On sites like Youtube it frequently askeds to install Adobe flash, to view videos but even after installing it, I show a red x (or unable to play video). Is there something wrong or do I have to somehow "turn it on"?
Do you have Javascript disabled in your browser? If you're using Firefox with NoScript, for example, it'll automatically block (or try to) JavaScript and Flash unless you whitelist the site.
If cameras add ten pounds, why would people want to eat them? -
I am using IE8. Firefox works, but IE8 doesnt.
"Disable script debugging (Internet Explorer)" is CHECKED. Is that it? -
As far as I know, it isn't. Unfortunately, I don't use IE, so I don't really know how to disable/re-enable Javascript in IE.
You did make sure to install the IE-specific version of Flash 10, right?
Do you have Quicktime installed? QT seemed intent on grabbing the MIME-type and such for Flash/FLV as well, before.If cameras add ten pounds, why would people want to eat them?
Copy text from website but right click is disabled and JavaScript needed
By coody in forum ComputerReplies: 12Last Post: 1st Feb 2011, 13:56 -
Javascript/Silverlight, embedding multiple players
By thecoalman in forum ProgrammingReplies: 0Last Post: 4th Mar 2008, 07:00 -
Help - JavaScript Help from anyone?
By TaoTeWingChun in forum ProgrammingReplies: 7Last Post: 14th Dec 2007, 16:34 -
I need urgent help, please! Javascript not working
By rem_2007 in forum ComputerReplies: 4Last Post: 23rd Nov 2007, 09:23 -
Windows utilities to strip Javascript?
By Ai Haibara in forum ComputerReplies: 12Last Post: 22nd Sep 2007, 19:37
