Oh, thanks !!! It did work !!!
How did you manage to get that link ?
I'm on Linux.
Results 3,841 to 3,870 of 4610
i'm on Linux too (debian)
1) find the pid of the video in source page
in this case
2) open this linkCode:rel="video_src" href="http://media.mtvnservices.com/mgid:uma:videolist:mtv.it:1266580">
>>>>>>>Code:http://intl.esperanto.mtvi.com/www/xml/media/mediaGen.jhtml?uri=mgid:uma:video:mtv.it:1266580&acceptMethods=fms,hdn1,hds
Code:rtmpe://cp24806.edgefcs.net/ondemand/mtviestor/_!/intlod/MTVInternational/MBUS/TACTIC/201512/VIAMTVIPYC0985EDCV6/it_acapulcoshore2_23dicembre_LBC439857_1280x720_3500_h32.mp4
Code:http://a123.g.akamai.net/7/123/5290/v0001/mtviestor.download.akamai.com/8619/_!/intlod/MTVInternational/MBUS/TACTIC/201512/VIAMTVIPYC0985EDCV6/it_acapulcoshore2_23dicembre_LBC439857_1280x720_3500_h32.mp4
nota: i think your rtmpdump doesn't work because the version in Repositories on linux are too old you need compile it with patch
but not easy wayLast edited by biezom; 9th Jan 2016 at 17:38.
Ok, thanks.
I'm on Manjaro Linux and rtmpdump last update is dated 30-12-2015, guess it's already old ?
I'll try to build myself.
Thanks again.
EDIT: Just to be sure, this is the official repository ?
Code:git clone git://git.ffmpeg.org/rtmpdumpLast edited by fracassato; 9th Jan 2016 at 17:50.
yes and i use the KSV patch in this zip
but before try compile new version try this code because your playpath is wrong in your codeCode:https://github.com/K-S-V/Scripts/releases
Code:rtmpdump -r "rtmpe://cp24806.edgefcs.net:1935/ondemand" -a "ondemand?ovpfv=2.1.9-internal" -f "LNX 19,0,0,207" -W "http://media.mtvnservices.com/player/prime/mediaplayerprime.2.10.13.swf" -p "http://ondemand.mtv.it/serie-tv/acapulco-shore/s02/acapulco-shore-s02e00-promo" -C B:0 -y 'mp4:mtviestor/_!/intlod/MTVInternational/MBUS/TACTIC/201512/VIAMTVIPYC0985EDCV6/it_acapulcoshore2_23dicembre_LBC439857_1280x720_3500_h32.mp4' -o "it_acapulcoshore2_23dicembre_LBC439857_1280x720_3500_h32.mp4.flv"
This code works perfectly now.
For testing I run rtmpdump without overriding -a -f -W -C and it worked.
I run this code.
Code:rtmpdump -r "rtmpe://cp24806.edgefcs.net:1935/ondemand" -y 'mp4:mtviestor/_!/intlod/MTVInternational/MBUS/TACTIC/201512/VIAMTVIPYC0985EDCV6/it_acapulcoshore2_23dicembre_LBC439857_1280x720_3500_h32.mp4' -o "it_acapulcoshore2_23dicembre_LBC439857_1280x720_3500_h32.mp4.flv"
Now I'm sure, the error I made was here:
and It should be thisCode:-y "mp4:it_acapulcoshore2_23dicembre_LBC439857_1280x720_3500_h32.mp4"
just as you said.Code:-y 'mp4:mtviestor/_!/intlod/MTVInternational/MBUS/TACTIC/201512/VIAMTVIPYC0985EDCV6/it_acapulcoshore2_23dicembre_LBC439857_1280x720_3500_h32.mp4'
Thanks again.
