I am using Win 7 Ultimate.
So I am trying to play a DVD with DTS 5.1 Audio.
I am not getting sound! What shall I do?
Try installing ac3filter and see if it helps - I think it is supposed to handle dts despite the name. - and ffdshow might be worth looking into as well.
Also I do think there are audio packs you can buy seperately for windows media player to handle non dolby sound.
Or try playing it with vlc or mediaplayerclassic. Those are both free to use.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Ya i have installed but DTS is detected while playing MKV with DTS
but while playing DTS DVD it is not detected!! -
The only actual solution is, drop WMP12.Originally Posted by anirban
It was designed to let the user see and hear
only what Microsoft regards as "best for all users".
How i can convert the dts-es or dts-ex 6.1 into dts core 5.1
By fits79 in forum Newbie / General discussionsReplies: 18Last Post: 19th Aug 2012, 17:25 -
How i can convert dts-es to dts-core from one mkv file?
By fits79 in forum Video ConversionReplies: 3Last Post: 11th Jun 2011, 22:24 -
Why WMP doesn't play DTS audio (MKV, M2TS files) ?
By mahogany in forum Software PlayingReplies: 2Last Post: 11th Dec 2010, 15:45 -
help gettinng .m2ts with dts to play on ps3 with the dts intact. got close
By jayjay139 in forum Blu-ray RippingReplies: 0Last Post: 12th Mar 2010, 13:10 -
DTS encoded disk, output to DTS receiver using an HTPC
By ChipMcC1 in forum Media Center PC / MediaCentersReplies: 6Last Post: 18th Nov 2007, 08:06
