What standard(s) describe the raw video bit streams that are input to and output from typical encoders (i.e mpeg4-2, wmv9, etc.?)
Results 1 to 10 of 10
Need more context. What do you have and what do you want to do?Originally Posted by crosenRecommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I'm just trying to fill a whole in my understanding of the subject. I don't understand how a device (i.e. computer, DVD player, etc.) can render the video from, say, an MPEG-4 file unless it knows not only how to decode an MPEG-4 file to an uncompressed bit stream, but also how to interpret that subsequent bit stream as video frames. Yet, I can't find any material that explains the specs/standards for that interpretation?
The decompressors produce output frames in one of several defined standard formats like RGB24, YV12, YUY2. Conversely, the compressors accept input in similar formats.
Mpeg2 (DVD) or MPeg4 files converted to uncompressed YCbCr or RGB would be a decode. The reference specs for MPeg2 or MPeg4 define the decode mechanism. MPeg in general consists of a sequence of digital frames organized as GOPs (group of pictures).Originally Posted by crosen
http://www.webopedia.com/term/m/mpeg.html
http://en.wikipedia.org/wiki/MPEG-2Recommends: Kiva.org - Loans that change lives.
codec - compressor/decompressor - like jag says they convert uncompressed to compressed and back out the other way.
great, jagabo, thank you much - that's just what i was looking for.
See http://www.fourcc.org/ for uncompressed format descriptions.
For display purposes under Windows the most common format are RGB24, RGB32, YV12, and YUY2 because graphics card can display those directly.
Basic questions on Premiere Pro, Authoring, Encoding...
By nharikrishna in forum Authoring (DVD)Replies: 4Last Post: 11th Oct 2010, 00:49 -
Basic video projector question
By jbaugh in forum Newbie / General discussionsReplies: 10Last Post: 14th Apr 2009, 01:58 -
Basic Question RE: Video Restoration
By hondaspeedx in forum RestorationReplies: 11Last Post: 10th Oct 2008, 07:43 -
AVI->MPEG2 (CCE Basic) encoding results in incorrect video length in pla
By binister in forum Video ConversionReplies: 8Last Post: 26th Feb 2008, 17:29 -
Need some basic knowledge of rendering/encoding.
By devizboy in forum Newbie / General discussionsReplies: 13Last Post: 11th Jul 2007, 11:30