Thanks, thanks, thanks. -
Hi All,
I'm new here but im stuck here for the below 4 links
Code:rtmpte://cp217686.edgefcs.net/ondemand/?auth=daEbVb2dvd9ajawbRbYaoccdbdmagbsdydz-bwKIWZ-bWG-KvvLk_wnvr_FAn&aifp=001&slist=1091/0_v679_vol679_001_VIDEO151208490580_7754335_1436000_640_360_11_20151208222435.mp4
Code:rtmpte://cp217686.edgefcs.net/ondemand/?auth=daEcmdabecddeb8cncKc2anaNaUbEcedpa4-bwKJ69-bWG-FxrJn_yqqs_GAo&aifp=001&slist=1091/0_v679_vol679_002_VIDEO151215924441_7810701_1436000_640_360_11_20151215204242.mp4
Code:rtmpte://cp217686.edgefcs.net/ondemand/?auth=daEb_d0d3b0aXbVdQddaJaYcCdba_bFcfcZ-bwKJ_p-bWG-GxtLo_xnvs_Hzp&aifp=001&slist=1091/0_v679_vol679-003_VIDEO151222258415_7882384_1436000_640_360_11_20151222224715.mp4
done via command prompt with the below:Code:rtmpte://cp217686.edgefcs.net/ondemand/?auth=daEbec_cSaVd8cjcpc3acaPawaXb5dkaIb3-bwKKak-bWG-HwuKn_Cqmt_GCo&aifp=001&slist=1091/0_v679_vol679_004_VIDEO151229826897_7911824_1436000_640_360_11_20151229192052.mp4
"C:\Users\rtmpdump.exe" -r "rtmpte://cp217686.edgefcs.net/ondemand/?auth=daEbtbadVcccCaZcnb2aNdjbvbVb5btamcJ-bwKLno-bWG-MvrLq_xpur_GAn&aifp=001&slist=1091/0_v679_vol679_004_VIDEO151229826897_7911824_143600 0_640_360_11_20151229192052.mp4" -o "C:\Users\video.mp4"
i had used rtmpdump version 2.4 and returned with the following:
Connecting ...
WARNING: HandShake: Type mismatch: client sent 6, server answered 8
INFO: Connected...
ERROR: Closing connection: NetStream.Play.Failed
i wonder if i can get some assistance here?
by the way, i got the rtmpte from the debug screen via firefox.
Thank you!!
Then that's why I couldn't get work. Is a restriced are, maybe works by IP.
I tried this command, try it you too.
Code:rtmpdump -r "rtmpte://cp217686.edgefcs.net/ondemand" -y 'mp4:auth=daEbVb2dvd9ajawbRbYaoccdbdmagbsdydz-bwKIWZ-bWG-KvvLk_wnvr_FAn&aifp=001&slist=1091/0_v679_vol679_001_VIDEO151208490580_7754335_1436000_640_360_11_20151208222435.mp4' -o "file.mp4"
hello! thank you so much for the reply!
i tried the above code and i got the below:
INFO: Connected...
ERROR: rtmp server sent error
ERROR: rtmp server requested close
'aifp' is not recognized as an internal or external command, operable program or batch file.
'slist' is not recognized as an internal or external command, operable program or batch file.
hmmm, or can i provide u with the id and password for logon? i dont mind providing you that actually. just let me know and i'll pm u the login requirement
i tried logging in the page again and start the cmd again
with a long string of messages,
The filename, directory name, or volume label syntax is incorrect.
INFO: Connected...
'KvvLk_wnvr_FAn' is not recognized as an internal or external command, operable program or batch file.
'slist' is not recognized as an internal or external command, operable program or batch file.Last edited by haruharu; 11th Jan 2016 at 05:36.
Try to use "" ( double quotes ) instead of '' ( single quotes ) on -y option.
Otherwise escape both & character with \
When the command line complains about commands not recognized it's because there are special shell characters not escaped.
