Page 130 of 154
FirstFirst ... 30 80 120 128 129 130 131 132 140 ... LastLast
Results 3,871 to 3,900 of 4610
  1. Originally Posted by fracassato View Post
    If you can provide the web page url of the video.
    ty
  2. It asks me an username and a password. If it is another restricted video I cannot do much about it...
    Do you have HTTPFox installed ?
    Activate it before reloading the page ( clean all previous catched url if any ), reload the page and in the search tab type video and you will filter all video objects captured.
    Copy and paste here all links you've got.
  4. @danielko: I can't PM you, I don't know why, this message you send me
    Originally Posted by danielko
    Hi Fracassato,
    can you help me with this link
    http://www.linkedu.tv/news/cisco-network-administration-2
    i got this link somehow: rtmp://148.251.85.99:1935/vod
    rtmp://148.251.85.99:1935/vod <--- this link works with ffmpeg/ffplay
    To download with ffmpeg, just parse
    ffmpeg -i rtmp://148.251.85.99:1935/vod -c:v copy -c:a copy -flags +global_header -y video.mp4
    Jan 2016
    Europe
    anyone can help this
    http://tpr199196sec-vh.akamaihd.net/z/secure/SPE_-_Central_Europe/194/451/SHANCH00103-Hungary,.,_1300.,_670.,mp4.csmil/2_6b2ff5ecca11e4fd_Seg1-Frag1_AQBZhPePaFMEjBb+mVYLKYb50+S5uW4ywUOJXyjsgbrdi8E9uyc4Wgzb+0EK2nLQ6qh15%2fx7?hdntl=exp=1453017265~acl=%2fz%2fsecure%2fSPE_-_Central_Europe%2f194%2f451%2fSHANCH00103-Hungary*~data=hdntl~hmac=145102203f9a1188514d139c361069436d45c3ff2a5e2f754c8cb0025a7cd273&als=64.58,60,1.6,0,659,1188,24.88,500,0,139,t,2325.65,2394.28,f,s,PCJSKSPVTWLQ,3.5.0,139&hdcore=3.5.0
  7. Originally Posted by Dartelton View Post
    web page link ?
    Jan 2016
    Europe
    web page link ?
    http://www.viasat3.hu/viasat-play/series/shannara-jovo-kronikaja/shannara-jovo-kronikaja-3-resz
  9. Originally Posted by Dartelton View Post
    web page link ?
    Sorry for being late.
    You need the following setup to download the video file. It's the easiest way I've found so far.
    1. Download and install PHP: http://nl3.php.net/downloads.php
    2. Download AdobeHDS script: https://github.com/K-S-V/Scripts/blob/master/AdobeHDS.php ( wiki: https://github.com/K-S-V/Scripts/wiki )
    3. Download HDS Link Detector: https://addons.mozilla.org/en-US/firefox/addon/hds-link-detector/ ( it will find for you the manifest of the video )
    4. Make sure to activate HDS Link Detector BEFORE starting playing video on the web page you give me ( it prompt automatically the command, just tip activate when it will show up )
    5. Open the terminal in the same directory you download AdobeHDS.php and parse the command HDS Link Detector gave you
    It should download the video file. For me It worked.
    Jan 2016
    Europe
    It's working perfectly too! I try couple of times to working, but i dont understand why not working, i skipped some steps, tyvm!
  11. I really need help please. I NEED this! I'm from outside Ireland and can't do it. http://www.rte.ie/player/ie/show/the-tommy-tiernan-show-tv-30003801/10510011 -
    Someone lovely has passed along these links:
    http://feeds.rasset.ie/rteavgen/player/playlist/?type=iptv&format=json&showId=10510011
    http://cdn.rasset.ie/hds-vod//2015/1227/20151227_rteone-thetommyti_cl10510011_10510148..._/manifest.f4m
    http://cdn.rasset.ie/hds-vod//2015/1227/20151227_rteone-thetommyti_cl10510011_10510148..._2048k.mp4.f4m
    FFMPEG won't work because I need to be within Ireland. I think. Can anyone shed some light? (If I could get the actual stream to play then I could screen record it at the very least.)
    Thank you so kindly for any help.
  12. Are these two valid links ?
    It says not found for both.
    I think you may have copied wrong the URL strings.
