Results 3,361 to 3,390 of 4610
Hi folks!
I want to download under following link the fuel set from Noel Gallghers pwerformance at the Philipshalle DSüsseldorf in the best quality:
http://www.rai.it/dl/portali/site/articolo/ContentItem-f8aea919-61f0-4089-88ee-e7af975a717d.html
I could download only a 404 p file,is it correct?
Greetings,
HJ -
Hi!
Could someone post the way to find the links for these:
Thanks in advance,
HJ -
Anonymous84347344Guest
YOUTUBE-DL:
Code:youtube-dl -g "http://www.laola1.tv/en-int/video/final-zenit-kazan-asseco-resovia-rzeszow/312727.html"
Code:http://hdsvodsportsman-vh.akamaihd.net/z/p-22_u-0_l-cev_a-volleyball_cev_cl_men_c-US_e-312727_i-92236934_k-0_q-_t-hdvideo/hdflash/2015/volleyball/CEV_CL/150329_zenitkazan_rzeszow_int_,low,medium,regular,high,premium,.mp4.csmil/manifest.f4m?hdnea=exp=1428151207~acl=*~hmac=d115e8ca6d001d31e66c608e5961d8c76a9828a0bb77267a4c63bdc1d4c7a3ef&hdcore=3.2.0
Code:youtube-dl "http://www.laola1.tv/en-int/video/final-zenit-kazan-asseco-resovia-rzeszow/312727.html"
Code:[Laola1Tv] 312727: Downloading webpage [Laola1Tv] 312727: Downloading iframe [Laola1Tv] 312727: Downloading XML [Laola1Tv] 312727: Downloading token [download] Downloading f4m manifest
Hi all.
Can someone help me grab the video on this link :
http://www.wattsatelier.com/project/drapery-phase-i/
It would be greatly appreciated.
Thanks ! -
hey guys,
I want to capture/dl a live stream which is located at https://screen.yahoo.com/live/event/at-the-gates
Since it is a live broadcast I would suggest that ffdshow is the right thing to do it?
Any help with the command which would work for this would be much appreciated.
Thanks a lot
regards -
Hi, i've fixed my yahoo live script and you can use it in adownloader. To get the stream i use vlc to watch meantime the video and save it. To stop the downloading simply close vlc.
Tested https://screen.yahoo.com/live/event/clean-bandit. -
hmm it doesn't work. My vlc player always says that he can't open the stream. No matter if I use
https://yahoo-live.hs.llnwd.net/livenation1p.m3u8
or
http://yahooios-i.akamaihd.net/hls/live/202861/tristudios/livenation1p/master.m3u8
Any help with a working batch file would be much appreciated since the show will start in a few hours.
thanks in advance
regards
-Gwar -
Need help to find a fixed URL for this site.
Player: http://livestream.com/accounts/5043608/events/2323628/player
The info keeps changing. I keep finding new URLs that work but are only for limited play and then expire, such as these:
http://livestream-f.akamaihd.net/5043608_2323628_a16edd82_1_2320@136690?v=3.6.0&fp=WIN 12,0,0,43&r=IARWB&g=XNJUUHBTMSUS
http://livestream-f.akamaihd.net/5043608_2323628_8172c88f_1_2320@136690?v=3.6.0&fp=WIN 12,0,0,43&r=NFWIR&g=LERVUHUYTOMR
I do not understand how to convert to a valid, fixed URL.
If anyone has time to point to a solution it would be greatly appreciated. -
These links are for Clean Bandit stream. Anyway they work with adownloader directly. You can put the url
or directly the m3u8. -
Hi there. I registered just to try to get this working.
I am trying to archive some videos from a class I am taking. They are streaming using RTMPE. My download command will start the download, but then silently stop downloading anything around 30 seconds. The file gets larger, but no new data accumulates. I tried using the resume switch with rtmpdump but that didn't work either.
I tried using RTMPDumpHelper's automatic capture thing and that works, but it seems to only capture in real-time-ish, so to download hours of video I'll need to spend hours watching the videos.
Here's an example command line I'm using:
rtmpdump -r "rtmpe://steaming.sscnet./4556" -a "4556" -f "WIN 17,0,0,134" -W "https://moodle2. /filter/sscwowza/jwplayer/SecureToken.swf" -p "https://moodle2. /mod/page/view.php?id=141376" -y "mp4:U2v1_What_is_GIS.mp4"
Unfortunately the page this video is on is protected by an authentication page, so I can't give much more info than this. Let me know if some HTML source from the page would help.
The site seems to be using "Wowza Streaming Engine 4 Perpetual Edition 4.1.0 build12602" to stream, if that helps anyone.
Further putzing around and I found a playlist file:
Code:#EXTM3U #EXT-X-VERSION:3 #EXT-X-STREAM-INF:PROGRAM-ID=1,BANDWIDTH=207493,CODECS="avc1.66.30,mp4a.40.2",RESOLUTION=640x480 chunklist_w359730289.m3u8
Code:#EXTM3U #EXT-X-VERSION:3 #EXT-X-TARGETDURATION:10 #EXT-X-MEDIA-SEQUENCE:0 #EXTINF:10.0, media_w359730289_0.ts #EXTINF:10.0, media_w359730289_1.ts #EXTINF:10.0, media_w359730289_2.ts #EXTINF:10.0, media_w359730289_3.ts #EXTINF:10.0, media_w359730289_4.ts #EXTINF:10.0, media_w359730289_5.ts #EXTINF:10.0, media_w359730289_6.ts #EXTINF:10.0, media_w359730289_7.ts #EXTINF:10.0, media_w359730289_8.ts #EXTINF:10.0, media_w359730289_9.ts #EXTINF:10.0, media_w359730289_10.ts #EXTINF:10.0, media_w359730289_11.ts #EXTINF:10.0, media_w359730289_12.ts #EXTINF:10.0, media_w359730289_13.ts #EXTINF:10.0, media_w359730289_14.ts #EXTINF:10.0, media_w359730289_15.ts #EXTINF:10.0, media_w359730289_16.ts #EXTINF:10.0, media_w359730289_17.ts #EXTINF:10.0, media_w359730289_18.ts ... (etc. up to 91 files) #EXT-X-ENDLIST
http://streaming/4556/mp4:U2v1_What_is_GIS.mp4/media_w359730289_0.ts
Any way I can take advantage of this and automate a download and merge process for all 91 files?Last edited by throwaway_rtmp; 6th Apr 2015 at 23:48. Reason: Removed domain to protect search engine results.
