This is the first time this happened to me: an audio track going completely out sync with the video track when demuxed from MKV file.
If played as is, the MKV file is fine. But when I demux it, the video ends up with 01h.56m.33s and the audio track with 02h.01m.31s. A complete mystery.
The program used was MKVextract GUI. What is happening?
Results 1 to 12 of 12
But you are posting in the Blu-ray ripping section...moving you...
Sorry.
I searched where questions similars to mine were posted, and I thought the place was in Blu-Ray section. -
In fact I did try it in its latest version, but I am not sure if it's working because it opens HCenc but it doesn't fill in the data.Originally Posted by Baldrick
In any case I am doing all these conversions with avisynth now, controlling more variables than AVStoDVD allows to. Particularly audio levels and subtitles. -
Test 1: failed
Right now I tried a different approach: adjusting the audio track length to the video length.
The program I used is Audioscale GUI, but I don't know why the program doesn't seem to be working.
Is there a program similar to Audioscale that I can use to adjust an audio length very precisely?
Test 2: failed
Now I tried doing a negative time stretch with Soundforge. As I have the exact video timing, what I did was load that time as the stretch target.
It got me closer, but it gets out of sync increasingly as I get to the end. I wonder if there's a more precise method for this than trial and error. -
Test 3: worked
This time what I did was down stretch the audio track time to video track time using Soundforge.
There was some out sync yet, which checking with TMPGEnc seemed to be around 7 frames. New correction with Soundforge from original file.
Authored the files with DVDLabPro, and there was a final correction of 100ms that seemed to put things back in sync.
Still not too satisfied, as I am not sure if the stretching shouldn't be more precise, but I don't seem to know how to compute that precisely. -
How are you? Thanks for commenting over this.Originally Posted by _MrC_
What I meant is that it opens the HCenc screen and it stays there, not filling in the numbers as I think it should. Then starting the conversion. In this case it didn't, at least during the time I waited. Maybe I should wait longer and see what happens.
Now it's been some time that I don't use AVStoDVD for a conversion, as I prefer the more control I can get with avisynth writing my own scripts. But as you see I still go back to it if necessary, particularly to check things I can't understand.
Your tool is VERY powerful, and I do recommend it around a lot, as I think it's the more transparent I could find. Particularly because it uses avisynth.
MKV files.... audio out of sync. What is......
By forest.lawn in forum Newbie / General discussionsReplies: 6Last Post: 11th Oct 2010, 12:04 -
Demuxed Audio is longer than Demuxed Video, help!
By caesarhawy in forum EditingReplies: 3Last Post: 26th Apr 2010, 05:18 -
Why video and audio out of sync while playing .mp4 and .mkv files?
By Bonie81 in forum Software PlayingReplies: 0Last Post: 6th Apr 2010, 19:03 -
StaxRip audio sync problem creating MKV files
By ejai in forum DVD RippingReplies: 0Last Post: 24th Apr 2009, 16:16 -
(MKV) Audio/Video synching problems after remuxing the same files I demuxed
By Sigma X Virus in forum Newbie / General discussionsReplies: 3Last Post: 9th Feb 2009, 17:27