  13. Hi all,
    i try to extract a live stream from a Wowza Streaming Server.
    You can see the flashplayer-stream at:
    http://tv.exitoostore.com/2015/12/tv-online-tvn-v7.html
    I sniffed the tcp traffic to the streaming server and extracted the following interesting data:
    http://live.64ma.com:1930/tv/cmp.swf?ver=201406301600..t.cUrl..1rtmp://pip-live-tving-...videoCodecs.@o........
    videoFunction.?.........pageUrl..Xhttp://live.64ma.com:1930/tv/html/flv.asp?code=O2idv2iYJ6wkJRXKTn1KS2vSHRX7IgvCOBDs8 QNK3...objectEncoding.@.......................&%..............&%................................................. .._result.?..........fmsVer...FMS/3,5,7,7009..capabilities.@?........mode.?......... ....level...status..code...NetConnection.Connect.S uccess..description...Connection succeeded...data.......version..
    3,5,7,7009.....clientid.A....@....objectEncoding.@ ............|..........&%.C...........createStream.@........B.....
    ..........................._result.@.........?.... .........J.........play............5EC7A974C899C75 A7965B81E7028032E4?content_type=PREVIEW........... .................................onStatus......... ....level...status..code...NetStream.Play.Reset..d escription...Playing and resetting wowz://pip-live-tvingorigin2.myskcdn.com:1935/tvn/_definst_/s5|wowz://pip-live-tvingbackup2.myskcdn.com:1935/tvn/_definst_/s5...clientid.A....@..........."........onStatus.............level...status..code. ..NetStream.Play.Start..description...Started playing wowz://pip-live-tvingorigin2.myskcdn.com:1935/tvn/_definst_/s5|wowz://pip-live-tvingbackup2.myskcdn.com:1935/tvn/_definst_/s5
    I already tried some hours but did not success
    Maybe somebody could help to get the livestream with rtmpdump, vlc or similar.
    UPDATE
    I solved the problem myself. I found the following tool: https://github.com/andreafabrizi/rtmpSnoop
    It worked perfect and shows the stream information while starting the website-player:
    # ./rtmpSnoop.py
    rtmpSnoop v0.2.1 - The RTMP Sniffer!
    Andrea Fabrizi - andrea.fabrizi@gmail.com
    Starting sniffing on all devices...
    * RTMP Stream found!
    url: rtmp://pip-live-tving-tvn.cjenm.skcdn.com:80/tvn/EC7A974C899C75A7965B81E7028032E4?content_type=PREV IEW
    app: tvn/
    pageUrl: http://live.64ma.com:1930/tv/html/flv.asp?code=O2idv2iYJ6wkJRXKTn1KS2vSHRX7IgvCOBDs8QNK3
    swfUrl: http://live.64ma.com:1930/tv/cmp.swf?ver=201406301600
    tcUrl: rtmp://pip-live-tving-tvn.cjenm.skcdn.com:80/tvn/
    playPath: EC7A974C899C75A7965B81E7028032E4?content_type=PREV IEW
    flashVer: LNX 11,2,202,554
    Tim
    Nov 2014
    Germany
    Hi all!
    I want to download a video which is available than a video on demand on AXS TV,you can find the video here:
    http://www.axs.tv/schedules/free-on-demand/
    I want to grab the Farm Aid 30 special...
    But I could not access the video with the download code!
    Could anyone help me with a link or a code for downloading the video?
    Greetings,
    HJ
  16. Hi!
    I want to download this video http://observator.tv/sport/becali-se-uita-la-filme-coreene-82889.html
    I searched for its code. It is [http://storage2bp.aplay.ro/vod/_definst_/mp4:antena1/2012/02/08/K03RCM6Lz92.mp4/playli...r7eeZlWFed7A=]
    I used a .bat which was made here. Only replaced the link with the one above. It looks like this
    livestreamer --http-header "User-Agent=Mozilla/5.0 (iPhone; U; CPU iPhone OS 3_1_2 like Mac OS X; ko-kr) AppleWebKit/528.18 (KHTML,like Gecko) Version/4.0 Mobile/7D11 Safari/528.16" "hls://http://storage2bp.aplay.ro/vod/_definst_/mp4:antena1/2012/02/08/K03RCM6Lz92.mp4/playlist.m3u8?letokenstarttime=1453297802&letokenendtime=1453305002&letokensource=web&letokenhash=K6mgdp_x_6UxtyjcRyVjTDJ-2fUGvxYr7eeZlWFed7A=" best -o abc.ts
    But it doesn't work. It says it couldn't find the stream. Please help me!
