Hi,
I'm trying to extract audio (in mp3) out of several .avi video files. VirtualDubMod has a Demux option in Streams > Stream list that works just fine. So my question is is there any way to automatily do it for a bunch of video files, instead of opening them one by one? Maybe, using the DubMan or something else? or maybe in avisynth?
Ok, I was too hung up on things like avi2raw and dubman. It just occured to me that VirtualDub is actually different from VirtualDubMod, so I gave it a try. I found the File > Queue batch operations > Batch wizzard menu, which seems to really extract raw audio mp3's once you force the program to rename output files from *.avi to *.mp3. So I guess my problem is solved
VirtualDub Batch Conversation with MTS files?
By khan.cross in forum Video ConversionReplies: 2Last Post: 24th May 2015, 03:09 -
Best way to batch convert xvid/avi files to mkv/x264 files?
By gaikokujinkyofusho in forum Video ConversionReplies: 1Last Post: 13th Jan 2012, 07:31 -
Tool for VirtualDub batch processing of video files - DubJobs
By bernie79 in forum Video ConversionReplies: 6Last Post: 14th Apr 2010, 11:36 -
batch join all .avi files in folder
By shun in forum EditingReplies: 7Last Post: 11th Dec 2007, 09:25 -
What should I do with these digicam AVI files? Batch to WMVs?
By bengance in forum Newbie / General discussionsReplies: 1Last Post: 3rd Jul 2007, 03:16
