    Dec 2001
    Italy
    Hi all!
    I try to put my Record of Lodoss War vcds on one DVD, so I joined the movies with MyFlix, then I converted the audio to 48KHz as stated in the guide.
    The movie is now about 2,8Gb (4 hours and 27 minutes).
    I tried to import this file in DVDit and myDVD, but both give me this Error Alert:
    DVDit! Can't find a decoder for E:\Mpg\Lodoss\Lodoss.mpg Verify to have installed a Decoder.
    Why it give's me this error? Where can I find an appropriate decoder?
    I tried to import the same file in SpruceUp and it manages to import it, but I don't like SpruceUp, it's not precise when I try to select the chapters.
    The Mpeg file is readable by WMP and any other progs I tried, but is not importable by DVDit!
    I created the mpeg (when I encoded it) with LSX Mpeg Encoder 3.5 and the other editing I did is just the demux and mux (Tmpgenc) to make the 48KHz conversion.
    I even thought it could be a dimension issue, but DVDit gives me the same Error even on other Mpegs a lot smaller (I tried from 50MB to 250MB) and it gives me the problem even if I don't convert the sample rate!
    I just managed to import Avi files, but I can't convert all the Lodoss war mpeg into Avi (even compressing with Huffyuv is more than 50GB!)
    My system is Windows XP Pro, Athlon 700, 384MB SDRAM
    Thanx for the help! ^_^
  2. Well I havn't used those programs but ReelDVD will only accept the elementary mpeg streams then multiplex them into a vob. So demux and see if it will open them.
    install a software dvd player such as powerdvd or windvd or install the mpeg2 codec to get a mpeg2 decoder.
    www.vcdhelp.com/vcdtools.htm
  4. Hi Hedgehog,
    I am curently using DVDit and used to get those sort of errors.
    Try this:-
    Open mpeg in windows media player, let it play a few seconds, then pause it, DON'T CLOSE WINDOW, just minimize it to toolbar.
    Now start DVDit, right click on import media files, it should import ok now.
    RimmeR
    "Smoke Me A Kipper, I'll Be Back For Breakfast!! :D
