    Oct 2009
    Hello, not sure if this is where this should be posted. Any help that could be given with this matter would be greatly appreciated.
    I have a 3-4 minute commercial built in final cut/shake. I've resized and exported it previously for American media, but I'm faced with a new problem that's proving difficult to troubleshoot. Basically, I need to get a file over to Russia in a clear, usable format. The end media is going to be displayed on a 52" Samsung LE-52A556P1 and it will be streaming from a laptop, so no worries about dvd conversion and region coding. The clip is 1920x1080 in PAL @ 25fps.
    Does anyone have any tips for what format / codec / compressor is compatible with a Russian system?
    Many thanks, comrades!
    Adam
  2. If it is going to be played on a computer, there is no "compatibility" issue. The only limitation would be the playback capability of the laptop in handling hi-res clips. They got the same playback software there as we use.
  3. Member Alex_ander's Avatar
    Oct 2006
    Russian Federation
    Almost any encoding will suit but mpeg2 would be better than mp4, since most people in Russia use Windows.
    Oct 2009
    <-- russian
    Yeah most use Windows, and formats such as Xvid/Divx with AVI/Mp4 containers are very common and are widely used.
    They use Pal/Secam on their TVs, but 99% of the TVs will play all PAL/NTSC/SECAM videos as will the players.
    If you need region for a DVD or something, either make it region free or make it region 5.