    With thanks...
    Nov 2014
    Germany
    Originally Posted by Username2013 View Post
    Hi!
    With thanks...
    You can grab the video with following steps!
    user agent switcher /chrome mobile) > reloading the site > IDM > Code: http://storage2bp.aplay.ro/vod/_definst_/mp4:antena1/2012/02/08/K03RCM6Lz92.mp4/chunkl...mQlNZWT0=.m3u8 > FFmpeg with following code:
    ffmpeg -i http://storage2bp.aplay.ro/vod/_definst_/mp4:antena1/2012/02/08/K03RCM6Lz92.mp4/chunkl...mQlNZWT0=.m3u8 -c copy ab.ts
    Good luck,
    HJ
  18. Ghostrewel, thank you so much! It worked!!!!!
    Jan 2016
    New Zealand
    Hi there,
    Trying to save the direct stream link to my computer in m38u format if possible so I can run it on my wifes tablet (home sick missing her indian telly).
    The website I am trying to obtain the streams from is www.yupptv.com I am unable to obtain and save the stream to my computer. I have tried both RTMP/helper which doesn't pick up the stream and a FLV downloader software (I forget its exact name) however it does pick up the M38U URL when I try to save it to my computer it doesn't save to my machine and just sits there doing nothing. Wonder if they have some special secure feature on their stream?
    If anyone could help it would be really appreciated.
    I am trying to get the main channels on their website;
    In HD
    All Z channels
    All Sony channels
    All music channels
    All movie channels
    Star plus, Life ok, colors
    and a couple of the more popular new channels.
    Some of these streams also have proxy requirements aswell I know how to bypass in order to view them and I have tried on music india channel as no proxy required for this channel and I can get it to play no problems but not save the stream (have a subscribed account to the website).
    Cheers,
    Time
  20. Originally Posted by fracassato View Post
    I don't know because I can't try being outside of Ireland Someone suggested I try them. - The video is here: http://www.rte.ie/player/au/show/the-tommy-tiernan-show-tv-30003801/10510011/ (I only have until the 27th to see it)
    Can anyone please help?? Thank you so very much!
  23. Hi all,
    I need help to download this video
    http://globoplay.globo.com/v/4759930/
    Video won't load. I tried with different browsers but none works. (Opera, firefox and the other options that offers GetFLV)
    Thanks in advance.
  24. Could someone help me download the file here: http://en.musicplayon.com/play?v=362380
    Thank you for your kind help
  25. Member
    Nov 2014
    Germany
    Hi folks!
    I try to download a webcast from here:
    https://www.yahoo.com/music/livenation/event/saving-abel-2016
    I catched in the past a lot of these without any problems!
    It looks like some things are changing from Yahoo!
    Any help for catching these?
    HJ
  26. Member Emeritus
    May 2014
    Originally Posted by ghostrewel View Post
    Hi folks!
    hls
    https://yahoohls-live.secure.footprint.net/yahoohls/live/livenation2p/appleman_6128_60fps.m3u8
    https://yahoohls-live.secure.footprint.net/yahoohls/live/livenation2p/appleman_4628.m3u8
    or
    http://yahooios2-i.akamaihd.net/hls/live/224964/iosstream/livenation2p/master_6128_60fps.m3u8
    http://yahooios2-i.akamaihd.net/hls/live/224964/iosstream/livenation2p/master_4628.m3u8
  27. Member Alex_ander's Avatar
    Oct 2006
    Russian Federation
    Originally Posted by kurek View Post
    Hi all,
    Video won't load. I tried with different browsers but none works. (Opera, firefox and the other options that offers GetFLV).
    You can download all 235 .ts fragments using this single link (720p version) in DownThemAll Firefox plugin:
    https://vodstreaming03.video.globo.com/v2/0e/a6/22/4759930_2283bb4016e11fd796f4dabea1b...[1:235].ts
    Then join using command:
    copy /b *.ts video.ts
