I got same problem, just one night dvdr3595h/31 unit was in Starting cycle.
did Self Test with "REC and Play (>|) keys" and got "Pass".
did the CD upgrade with "REC and NEXT (>>|) keys" to v3.06.
nothing, still STARTING over and over again.
do not want to format hdd and loose recordings.
will try to take it out to ide->usb box and watch wit laptop, if i can copy recordings.
if not, will try "hdd regenerator" to repair hdd, (have got one old Samsung ide hdd back to work with windows, where it wasn't recognized before at all).
				Results 61 to 73 of 73
 darryl
 thanks for taking the time to post this valuable info...as there is no help available from philips.
 I have a philips dvdr3576h/37... came with the seagate 160 hdd it still worked but was full
 I'm taking a shot in the dark, with a refurbished 2t hitachi sata
 I just tossed it in to see what happened as the sata are to self adjust so no jumper settings to mess with,
 but only got an error code on the unit.
 I wasn't expecting much.
 another thing to check out if using the jumpers on an ide, is to go to the mfrs website for that particular hdd from the philips recorder
 and dbl check the settings, then go to the mfrs website for the hdd YOU have and make sure you know which jumpers to now use.
 I just got the sata drive and an ide refurbished too, just in case the sata refuses to fly, I SHOULD be able to get the 250 sized western digital to work [ fingers crossed ]
 anyways, good thing I kept trying different types of searches and hit upon this forum I almost forgot about
 so, I'll report back as time permits.
 I'm gonna pull the drive, format to fat 32 and report what happens afterwards
	All-
 The O-ring you need to replace the optical drive tray opening/closing belt is a #30. They sell at Lowe's for about $2 for 10 or 20 of them in a pack.
 You can replace the belt from the front of the unit once you have become familiar with it. Otherwise, you can still replace it without removing the optical drive from the chassis by removing the top cover of the drive.
 I have replaced my belt twice over the years. I found it is most easily done working from the front of the unit using a hemostat and small flathead screwdriver. I got the belt around the big pulley first then stretched it around the smaller pulley, which is on the motor shaft.
	I found this problem also on XBOX360 game consoles and pc dvd-drives, refusing to open the plateau or refusing to eject the disc.
 I am almost certain that it has to do with the magnet in the top plastic wheel. When it gets too strong and after a long period also magnetizes the metal in the bottom plateau parts, this problem starts happening! Of course it could also be a rubber snare that lost strength but mostly it isn't !
 What you can do is simpel, and I did this with a few XBOX360 dvd players that wouldn't eject the plateau anymore. You fix this problem easily just by weakening the magnetic strength of the magnet pressure wheel in the top (That is only needed to keep the disc in place when it is turning).
 And the way to do this is by sticking 1 or two layers of not deforming tape needly in the shape of the round wheel in top of the player. And you'll notice that the drive will open the plateau much easier.
 But carefully not to apply too much tape so the disc still will stay centered on the turntable motor when read, without danger of getting loose. And of course you better use tape that sticks well and is not easily removed so you make sure it won't break the inside of your drive !
 It is in most cases a good solution to enjoy your original DVD player or DVD burner much longer.
 Alectronic, Weert, The Netherlands.
	The post you're responding to was made 5 years ago. It was his first and only post, and he hasn't logged in since 2011.
 He was referring to setting up a new HDD to use Philips' file system so that it can be used as a replacement inside the DVD recorder. That's why he suggested aborting the copy early to save time; his goal was not to backup the original files, and certainly not to view them in Windows as you would like to do.
 The tool he used likely did a bit-for-bit copy, so it didn't need to actually interpret the file system. He probably had no opportunity to view the files with this program even if he wanted to.
	I have an LG LRH-780 that I've had since January 2007. Last night (February 17) I accidentally turned off that recorder and have had nothing but trouble ever since. It won't completely start up and I'm thinking the hard drive is on its last legs and need a way to get the content transferred off. (Said content only comprises of about 30 hours worth in 4-hour mode, out of a possible 80 hours at the outset, and some of the stuff I have on it I have no plans to keep beyond playback. And I can re-record some episodes of one CBC program later this summer in reruns if necessary.)
