I wrote an explanation here.
http://nch.invisionzone.com/index.php?showtopic=13808
No one knew the answer (so far). Here is a paste
I'll write and link another thread for more general help.
Its very weird... i have a FLV file that uses FLV1 and NELL captured via stream.
VideoPad so far is the only app that can open and convert it without crashing or getting the framerate wrong.
However my output is always terrible quality no matter the setting. Then i notice my INPUT video is horrible as well. Worse then how it looks in EVERY player i tried. Weird, how do i fix this?
Is there a way to make it use k-lite codec/FFTryOut? I install it and had it working with virtualdub (framerate problem) and the input source is fine. Now if only i can get videopad to use the same input codec......
	What does mediainfo say about the file? And what is the framerate supposed to be?
 If it's FLV1 and nellymoser audio, you can enable those in the ffdshow configuration (for video and audio). You could use DirectShowSource() in avisynth to open it if you have a flv splitter installed
 Some FLV's are variable frame rate. Drop the FLV onto flvextract, and read the timecodes sheet. If it's VFR, then you will have a lot of difficulty in editing it and keeping sync
 What is your end goal with this file?
	Media Info only tells me the Filesize -_-. With other files (non streaming/captured) it supplies actual data
 FLV Extract gives me this. (It plays it back as 28min too. This isnt the same file)
 0
 0
 0
 23
 1215682
 1215823
 1215939
 1216101
 1218355
 3042
 1218692
 etc
 My Goal is to convert it to xvid. I would like to jump around and also i notice if i use a screen capture app setting it to the same resolution i can get a smaller (about 2/3 to 3/4 WITH jumping) xvid file with same or near same quality
	How did you capture it? What software/What process?
 Do other media players play this file fine? e.g. VLC, MPCHC, KMplayer ?
 I have no idea what you are trying to say here?I would like to jump around and also i notice if i use a screen capture app setting it to the same resolution i can get a smaller (about 2/3 to 3/4 WITH jumping) xvid file with same or near same quality
  Poor Picture quality - need help!By Martin747 in forum EditingReplies: 2Last Post: 26th Dec 2010, 13:00
  Poor Burning QualityBy CindyLuB in forum DVD RippingReplies: 6Last Post: 17th Jul 2010, 21:41
  best audio video quality of youtube poor quality and not hq flv videos.By nusratjaveid in forum Video ConversionReplies: 3Last Post: 20th Jun 2010, 20:23
  Poor Video QualityBy itsernst in forum Capturing and VCRReplies: 20Last Post: 10th Feb 2010, 17:32
  Poor QualityBy Net_Bug in forum Capturing and VCRReplies: 3Last Post: 29th Mar 2008, 17:37
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
