Hello, I need to write a script, which will import a video file to vdub, from txt file will read a set of timecodes and export AVI files starting at these timecodes with duration maybe 30s. Is it possible? Is there any other easier way? Please write any help, thanks, DveD
You can split an avi into intervals (split by frames , which can you can convert into time units like 30s if you know the fps, or file size) by using the save segmented avi function, but it won't work with different intervals (they have to be constant), and it won't read it from timecodes
Error when saving from VirtualDub as AVI with compression
By Thread7 in forum Newbie / General discussionsReplies: 5Last Post: 9th Aug 2010, 21:41 -
Do Movie Maker or Virtualdub re-encode DV-AVI when saving? Quality concern?
By sdineen in forum Newbie / General discussionsReplies: 9Last Post: 18th Jul 2009, 21:47 -
Simple Script to Prepare Your DivX/Xvid AVIs for Transcoding
By Soopafresh in forum Video ConversionReplies: 17Last Post: 13th Jul 2009, 20:30 -
VirtualDub: Saving Segmented Avi
By Ruro Jiruries in forum EditingReplies: 0Last Post: 18th Jun 2009, 07:13 -
Saving AviSynth script to file
By Leo48 in forum Newbie / General discussionsReplies: 6Last Post: 24th Jun 2008, 14:35
