So a lot of you guys have probably seen the show "All that" at some point or another.
But I am in a broadcast class for my school, and it is kinda like that show, we have announcements, but the rest of the time (we get 10 minutes every other day) we can do funny skits.
But we have an intro to the show, and every so often we need to change it.
We wanted to kind of recreate the intro they use in all that:
http://www.youtube.com/watch?v=kipmGJCVnYM
One thing I'm not sure how to do is if you watch it, they have the video kinda wobble, like wave almost. I think I know how it's done, but I'm not positive.
How do you guys think I can recreate this?
Results 1 to 12 of 12
All I see wobbling is the text -- and that's because it's animated and drawn that way.
I think he's talking about the waving effect 15 seconds into the video. As guns1inger noted, most advanced editors have that type of effect built in. You may have to tweak it to get exactly what you want. Look for 2D or 3D motion or distortion filters.
Well, would FCP or adobe premire CS4 have it built in? I assume After Effects does as well, because I have those programs.
Look under "Distort" for filters. e.g turbulent displace , or wave warp. Just play with the settings
With after effects , there are a lot of filters that could do something similar. Just play with them until you're happy. A very powerful / customizable one is displacement mapping which is similar to photoshop's filter, but for video.
Search google as there are 100's of tutorials on this subject -
What should I search google for? video distortion?
Sorry if I sound completely helpless haha I'm not very unfamiliar with some more of these intricate filters and effects. -
If you want the most control, I would use displacement mapping. It sounds it might be too advanced for you right now but there are very basic tutorials out there. Search for terms like displacement mapping, after effects etc...
If you want easier to use, just use one of the built in filters. In AE it would be effects=>distort. In premiere its under distort. Try turbulent displace for starters. It's probably going to easier to fiddle with it, than to look up and watch some tutorials. You can also look up the effects in the pdf help file
EDIT: we posted at the same time but it looks like you figured it out
Cheers
Is there a program to edit HDDVD like Clown_BD can edit Blu-ray?
By c627627 in forum Authoring (Blu-ray)Replies: 0Last Post: 3rd Jan 2011, 23:35 -
Why does the video I edit in Cyberlink look darker after I edit it and post
By Chubby Johnson in forum Newbie / General discussionsReplies: 1Last Post: 30th Jun 2010, 05:08 -
Edit, add, extract WAVE and edit file tags with new Machete 3.5
By MacheteSoft in forum Latest Video NewsReplies: 0Last Post: 23rd Dec 2009, 10:05 -
Can`t use edit mesh, edit, poly and many more at autodesk
By k4z0 in forum EditingReplies: 2Last Post: 3rd Jul 2009, 06:38 -
need help in choosing a format after video edit (DV then edit then DVD)
By shade_2 in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2008, 13:13
