Howdy All
I have recently started using the program "Handbrake". It seems like a good tool but Im having a technical problem with it.
Firstly I am using the program to convert video for my Iphone. I have been experimenting with home video files (because I don't have an avi file at the moment ) taken with a camcorder (mpg) i think. I have successfully converted 2 small files to mpeg4 and uploaded them to my phone.
Although the video files have a brilliant picture the sound only comes out one of stereo earpieces of the iphone. Im wondering if this problem is with the source files or something I have overlooked in the program.
Thanks![]()
Results 1 to 10 of 10
Does the new mp4 sound okey on your computer?
You could also try other free all-in-one converters like format factory or xvid4psp. They have profiles for iPhone. -
What camcorder? How did you get video from the camcorder into the computer? Maybe you need one of these: http://www.cablesnmor.com/rca-y-splitter.html
I got the camcorder files into the computer via a hardware processing video capture device. The brand was "videomate".
I did all of my home movie files with that.
So at the end of the day it could of been captured like that??? -
I think I need to do some more experimenting with other files and not my home movie files.
I haven't got access to any internet quota at the moment, but when I do im going to try an avi file.
And no the file was the same on the pc. 1 speaker only. And thanks I'll try those other tools if I need to.
Has anyone had good experiences with "Handbrake" the video tool?
Thanks -
Was only a single audio connector (of the two) used on the capture device? Then yes, you only captured audio onto one of the stereo channels. In the future a Y adapter will take care of that (feed the mono signal from the camcorder into both the left and right channels of the capture device.Originally Posted by Dnoscave
You can fix your current caps by copying the audio from one channel onto the other while you are converting. I don't use Handbrake so I don't know if it supports that. -
Thanks guys
I just checked the source video and that only comes out in one speaker on the pc. That must be the problem. -
You can still copy the good channel over to the empty channel while you convert.Originally Posted by Dnoscave
MakeMKV > Handbreak > Mkvmerge = result; Is there a better way?
By jmallory in forum Newbie / General discussionsReplies: 2Last Post: 10th Dec 2011, 12:00 -
Proper Handbreak Xvid settings
By A_51 in forum DVD RippingReplies: 3Last Post: 22nd Feb 2011, 20:26 -
Handbreak 0.9.4 (Source)
By The.King in forum Video ConversionReplies: 27Last Post: 21st Jun 2010, 08:07 -
help encoding anime w/ handbreak
By Ronin Silfar in forum DVD RippingReplies: 22Last Post: 29th Jan 2010, 22:28 -
Resizing video file size using handbreak question.
By demonhunter in forum Video ConversionReplies: 2Last Post: 19th May 2009, 07:23