 I had a power outage late on January 29 (weather-related) and it took about 10-15 minutes at the time for the unit to fully activate. At that time, I surmised to myself the unit cannot be allowed to be off for a prolonged period of time. This incident last night meant I couldn't turn it off at all.
 I did buy a new (in the loosest sense) LG HDD recorder last Christmas and it works perfectly (the only surprise I got out of it was a previously recorded program done in 2011, probably in Ontario (and I'm in Newfoundland) which I've kept). Unrelated, I have a Toshiba D-R7 DVD recorder (no hard drive) that has preservation issues, and I've put it in storage until someone can repair it. (Bought a D-R5 at a yard sale last summer for $5, and despite its hit-and-miss situations during/after recording, has been an able secondary unit whenever there's a scheduling conflict.)
	http://ifndef.altervista.org/index_eng.html
 http://www.satacables.com/SATA-Hard-Drive-to-usb-adapter/SATA-IDE-ATA-66-ATA-100-ATA-1...ata-drive.html
 You'll need to remove the HDD from the unit, hook it up to your PC with an adapter kit like the one I linked to, then run either "from hdd lg to pc v1.12" or "from hdd lg to pc v2.06" softwares available on the website I also linked to.
 The recorded programs are in MPEG-TS - straight MPEG2 files.Last edited by hech54; 18th Feb 2016 at 08:00.
	My old recorder is running again, and I did absolutely nothing! What I did do was I switched it on either Thursday or Friday night, and let it try to warm up overnight; as of this morning, it's running again and I can transfer stuff as long as (a) I don't shut it off accidentally again or (b) the power goes out. This (for now) ends a week and a half of inactivity.
	How do u get the hdd file inside readed?
 i try to plug in to my pc but it dont read
 i using win 10
	HDD replacement procedure
 1. Install the new HDD.
 2. Upgrade the software by forced download ("REC"+"Next >>|" while powering
 on the mains) with the upgrade disc to the latest software
 2.1 Press and hold the REC and NEXT (>>|) keys on the front panel while you
 reconnect the recorder to the mains. The message "Download" will appear
 on the recorders display.
 2.2 After a while, the tray will be ejected and your recorder displays
 the message "Put disc".
 2.3 Place the download disc on the tray and push in the tray.
 Your recorder will now start the upgrade process, which will take
 around 10 minutes.
 2.4 After the download is completed, the disc tray will eject automatically.
 Remove the disc and push back the tray.
 2.5 When you see the message "DONE" on your recorders display,
 switch off and restar your recorder in order to complete the upgrade.
 3. Format the HDD drive (forced formatting)
 3.1 Press and Hold the "Previous |<<"+"Stop" key combination while powering
 on the mains.
 3.2 The set will start to display “FMT KEY”, and then it will show “FMT HDD”
 while formatting HDD.
 3.3 If the formatting is completed successfully, the set will display
 “FMT DONE”. If the formatting is failed, it will show “FMT FAIL”
 !!!Notes: Do not power off the set immediately when the “FMT DONE” is seen.
 Wait until the time or --:-- is displayed before powering off the set.
 The new HDD is ready to use. Some of the user information
 may be lost after HDD Replacement.
 from Russia with Love
  Philips DVDR 3455H/37 has burner drive problems- SOLUTION-maybeBy Roberht in forum DVD & Blu-ray RecordersReplies: 8Last Post: 6th Jan 2015, 18:02
  Philips DVDR-3480 DVD Recorder and Player 1080i‏By Vixfoxwatch in forum Newbie / General discussionsReplies: 5Last Post: 7th Nov 2010, 15:18
  Philips DVDR 3455H and DishNetwork DVR 625By mdtx001 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 14th Oct 2010, 18:57
  philips dvdr 3455hBy mikes94547 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 24th Dec 2008, 10:36
  Philips DVD 160GB Recorder Model DVDR 3455HBy vsenapati in forum DVD & Blu-ray RecordersReplies: 2Last Post: 28th Jun 2007, 20:56
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 29th Aug 2010 07:20
 29th Aug 2010 07:20 Quote