Maybe you are on windows because i didn't have those errors. -
yes u r correct, im on windows....
tried with the amendments of single quote for double quote and i get lesser error with just
INFO: Connected...
still no results.... -
Try this
Code:rtmpdump -r "rtmpte://cp217686.edgefcs.net/ondemand" -u "daEbVb2dvd9ajawbRbYaoccdbdmagbsdydz-bwKIWZ-bWG-KvvLk_wnvr_FAn&aifp=001&slist=1091" -y "mp4:0_v679_vol679_001_VIDEO151208490580_7754335_1436000_640_360_11_20151208222435.mp4" -o "file.mp4"
hey pal,
thank you so much for your quick response!
tried the new code u provided and returned with the same message of
NOOOOO!!!!! my time limit to retrieve this file is within the next 28 hours -
Sorry to not be able to get it work.
It is certainly a problem with restricted access and limited download/visit per day... -
thanx friend!
sincerely appreciate so much for your kind assistance for the file
u dont have no apologize, it's not your fault.
i only noticed that the rtmpe file link sort of changed each time i click, so i sort of changed to the correct link with what you provided and the file does not turn up.
and then, seems like i have to be logged in in order to get lesser error... somehow?? -
At the end of the output, rtmpdump says this:
Code:If you don't pass parameters for swfUrl, pageUrl, or auth these properties will not be included in the connect packet.
I think that these options are mandatory when you have to deal with files protected by restricted access and limit of visits like your case. -
yea, the login issue was the biggest reason keeping you out from the information you needed...
dont know if this helps...
minbit=
type=1
eid=vol679%5F001
did=1091
vid=VIDEO151208490580
rnd=8189
pid=4206
maxbit=
host: www2.uliza.jp
Referer: "https://aka-secure-img.uliza.jp/Player/player.swf?d=20150901"
{"TITLE":"vol679_001","IMAGE_BEFORE_STREAM":"","IMAGE_THUMNAIL":"","IMAGE_BANNER":"","FACEBOOK_TXT":"","TWITTER_TXT":"","LIVEDOOR_TXT":"","DELICIOUSE_TXT":"","GOOGLE_TXT":"","YAHOO_TXT":"","DESCRIPTION":"","NETWORK_ID":"3999","NET_CONN":"rtmpte://cp217686.edgefcs.net/ondemand/?auth=daEaQd5c0aNdWdJa.bZb0bLbiaic8dkaNcb-bwK451-bWG-FxyKl_Equu_Ezn&aifp=001&slist=1091/0_v679_vol679_001_VIDEO151208490580_7754335_143600 0_640_360_11_20151208222435.mp4","USEBEACON_FLAG":"0","BEACONRECEIVE_URL":"http://www2.uliza.jp/api/log/set_playlog.aspx","BEACONPING_INTERVAL_SEC":"3","BEACON_TYPE":"0","LINK_URL":"","LINK_TEXT":"","PLAYLIST":[{"NAME":"0_v679_vol679_001_VIDEO151208490580_7754335_143600 0_640_360_11_20151208222435.mp4","START":"0","LEN":"90","RESET":"false","LOG_PARAMS":"di=1091&pi=4206&ec=vol679_001&vc=VIDEO151208490580&si=824&gi=7446&gc=3&bi=153963&bc=v679&ei=1505788&vi=7562402&msi=720&sl=0"}],"SITE_ID":"824","SITE_URL":"*.shinoyama.net,*.visualweb.youngsunday.com,*.sabr a.jp,sabra.jp,*.payon.svc.ocn.ne.jp,payon.svc.ocn. ne.jp,*.contents.nifty.com,contents.nifty.com","GENRE_ID":"7446","GENRE_CODE":"3","PROGRAM_ID":"153963","PROGRAM_CODE":"v679","EPISODE_ID":"1505788","VIDEO_ID":"7562402","MEMBER_SITE_ID":"720","VIDEO_CLICK_URL":"","CDNID":"6","STORAGESUBDIR":"1091","KEY":"","STIME":"1452510837.1845","USERID":"","BANDWIDTH":"1650000","SHOW_LITTLE_FLAG":"0","SHOW_LITTLE_START_TIME":"0","SHOW_LITTLE_END_TIME":"0","DYNAMIC_STREAMING":[],"LIVE_STREAMING":[],"CHAPTER":[]}
this site must be really good to keep their files unaccessible...
but then.. i did saw the videos of similar ones from the same site up some time ago thou... -
I can't look it now, i have a lesson at college in a moment.