It really worked with ffdshow this time using this command
ffmpeg -i "http://yahooios-i.akamaihd.net/hls/live/202861/tristudios/livenation2p/master.m3u8" -c copy atg.ts
So it seems that ffmpeg can't capture the stream as a whole and always missed parts and therefore the capture isn't really usable.
Some messages ffdshow gives me during the capture is "skipping 3 segments ahead expired from playlists " Maybe that's a problem?
Any further help would be appreciated. Thanks a lotLast edited by Gwar; 7th Apr 2015 at 11:14.
Hi folks!
here the correct link for downloading the highest available source with FFmpeg:
ffmpeg -i https://yahoo-live.hs.llnwd.net/livenation2p_6128.m3u8 -c copy at.ts
Good luck!!! -
please can anybody help me download this video on channel4.com
http://www.channel4.com/programmes/food-unwrapped/on-demand/54294-001
i tried idm, rtmexplorer,cooljah,mediabox,streamtransport,nettransport nothing worked can any body download it and show it how it can be done i will be very happy i am newbee no coding do i know of, but anything that can download this series videos glad for reading me..... -
i want it bad screenshots of download and or coding ,much appreciated , please please please please
how to download it howt to download it i broke my back for fifteen days trying to even get glimpse of it is 11 seconds of video after 4 to 5 advertisements
please please -
getFLV,VDownloader, tried latest version of rtmpdump 2013 12 22 but it they wont work
help me to download this video series this video first
please please please i will be eternally gratefull ............ -
Hi guys,
I have problems with downloading video from Slovenian site: VOYO.SI
I have used "GETflv", but this program has a problem with downloading largest videos (1h 30min)
Here is RTMP link (URL copy from GETflv)
TCURL: rtmpe://voyood01fs.fplive.net:1935/voyood01?auth=ZXhwaXJlczoxNDI4NTI5MjcwfHZpc2l0b3Jf aWQ6MTExODMyNHx2aXNpdG9yX2lwOjg5LjE0Mi4xMTQuMTN8cH JvZHVjdF9pZDpwb3BwbHVzfG1lZGlhX2lkOjYxNTY0MzQyfG1l ZGlhX2dlb2xvY2s6U0l8bWVkaWFfZmlsZW5hbWU6YzdlZGI1MW Y3ZF82MTU2NDM0MnxtZWRpYV9wdWJsaXNoZWRfZnJvbToxNDI1 MTY0NDYwfG1lZGlhX3B1Ymxpc2hlZF90bzoxNTE5OTQ1MTM5fG RybV9wcm90ZWN0ZWQ6MXxyZWFsX3Zpc2l0b3JfaXA6ODkuMTQy LjExNC4xM3xmODQ3MDI2NzcyODEwN2JhNDQ0OWVjNTczZmI4Y2 NmYw==
FLVName: mp4:/p/2015/02/24/c7edb51f7d_61564342-3.mp4?auth=ZXhwaXJlczoxNDI4NTI5MjcwfHZpc2l0b3JfaWQ6MTEx ODMyNHx2aXNpdG9yX2lwOjg5LjE0Mi4xMTQuMTN8cHJvZHVjdF 9pZDpwb3BwbHVzfG1lZGlhX2lkOjYxNTY0MzQyfG1lZGlhX2dl b2xvY2s6U0l8bWVkaWFfZmlsZW5hbWU6YzdlZGI1MWY3ZF82MT U2NDM0MnxtZWRpYV9wdWJsaXNoZWRfZnJvbToxNDI1MTY0NDYw fG1lZGlhX3B1Ymxpc2hlZF90bzoxNTE5OTQ1MTM5fGRybV9wcm 90ZWN0ZWQ6MXxyZWFsX3Zpc2l0b3JfaXA6ODkuMTQyLjExNC4x M3xmODQ3MDI2NzcyODEwN2JhNDQ0OWVjNTczZmI4Y2NmYw==
Okay ... server link from HTML5FALLBACK is
vid01.24ur.com, but there is a problem when I join server link + mp4 file name
here is link which doesn't work (it says --- "unavaliable in your country"
http://vid01.24ur.com/2015/02/24/c7edb51f7d_61564342-3.mp4
If you need some other information about video, please let me know.
Please help me, THANK YOU! -
How to download a rtmp stream from a website
By krb214 in forum Video Streaming DownloadingReplies: 2Last Post: 26th Jul 2011, 18:08 -
Need some advice on how to download certain rtmp streams
By aveceux in forum Video Streaming DownloadingReplies: 3Last Post: 13th Jun 2011, 08:45 -
Free DivX Pro Software Download
By MJA in forum Video ConversionReplies: 11Last Post: 18th Dec 2010, 07:21 -
RTMP Flash file help?
By xiaofan in forum Newbie / General discussionsReplies: 0Last Post: 3rd Jun 2007, 08:16
