, but if you just copy that link, then open VLC, and click Media > Convert/Save > Network , then Paste the URL into the field, and click the Convert/Save button at the bottom, it will start playing WITHOUT displaying anything. THIS IS NORMAL! it will play very quickly while it saves the file locally. don't interrupt it or do anything else on your PC. when it is done, you should be able to play the file in VLC to test it
    P.S., make sure that when you choose what format to save it in, you choose MP4, and have it copy the video and audio without re-encoding it. This will result in the best quality and fastest download.
    darkflux
  5. Quote
    darkflux "there is a "new" way to get these now...."
    AND LZAA.
    \Quote
    Thanks a million times for all the hard work. I had som problem with my PC, but this fixed it AND i LEARNED A LOT
    AND
    HAPPY AND PEACEFULL Christmas
  6. Hi guys, any ideas on how to download either the video or entire playlist from here? submeta/courses/introduction
    Uses cloudflare - can get the dash-video link, but the file downloaded is encrypted (?) - https://150vod-adaptive.akamaized.net/exp=167....~acl=%2Fdbbb38be-cdfe-45b8-9~hmac=850...dash-video.mp4
    Update: Found that it is hosted on Vimeo; one way is to get the link above and download the .mpd which works - any other solutions you guys use?
  7. streamlink "https://customer-3j2pofw9vdbl9sfy.cloudflarestream.com/533e172b85b64d865a9c9f33d4a4f4d0/manifest/video.mpd?parentOrigin=https%3A%2F%2Fsubmeta.io" best -o video.ts
  8. Downloading the long way
    filter on init
    https://64vod-adaptive.akamaized.net/exp=1673550148~acl=%2Fcb840b23-57b2-4070-95e2-c5157697ac7f%2F%2A~hmac=eb2bfe531e27ceaec561742deee5726ab817322b143b9e87ab80d9b9f2ec8de8/cb840b23-57b2-4070-95e2-c5157697ac7f/sep/video/bdd0bcde,baf59356,d03af824,ae35702b,94eb4088/audio/ad3393de,e34ccf8d/master.json?query_string_ranges=1&base64_init=1
    look call :
    video options : bdd0bcde,baf59356,d03af824,ae35702b,94eb4088
    audio options : ad3393de,e34ccf8d
    look at video url call in dev tools
    https://64vod-adaptive.akamaized.net/exp=1673550148~acl=%2Fcb840b23-57b2-4070-95e2-c5157697ac7f%2F%2A~hmac=eb2bfe531e27ceaec561742deee5726ab817322b143b9e87ab80d9b9f2ec8de8/cb840b23-57b2-4070-95e2-c5157697ac7f/parcel/video/baf59356.mp4?r=dXM%3D&range=1634-163801
    look at audio url call in dev tools
    https://64vod-adaptive.akamaized.net/exp=1673550148~acl=%2Fcb840b23-57b2-4070-95e2-c5157697ac7f%2F%2A~hmac=eb2bfe531e27ceaec561742deee5726ab817322b143b9e87ab80d9b9f2ec8de8/cb840b23-57b2-4070-95e2-c5157697ac7f/parcel/audio/e34ccf8d.mp4?r=dXM%3D&range=1635-75296
    now consider the range parameters .... they start at 0 and the ending parameter has to be determined
    Search the response on the master.json call and seek the final range response for baf59356 and e34ccf8d
    baf59356.mp4?r=dXM%3D\u0026range=10021320-10133343
    e34ccf8d.mp4?r=dXM%3D\u0026range=4641845-4700234
    download the audio
    https://64vod-adaptive.akamaized.net/exp=1673550148~acl=%2Fcb840b23-57b2-4070-95e2-c5157697ac7f%2F%2A~hmac=eb2bfe531e27ceaec561742deee5726ab817322b143b9e87ab80d9b9f2ec8de8/cb840b23-57b2-4070-95e2-c5157697ac7f/parcel/audio/e34ccf8d.mp4?r=dXM%3D&range=0-4700234
    download the video
    https://64vod-adaptive.akamaized.net/exp=1673550148~acl=%2Fcb840b23-57b2-4070-95e2-c5157697ac7f%2F%2A~hmac=eb2bfe531e27ceaec561742deee5726ab817322b143b9e87ab80d9b9f2ec8de8/cb840b23-57b2-4070-95e2-c5157697ac7f/parcel/video/baf59356.mp4?r=dXM%3D&range=0-10133343
    Mux the two
    ffmpeg -i "video.mp4" -i "audio.mp4" -c copy "final.mp4"
  9. Hi guys - can anyone help with downloading from Loom? e.g. loom.com/share/0afe10285bc74af2bb2c9b412ffd26a5
    Previously you could download the 'manifest.mpd' file and edit 'initialization' and the 'media' attribute to incorporate the full url with query-params, and then download with ffmpeg by feeding that local-manifest.mpd file, but now they've changed the way they do things.
