I have Windows Vista Home Premium and I downloaded VirtualDub 1.7.8. When I tried opening the AVI video file that i wanted to used on VirtualDub it said:
Couldn't locate decompressor for format 'xdiv' (unknown)
VirtualDub requires a Video for Windows (VFW) compatible codec to decompress video. DirectShow codecs, such as those used by Windows Media Player, are not suitable.
I searched for a VFW compatible codec that could be used with VirtualDub but it didn't work.
Please help me I'll be very greatful![]()
Install the Xvid codec.
If cameras add ten pounds, why would people want to eat them? -
download the Xvid codec installer from this site and run the setup. that should do...
Sorry but I'm a real idiot when it comes to codecs and such, I've installed it but how do i run the set up? :/Originally Posted by leghorn
If it's installed, it will show up in VD's 'Video>Compression' list. L click on it, then to the right side of the page, L click 'Configure' and you will see the settings. L click 'Target Bitrate' and it will change to 'Target quantizer'. Use a setting of '2' there if you want about the same quality as the original file. Or '3' if you want smaller filesize/quality.
If you want a particular size output, there is a bitrate calculator to the right of the 'Target' settings. It works best with 'Target bitrate' and two pass encoding. For VD guides, just look to the bottom of the VirtualDub toolpage.
Using VirtualDub 1.10
By eteaneck in forum Newbie / General discussionsReplies: 3Last Post: 8th Mar 2011, 15:50 -
Why is Virtualdub doing this?
By skybooks in forum Video ConversionReplies: 4Last Post: 29th Jan 2011, 21:11 -
Virtualdub comand line crashes, but virtualdub works.
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 28th Jul 2010, 13:26 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 17:08 -
Help with VIRTUALDUB Please !!!!
By spliffy in forum RestorationReplies: 10Last Post: 30th Jun 2007, 08:28
