This is regarding to burn the market blu-ray DVD movie. The DVDfab 6 beta version does not accept the none blu-ray DVD disc. How to burn a blu-ray DVD movie to the regular DVD-/+R(W) directly, or the blu-ray DVD movie should be copied to the hard drive first and then use the other DVD copy software to burn it to the regular DVD-/+R? By testing to back up the blu-ray DVD movie Proposal with the DVDfab 6 beta version, DVD to DVD, but, the message keeps prompting to insert a compatible media though a blank DVD disc has already been inserted. Can DVDfab 6 beta burn the Blu-ray DVD movie to the regular DVD-/+R directly?
What is a blu-ray dvd???? A dvd movie on blu-ray? or a blu-ray video on a dvd? OR what?
You can't read Bluray discs in a DVD drive.
If this is a Bluray that has been down converted to fit on a DVD disc then just copy the files. You may have to install a UDF Reader first so you can read the format in a standard DVD drive.
You might also consider proof reading your posts before you hit the submit button - maybe throw in a little punctuation - and kind of make sure what you type actually makes some sort of sense.Read my blog here.
Blu-ray converted to .mkv now i want it back to blu-ray structur ?? help
By Trigarr in forum Authoring (Blu-ray)Replies: 8Last Post: 20th Oct 2011, 13:34 -
How to back up blu-ray DVD?
By coody in forum Blu-ray RippingReplies: 2Last Post: 2nd Sep 2010, 11:23 -
Put Blu Ray disc in regular DVD player???
By Tech Challenged in forum Newbie / General discussionsReplies: 18Last Post: 20th Feb 2009, 11:09 -
Will a blu ray disk play on regular dvd player in 480 lines of resolution?
By donfm in forum Newbie / General discussionsReplies: 5Last Post: 6th Jan 2009, 07:00 -
Will my regular DVD player play a "blu-ray to DVD " disc ?
By htp367 in forum Newbie / General discussionsReplies: 6Last Post: 2nd Oct 2008, 13:28
