Page 123 of 154
FirstFirst ... 23 73 113 121 122 123 124 125 133 ... LastLast
Results 3,661 to 3,690 of 4610
  1. Originally Posted by ghostrewel View Post
    Hi folks!
    Hope someone could help me again to download following:
    http://www.rtve.es/m/alacarta/videos/festivales-de-verano-de-la-2/18-festival-jazz-san...658/?media=tve
    Greetings,
    HJ
    hi
    mp4 with token
    to have token need spain ip
    you can use ola addon on firefox
    http://flash.akamaihd.multimedia.cdn.rtve.es/auth/resources/TE_GLESP/mp4/3/2/1441260206923.mp4?v=&fp=&r=&g=
    then you can use livestreamer or youtube-dl (no need spain ip)
    livestreamer  "httpstream://http://s01vod.akcdn.rtve.es/resources/TE_GLESP/mp4/3/2/1441260206923.mp4?primaryToken=1441308493_294ab9d21831986a6e9b950736a1ee9f&v=&fp=&r=&g=" best -o video.mp4
    with in red code find with http://flash.akamaihd.multimedia.cdn.rtve.es/auth..........
  2. Hi, does anyone know how to get the highest quality streams from Brightcove - nothing I've found so far works, and I'm not seeing any rtmp or mp4 or m3u8 in the urls that I capture.
  3. Originally Posted by dvdboy View Post
    can you post an example URL page?
  4. Originally Posted by Baldrick View Post
    If you have problem downloading streaming flash video using simple tools like Video DownloadHelper, Orbit Downloader, VDownloader, etc then it try this method. It might not work with all flash video streams though.
    Tools required:
    URL Snooper
    RTMPDump(also called FLVStreamer)
    Guide:
    Start URL Snooper and under General Options click Auto Determine Network Adapter Now or choose the Network manually.
    Under Search and at the bottom paste the url to your video page and press Download. Then search for RTMP or RTMPE under the protocol tab, right click on it and choose Copy selected URL(Strip all args). If you don't find any RTMP streams then first start play the video in your browser and try click on Sniff Network and wait until you see a RTMP link.
    After you copied the url we use the command line tool RTMPDump. Download it to for example C:\temp and then start the Command Prompt(Start->Program->Accessories->Command Prompt) and in the command line type
    "C:\temp\rtmpdump.exe" -r "rtmpe://fl11.c90909.cdn.qbrick.com/90909/_definst_/kluster/20091027/geose_PG-1131239-010A-TRUEBLOOD1" -o "c:\temp\video.flv"
    and replace the "rtpme://"-stream with the one you copied from URLSnooper. Right click in the command prompt to Paste.
    It should like,
    and if it works RTMPDump will start download the file,
    Done!
    Last play the video.flv with VLC or MPCHC.
    How i can downloaded this video (Option 2) http://cuevana-latino.com/k-pax/
  5. Originally Posted by biezom View Post
    Unfortunately not...
    Do Brightcove had different 'implementations'?
  6. Help me download video
    http://gotv.tvb.com/programme/102263/146986
    Thanks you all very much
  7. I've been trying to figure out disneymoviesanywhere. There's a "discover" section that's free and I can't seem to figure out how to grab some of the videos. Anyone able to help?
    For example...
    https://www.disneymoviesanywhere.com/#watchBonus-494584899964
  8. Pleas help me how to download from with 1080p: http://tvcast.naver.com/v/519492
    Thank you so much~~
  9. Originally Posted by lolli12 View Post
    Thank you so much~~
    hi you can find direct link
    tools: firefox; adblockplus addon
  10. Hi again
    Can you help me getting this stream?
    http://www.bbc.co.uk/iplayer/episode/p030s9rt/radio-1-live-sessions-bring-me-the-horizon
    I tried everything that I learn here before but now it seems to doesn't work anymore.
    Please help. Thanks in advanced!
  11. Any help guys, please?
    Nov 2014
    Germany
    Hi John!
    You must using a VPN Proxy,look here:
    http://www.bestukvpn.com/
    after that start the stream and grabbed the infos with HDS Link Detector(Mozilla Firefox Addon)
    then copy that in the Adobe HDS Script and put enter...
    Good luck!
  13. Thank you very much man, that worked very well!
    Nov 2014
    Germany
    Hi Folks!
    How I can find out the rtmp Link for following:
    http://concert.arte.tv/de/lollapalooza-berlin-2015-livestream-vom-1309
    Greetings,
    HJ
  15. Originally Posted by ghostrewel View Post
    Hi Folks!
    Greetings,
    HJ
    you can find with rtmpdumphelper
    rtmpdump -v -r "rtmp://arte.fc.llnwd.net/arte/alw-main-stream-1" -o concert.flv
  16. nvm
    Jul 2014
    Australia
    Can someone please tell me how do download this:
    http://www.oln.ca/shows/illusions-of-grandeur/?video=4253464793001
    I prefer if you could teach me instead of just providing the link. Thank you!
  18. I want to download first audio file "The Basics About Big Data" from the link
    What would be the direct download link?
    i could reach to
    https://api.soundcloud.com/tracks/152671918
    but became headless chicken hereafter
    Can someone please help me?
