Hi folks,
Couple of questions in regards to .Exe & .Zip programs. In any programs whether is a Converting Program or any other ...
Q1: If you have a program that is offered in both .Zip and .Exe formats, which forat which choose to use?
Q2: And why did you choose the one that you picked? I mean if you chose to use .Exe version of the program ... WHY did you chose that version?
Q3: Any Benefits using one over the other!?!?
Thanks,
G!![]()
Closed Thread
Its been all discussed here .............. https://forum.videohelp.com/topic357794.html?highlight=exe%20zip
Edit ..now that I look at it ..Its your post in Oct 2008... Don't tell me you have been thinking about it for a year ...........
Yep, continue in https://forum.videohelp.com/topic357794.html
Windows 7 does not see my Zip Drive
By kimco52 in forum ComputerReplies: 16Last Post: 22nd May 2010, 20:16 -
Problem capturing audio with most programs, any fixes? + Lagless programs?
By fgsfdsyo in forum Capturing and VCRReplies: 5Last Post: 15th Oct 2009, 16:51 -
AviDemux .Zip vs .Exe
By gonwk in forum Newbie / General discussionsReplies: 2Last Post: 8th Feb 2009, 18:53 -
Can't unzip ffmpegXbinaries20060307.zip
By cerebusthe2nd in forum ffmpegX general discussionReplies: 4Last Post: 9th Dec 2007, 08:39 -
explorer.exe / drwtson32.exe keeps closing
By coolcoates in forum ComputerReplies: 7Last Post: 28th Nov 2007, 08:42
