    Jun 2009
    OK using vd and so far ok fixing b and w movies but wondering where i get the plugs to fix color problems , lighten / darker / contast using AVI format then to convert X then burn, so is their a pug in list for color i can choose from -
    thanks a bunch . .
  2. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    In VirtualDub, on the Video menu, see Filters, then Add to see the installed plugins. There are several default ones that adjust colour.
    You'll find more at :
    http://neuron2.net/
    http://www.thedeemon.com/VirtualDubFilters/
    http://compression.ru/video/index.htm
  3. You'll also want ColorMill and Gradations. You should be able to find them at the above links.
