Hi,
Here's my problem, I collect a lot of videos from all over the Internet that I want to put on my handheld PocketPC (iPaq hx2755), which has a screen dimension size of 320x240. The source videos I collect have various dimensions such as 672x384, 768x432, 624x352, 640x512, and so on and so on.... In order to maximize the playback viewing on my iPaq, I need to convert the source videos to a size where the horizontal dimension is 320. This is where I have to do manual work that I'd really like to not do
. While I have the destination video's horizontal dimension of 320, I dont know the destination video's vertical dimension or its aspect ratio
. To get those I have to calculate the aspect ration of the source file, say its dimension are 672x384 so the aspect ratio is 672/384=1.75. Then I take the desired destination video's horizontal dimension of 320 and the aspect ratio of 1.75 to determine the vertical dimension is 320/1.75=182. The destination video will need to be 320x182 with the aspect ratio of 1.75
The math is quite simple but when you feed each file into the conversion software (Xilisoft's Video Converter Ultimate), each file will need it's own custom output profile with the information I calculated above. It gets to be a royal pain.
Does anyone know of a tool that I could use to simplify the task. Something where I have to enter the fewest numbers yet produces the results as describe above.
Any help you can provide is greatly appreciated.
Thanks,
Norm
Results 1 to 1 of 1
Norm
File Dimensions No Longer Show In Windows Explorer
By DarrellS in forum ComputerReplies: 15Last Post: 23rd Feb 2009, 23:11 -
Can vertical oscillation be fixed?
By davexnet in forum Video ConversionReplies: 11Last Post: 19th Feb 2009, 20:11 -
rmvb file crashes every program when try to convert, can it be fixed?
By whatsmyname in forum Video ConversionReplies: 11Last Post: 28th Jul 2008, 21:55 -
Audio sync problem converting 2nd part VOBs->avi with VDubMod [fixed]
By blueprint in forum Video ConversionReplies: 5Last Post: 13th Dec 2007, 00:07 -
Many many Yellowish and Dim LCD TVs...
By SingSing in forum Newbie / General discussionsReplies: 3Last Post: 29th Oct 2007, 09:41
