I have a celeron desktop with 512 mb of ram, an ATI dual head video card (128 mb ram) 15K 36 GB HD, a 10K 72 GB and a 1TB hard drive on the way, that I can upgrade to a 3.06 ghz P4 with 3gb of memory for about $40. I was planning on just getting parts for a whole new computer...then this really neat sale came up on a camcorder, and, well, you know how that goes.
With the P4 will I be able to do real time editing? - that is one reason why I got the dual head video card. With the present system it takes about 3 hours to render 1 hour of video (am using Ulead v. 9) With the upgraded system will I come close to having a 1 to 1 ratio for rendering? i.e. one hour to render one hour of video? Does rendering time depend on the software being used?
Of what? Standard definition DV? Yes -- ish. High definition AVCHD? No. (Note that editing is not rendering.)Originally Posted by Haopengyou
That won't make editing or rendering go any faster.Originally Posted by Haopengyou
No. Going from a 2.4 GHz Celeron to a 3.0 GHz P4 will probably increase your rendering speed by about 20 percent. So your 3 hour encode will drop to about 2.5 hours.Originally Posted by Haopengyou
Yes. Some encoders are faster than others. CCE is fast, TMPGEnc is slow. I think Ulead is somewhere in between.Originally Posted by Haopengyou -
A Core2Duo processor will get you faster than 1:1 for MPeg2 encoding with ULead's Mainconcept encoder.
http://www.kiva.org/about
cpu vs gpu for video rendering with i5 460m 2.53 ghz
By Edgarke16 in forum Software PlayingReplies: 6Last Post: 3rd Jan 2012, 06:43 -
Cores Vs. Ghz for photo programs ?
By Noahtuck in forum ComputerReplies: 31Last Post: 9th Sep 2010, 23:06 -
computer power ghz ?
By luc13137 in forum EditingReplies: 6Last Post: 2nd Aug 2010, 23:08 -
clarkdale hitting 4 ghz on air
By deadrats in forum ComputerReplies: 2Last Post: 25th Jul 2009, 08:09 -
iMac G5 as fast as new SR 2.4 Ghz MB Pro? This can't be right.
By Scallywag in forum ffmpegX general discussionReplies: 4Last Post: 21st Jun 2007, 23:59
