Alright, I need a capture program that can do the following:
-compress and save as avi, mpeg, or both, doesn't matter
-compress audio using formats other than PCM, preferably mpeg layer-3
-run at scheduled times
AVI_IO has everything except it only supports PCM audio... argh! Any other suggestions?
Try VirtualDub and you can download the program on this web site. Just select capture on the left.
Simple DV capture program
By HDClown in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 12th Jul 2010, 09:49 -
Best Capture Program???
By Dom_Sisko in forum Capturing and VCRReplies: 2Last Post: 11th May 2008, 22:49 -
Are there any Capture program that can capture in high resolutions?
By Wooooooo in forum Capturing and VCRReplies: 2Last Post: 7th Jan 2008, 16:39 -
Is there a good Capture program where you can capture in high resolutions?
By Wooooooo in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2008, 12:20 -
Screen Capture Program ?
By Endemoniada in forum Newbie / General discussionsReplies: 3Last Post: 21st May 2007, 15:45