I'll try it this evening. -
Try this but It doesn't work for me.
Code:rtmpdump -r "rtmpte://cp217686.edgefcs.net/ondemand" -s "https://aka-secure-img.uliza.jp/Player/player.swf" -p "www2.uliza.jp" -u "daEaQd5c0aNdWdJa.bZb0bLbiaic8dkaNcb-bwK451-bWG-FxyKl_Equu_Ezn&aifp=001&slist=1091" -y "mp4:0_v679_vol679_001_VIDEO151208490580_7754335_1436000_640_360_11_20151208222435.mp4" -o "file.mp4"
hello! thanx for the try! it doesnt work too... there's another smartphone link for the site too, which gave a different url
http://www2.uliza.jp/IF/iphone/iPhonePlaylist.m3u8?v=VIDEO151208820478&p=4207&d=1091&n=4475&cpv=1 -
Hello. I have a big problem. I need to download videos from a website. There are two kinds of video links:
FIRST LINK TYPE (I can successfully download these videos):
http://hdodhttp-f.akamaihd.net/2015/11/08/MotoGP_2015_VAL_RACE-IPF_MIX-,LW,ST,HR,HD,.mp4.csmil/bitrate=1?primaryToken=1453158914_90b338cfb2db7174 cd46069fbba5ba4f&v=3.4.0&fp=WIN%2020,0,0,267&r=IXHML&g=GCFGLFNPGQPG
I use this code with IDM to download these videos: :
rtmp://cp88659.edgefcs.net/ondemand/mp4:motogp/2015/11/08/MotoGP_2015_VAL_RACE-IPF_MIX-HD.mp4
PROBLEMATIC LINK TYPE (I can't download):
http://hdodhttp_o-f.akamaihd.net/2012/05/30/2009_13_RSM_MGP_RACE_IF_Mixed_forSD_,ST,HR,_clean. mp4.csmil/bitrate=1?primaryToken=1453159089_b1d10245a18cf850 0c8b2cd5892474a2&v=3.4.0&fp=WIN%2020,0,0,267&r=SMNOW&g=XURWORAIKUKH
I don't know what code to use to download this. Looks like the problem is the "_o"
Perhaps I need to change this part of the codeThe only way I can download these videos (with _o) is with replay media catcher, but I can only download the low definition video.Code:cp88659.edgefcs.net/ondemand/mp4:motogp
I've been looking to find a way for over a year.
Please, I'm really begging for your help, I'm in your hands -
Hey, can anyone help me? I'm going around in circles trying to ungeoblock myself! I will gladly give any shots a go because I have run out of ideas
I need to be in Ireland, the video isn't going to be on for too much longer, kind of desperate here lol
http://www.rte.ie/player/ie/show/the-tommy-tiernan-show-tv-30003801/10510011
You try with ffmpeg
https://trac.ffmpeg.org/wiki/Concatenate -
I think this is a YouTube video and If I am right, you can easily download it with youtube-dl.
It's a command line tool, just download and parse this command on the shell
Code:youtube-dl VIDEO-URL ( VIDEO-URL is an example, paste the real youtube video url, which is the WEB page URL, and NOT the link you provide above )
How to download a rtmp stream from a website
By krb214 in forum Video Streaming DownloadingReplies: 2Last Post: 26th Jul 2011, 19:08 -
Need some advice on how to download certain rtmp streams
By aveceux in forum Video Streaming DownloadingReplies: 3Last Post: 13th Jun 2011, 09:45 -
Free DivX Pro Software Download
By MJA in forum Video ConversionReplies: 11Last Post: 18th Dec 2010, 08:21 -
RTMP Flash file help?
By xiaofan in forum Newbie / General discussionsReplies: 0Last Post: 3rd Jun 2007, 09:16