  10. Originally Posted by Restricted View Post
    they use HLS just use ublock origin addon as urls sniffer and search for m3u8 or use HLS Downloader addons for chrome or firefox
  11. Originally Posted by Silv3r View Post
    Have tried but the links are unable to download - did it work for you? These are the links obtained...
    https://luna.loom.com/id/0afe10285bc74af2bb2c9b412ffd26a5/rev/61b5d89c1600b960edeed6fb...y-Pair-Id=AAAA
  12. No need
  13. Originally Posted by 7PWpNxx5 View Post
    No need
    no need for what? your post? i agree.
    darkflux
  14. Now I need to download videoes from the following forum which you have to create an account to do for having access:
    https://app.clouthub.com/
    This is an open and free forum and account.
    I'am interessted to download the following video:*
    https://app.clouthub.com/#/posts/e17c5538-dea7-4b23-95d1-8a598df6c674
    How do I do it ???
  15. Originally Posted by 7PWpNxx5 View Post
    How do I do it ???
    https://chromewebstore.google.com/detail/stream-recorder-download/iogidnfllpdhagebkblk...jkbkjdmm?hl=pl
  17. what exactly is "not safe" about it, and how does it "steal information"? iy's available on CNET:
    https://download.cnet.com/ivideomate-downloader/3000-2071_4-78427445.html
    and what do you mean "these apps"? your statements are very sparse, and general. mind sharing what led you to this understanding?
    darkflux
  19. not sure what kinds of issues you are running into installing. i just downloaded and installed the one at the CNET link in less than a minute. it was about 80MB.
    perhaps your internet speed is too slow? or if your firewall is blocking it? it's also possible that part of your hard drive is corrupted? have you tried running chkdsk on your C: drive?
    darkflux
  20. Any idea how to download this? Seems to be in lots of tiny bits and no m3u8 that I can see
    https://www.rte.ie/player/series/for-one-night-only/SI0000000612?epguid=IH000279902p
  21. Member Seeker47's Avatar
    Jul 2005
    This will be something of a late recap. I was always too busy (or lazy) to bother with the likes of RTMPdump or any other full manual / command line tools. My top three download solutions -- although these are not free -- had long been Tubedigger, Allavsoft Downloader, and Videoget. TD has a generous and very cheap license, Allavsoft turns up a couple times per year as a freebie promo from one or another of the sites regularly offering such things (GiveAwayoftheDay, SharewareOnSale, and BitsDuJour), and VideoGet is from Nuclear Coffee. More recently, the latter and maybe the latter two have been knocked off their leading perch here by MediaHumanYouTube Downloader. It covers a lot more than YT, as do the others, and it is super swift. And quite impressive. I like to keep all of these programs available for use. If one of them can't pull in some video or stream you are after, then I'd say you've got a BIG problem.
    I'm aware that VLC includes a capability for capturing streams . . . but again, I've glanced at a couple tutorials, considered the learning curve, and once again being busy or lazy wins. Some day perhaps. For now, I'm not missing out on much of anything of interest, just relying on the programs I've mentioned. (And I think they are all updated regularly, to keep pace with various sites' countermeasures.)
    Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com
  22. Originally Posted by -Monkey47- View Post
    [code]https://www.rte.ie/player/series/for-one-night-only/SI0000000612?epguid=IH000279902p/code]
    looks like they took it down. seems it really WAS "For One Night Only", lol
    @Seeker47: if i had the ability/desire to pay for something, i wouldn't be trying to just download it. plus, at least for a lot of us, the thrill is in finding the loophole in the programming; the proper steps to sidestep thru the maze. it is ALWAYS possible, but not always easy. but nothing good is ever easy.
    as for the VLC trick, it only works if you can find the m3u8 source. which you can do by hitting F12 (Developer Mode), going to the Network tab, and filtering the list for "m3u8". then just copy and paste that into VLC, using their Convert/Save function, being sure to choose "Copy" for video and audio, rather than re-encoding. this will both make it faster, and better (original source) quality.
    anybody who can't do that much probably should buy a program. or learn some video editing skillz
    darkflux
  23. My bad, there was an error in the link.
    What about this one? I’m pretty techy so interested to see if it’s possible.
    https://www.rte.ie/player/movie/cloch-le-carn-christy-dignam-s1-e1/471988264441
    You’d need a vpn to access as it’s an Ireland only site.
    Thanks.
  24. Originally Posted by -Monkey47- View Post
    Thanks.
    https://gofile.io/d/Z8cpYw
  25. Ace. Thanks. Can you point me in the direction of how you did it? Some others I’d like to grab also.
  26. Originally Posted by -Monkey47- View Post
    sure check PM
  27. Member Seeker47's Avatar
    Jul 2005
    [QUOTE=darkflux;2718317]
    Not a matter of "can't" for me so much as a matter of ease, efficiency, time & effort. There always seem to be more important or more urgent things going on here. That's also the reason why my 'Go To' for video editing continues to be Machete, basic and limited as it is. No learning curve to speak of, but (usually) gets the job done for me. Every time I got bogged down in the extensive timeline and detailed selection controls of the more comprehensive editors, I just thought "can't deal with this right now" and reached for the reliable, familiar simplicity. As far as my hobbyist curiosity goes, that tends to be a can kicked down the road.
