Hi
In a process of capturing from VHS aiming to produce high quality (the best possible) Mpeg4-DivX;-) videos, and since encoding in real time is not recommendable, which is the best format for the intermediary file?
I discard the uncompressed one because it needs much HD space.
I heard that Mjpeg is not a good option for this purpose.
Mpeg2 has audio synch problems.
Does Mpeg1 offer satisfactory quality?
Any opinion is useful
I would suggest using virtualdub to capture to YUY2 with huffyuv compression. Still gives you a pretty large AVI file but if youve got the hard drive space it is well worth it for the much better results than with mpeg. You can also capture to segmented files using vdub so your file size is only limited by your hard disc space.
Craig -
When encoding on the fly using software codecs, I would only consider a couple of options. If you've got quite a few gigs free then take craig's advice and go for HUFFYUV capturing at a high resolution. This is a lossless codec so the results will look exactly the same as if you had captured uncompressed.
If disk space is more of an issue (like it is with my computer) then capture using MJPEG with a quality setting of 18 or 19. It won't be as good as HUFFYUV at the same resolution but it will be a darned site better than doing a real time software encode to MPEG1 or MPEG2.
The resolution you capture in often has more of an impact on quality than the file format used. For example, my captures look better at 352x576 using MJPEG(Q18) then they do using HUFFYUV at 352x288.
intermediary format for editing screencasts
By codemaster in forum EditingReplies: 6Last Post: 25th Dec 2011, 08:59 -
.dxa format file to other video format
By Edisonsss in forum Video ConversionReplies: 2Last Post: 2nd Dec 2010, 16:52 -
Realplayer files to another file format or dvd format
By vieya in forum Video ConversionReplies: 8Last Post: 25th Dec 2009, 12:12 -
What's a good intermediary format?
By sd_smoker in forum Video ConversionReplies: 3Last Post: 9th Jul 2008, 12:06 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 10:38
