What software do you use. Generally speaking, if it ripped to the HD, you removed the protection. I never heard of the the protection being copied with the DVD.
I love children, girl children... about 16-40
W.C. Fields -
The programs I recall using were/are DVD Decrypter, SmartRipper and DVD Shrink.
I hope you're right that it's all or nothing. Protected ripped files would have probably been nothing but trouble. -
I've used them except Smartripper, and a t least a half dozen others including Anydvd and DVDFabDecrypter. All remove the protection, not copy it, I doubt Smartripper would be different. It just wouldn't make sense to copy the protection.
W.C. Fields -
There is no 100% sure way to know.
They can have blank cells at the beginning for example, even though it has been "copied to your hard drive". Another example is pixellated/distorted segments can signal poor copy protection removal, even though it exists on your hard drive... you get the picture -
None of the 3 decrypters mentioned will completely remove the copy protections from DVDs using more modern copy protections. If kept as unreencoded DVDs, most likely they'll play without issue. If reencoded, the thing most likely to occur is audio desynch because of the unreferenced cells still remaining, something already mentioned by poisondeathray.
I don't feel comfortable saying it's impossible for any of those to rip a protected DVD and leave some of the protection in, but in my experience the modern methods that they don't understand result in failed rips - the program will show you errors and refuse to continue the rip. I do feel comfortable in saying it's highly unlikely that your rips are still protected. And with the original poster being in Israel (region 2, right?), the odds of having a DVD from Israel's region that uses those modern methods of protection is also quite low. I've heard of a few discs outside of region 1 that use these new protections, but it's still quite rare overall to find them on any discs outside of region 1. Again, I did NOT say it was impossible to find such discs, so please don't follow up with a post listing one of the few region 2 or 4 discs that uses ARCCOS, etc. I said it was rare. The vast majority of non-region 1 DVDs do NOT use these new DVD copy protection methods that DVD Decrypter, etc., don't understand.Originally Posted by l-w-c
Cant get rid of aliasing
By killerteengohan in forum RestorationReplies: 7Last Post: 8th Feb 2012, 00:33 -
How to use DVDFab HD Decrypter to remove protections?
By VGI in forum DVD RippingReplies: 4Last Post: 9th Apr 2011, 06:27 -
Beauty&Beast Blu-Ray Ripping Loses 3-Dimensionality after ripping
By KostaRae in forum Blu-ray RippingReplies: 4Last Post: 22nd Mar 2011, 05:50 -
Dazzle Digital Video Creator 100 (DVC 100)
By Rockin Rayzor in forum Newbie / General discussionsReplies: 3Last Post: 7th Nov 2008, 17:08 -
How to get rid of windowboxing?
By Levina in forum MacReplies: 8Last Post: 10th Jun 2008, 20:47
