I was asked a question by a friend that I couldn't answer, I thought I'd come here.
He has a DVD to DivX rip AVI file. He also has a separate ripped subtitle from the same DVD. He wants to know if it's possible to encode that subtitle file to the AVI so the subtitles are superimposed over the movie.
Is this possible? If so...how?
Thanks,
Ep.
I'd do it with Smartripper 2.41 (to rip the DVD to the hard drive), then convert to DivX with with DVDx 1.7
In the Input Option of DVDx:
Subtitle:
Show subtitle.
Default is : None (if the movie has subtitles, they'll show up here)
Subtitle Offset:
Vertical offset in pixel of the subtitle. This values is automaticaly adjusted
if the subtitle goes out of the screen
Default is : 0
I've done it one chapter of one movie just to see how it works (just fine!).
As always, your mileage may vary; professional driver on closed course; always wear a seat belt; don't drink and drive...As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
How to add permanent subtitles with AutoGK and convert to AVI DivX or XviD
By Baldrick in forum SubtitleReplies: 263Last Post: 17th Jun 2018, 15:18 -
Dual or Multi Audio AVI with subtitles (MPEG4 XviD DivX)
By DereX888 in forum User guidesReplies: 16Last Post: 20th Dec 2012, 15:24 -
ffmpegX - idx/sub subtitles lost in converting from avi to Xvid or DivX
By bonespur in forum MacReplies: 5Last Post: 4th Mar 2011, 02:25 -
Creating my own subtitles and adding them to an AVI (divx) file? Best way?
By Chrushev in forum Newbie / General discussionsReplies: 1Last Post: 9th Jan 2010, 04:12 -
adding subtitles to AVI (xvid or divx) WITHOUT re-compressing
By truthlesshero in forum SubtitleReplies: 2Last Post: 22nd Dec 2009, 10:43
