Recently I have been able to create mp4s that are compatible with both PSP and iPhone using Xvid4psp v5.037 on Vista OS. Now, I've upgraded to windows 7 and found out that v5.037 dont work with W7 so I used xvid4psp v5.0.37.5 r25. I was able to change most of the settings I recognized from the old version to the new one but for some reason my psp says its unsupported. Does anyone know the correct setting to get an mp4 compatible with both iphone and psp.
Current Settings are:
[Main Tab]
Encode Mode: 2 pass
AVC profile: Baseline
AVC level: 2.1
No Checkmarks
[Motion Analysis Tab]
Subpixel ME: 6 - RD on I/P frame
ME algorithm: Hexagon
ME Range: 16
Reference Frame: 2
Checkmarks on:
Mixed ref. frames
Chroma ME
DCT decimate
I4x4
P8x8
B8X8
[B-frames Tab]
B-frames: 0
B-frames mode: Disabled
Adaptive B-frames: Disabled
Check Mark on:
Disable mb-tree
[Misc Tab]
Trellis: 0 - Disabled
Minimum quantizer: 10
AQ Mode | Strength: 1 - 10
Pys-RD | Psy-Trellis: 1 - 0
VBV buffer | maxrate: 0 - 0
QP curve compression: 0.6
Chroma QP offset: 0
Checkmark on:
Psy-RD: | Psy-Trellis
Fast P-Skip
Results 1 to 1 of 1
xvid4psp settings to convert mp4 videos for SE w580i?
By secko in forum Video ConversionReplies: 2Last Post: 23rd Nov 2011, 10:27 -
XVID4PSP Settings?
By skorpinok in forum Video ConversionReplies: 1Last Post: 6th Jun 2011, 15:41 -
xvid4psp help with settings to play on 360 and ps3
By huntsman in forum Video ConversionReplies: 0Last Post: 23rd Apr 2010, 19:11 -
Xvid4PSP settings for hybrid AVCHD disc
By zoobie in forum Video ConversionReplies: 3Last Post: 9th Jul 2009, 01:51 -
Need the Best Settings for MKV from Xvid4PSP
By maass in forum Newbie / General discussionsReplies: 1Last Post: 20th Feb 2009, 11:29