  19. Originally Posted by manojpatil View Post
    i could reach to
    hi
    video downloadhelper addons on firefox works with this site
  20. How about this one?
    I've tried JAKSTA, and it did find the file, but it couldn't download.
    http://www.amauryjr.com.br/iVideo.asp?id=7170
    Through JAKSTA It points to a MP4 file hosted at netpoint.com.br, a streaming provider.
    Any ideas?
  21. Hey guys,
    I was trying to get this stream, but it`s stops every 4 mins +-
    http://multishow.globo.com/especiais/rock-in-rio/#v=2767789
    I think I`m doing something wrong,
    Thanks in advanced!
  22. Originally Posted by leosarma View Post
    How about this one?
    Any ideas?
    rtmpdump -v -r "rtmp://wowza.netpoint.com.br/amauryjr_od/" -a "amauryjr_od/" -f "LNX 17,0,0,134" -W "http://www.amauryjr.com.br/files/js/jw6/jwplayer.flash.swf" -p "http://www.amauryjr.com.br/iVideo.asp?id=7170" -y "mp4:hdamauryjr3321bl1h.mp4" -o "mp4_hdamauryjr3321bl1h.flv"
  23. Member
    Nov 2014
    Germany
    Hi friends!
    Need another time some help!
    I want to record following:
    https://www.youtube.com/watch?v=aHORTJPXWac
    Try to find the m3u8 link,but no success...
    Hope someone could help me out how to grab the performance!
    Greetings,
    HJ
  24. Originally Posted by ghostrewel View Post
    Hi friends!
    Greetings,
    HJ
    to find m3u8 link
    youtube-dl -g "https://www.youtube.com/watch?v=aHORTJPXWac"
    you can use youtube-dl with ffmpeg in the same folder
    youtube-dl  "https://www.youtube.com/watch?v=aHORTJPXWac"
  25. Originally Posted by john.scofield View Post
    Hey guys,
    Thanks in advanced!
    tools: firefox; adblockplus addon, livestreamer
    livestreamer  "hlsvariant://http://live.hls.globo.com/dvr/public/msw1a/master-playlist.m3u8?h=04114426977817992745808144270127135988564240CnO5N2yKE9Sgk2gPTLLHQ&k=html5&a=A&u=" best -o video.ts
    in red m3u8 link found with adblock plus
  26. Originally Posted by biezom View Post
    i could reach to
    hi
    Thanks for your quick response.
    Actually i tried with Download Helper but it simply says "No media to process"! i am going with defauly settings and confirmed that extensions like mp3, flv are already included. But still not able to download ...
  27. Originally Posted by manojpatil View Post
    i could reach to
    hi
    other way
    tools: firefox; adblock plus addon; youtube-dl
    youtube-dl "https://cf-media.sndcdn.com/ClRYhUL3uW0A.128.mp3?Policy=eyJTdGF0ZW1lbnQiOlt7IlJlc291cmNlIjoiKjovL2NmLW1lZGlhLnNuZGNkbi5jb20vQ2xSWWhVTDN1VzBBLjEyOC5tcDMiLCJDb25kaXRpb24iOnsiRGF0ZUxlc3NUaGFuIjp7IkFXUzpFcG9jaFRpbWUiOjE0NDI4MjI4OTR9fX1dfQ__&Signature=Js7nK1tkxTnA4oQcPF-GMS2KPvqJ7wtowaWBR4nKTOPRYgCzJc9GmjHRPxuexjcfWWHBAqWSSqUeazVJljzuGqiMCxy38UBibvrrBibMJsm6xpbZnI3aI5CtnNoZ9MB7S0BD4FjvkK4e9T6KgJtOGkhmcNz0MiVSL62Dcf00e4pKChFZwkb162WiuoCwmvRR4Icpq1jYyi4ME~HKb0xo1sNww5YFmdan2wnf4JOALdOqmzp5UIEM2TvDGQKOQ6pMi1q8HXwykGAg0m6k7riIqHWfOjBHMY-vZUnDvWeO0l-bjwLtVDR3YHhQwdEdiO6yvmpv7LoTb93SDOEOIk1KMQ__&Key-Pair-Id=APKAJAGZ7VMH2PFPW6UQ"
    [generic] ClRYhUL3uW0A.128: Requesting header
    [download] Destination: ClRYhUL3uW0A.128-ClRYhUL3uW0A.128.mp3
    [download] 100% of 14.74MiB in 00:37
    whit in red the link found with adblockplus addon
  28. Member
    Feb 2006
    Hey guys,
    Thanks in advanced!
    Does livestreamer have to be .ts? Can it be .flv instead or does that need conversion
  29. Originally Posted by imdaman View Post
    mp4
    ffmpeg -i "http://live.hls.globo.com/dvr/public/msw1a/master-playlist.m3u8?h=04114426977817992745808144270127135988564240CnO5N2yKE9Sgk2gPTLLHQ&k=html5&a=A&u=" -bsf:a aac_adtstoasc -c copy video.mp4
