I have a combo vhs/dvd player, and closed caption works on the dvd side but not with vhs tapes. The tapes I have are marked with the cc emblem and I have closed caption turned on with the tv; but no closed caption. I have a Sony Lcd tv and a Toshiba combo dvd/vhs player-recorder. What am I doing wrong?
Thanks![]()
Results 1 to 9 of 9
I am not too familiar with CC on tape, but my recollection is that VHS did not support it. S-VHS did, however, and requires an SVHS deck to play it back properly. If you are playing the tapes back on a VHS deck, that would explain why CC data can't be viewed. [Late-generation VHS decks can play SVHS tapes, after a fashion, but I don't think the CC data will be decoded.]
Most of my VCRs (including a Samsung DVD/VCR combo someone gave me when the DVD drive failed) can handle CC with no problems - other than the tapes I made were usually low quality, so the CC data was occasionally munged.
If cameras add ten pounds, why would people want to eat them? -
Teletext captions can't be stored on a standard VHS tape (due to limited bandwidth), although they are available on S-VHS tapes and DVDs.Regular vhs cant play cc,dont see how most of your vcrs could show cc.Originally Posted by Ai HaibaraI think,therefore i am a hamster.
No idea, then. I don't have any S-VHS decks; all of my VCRs are more or less four-head stereo VCRs. But if I turn CC on on the TV, the closed captioning on the tapes will display normally.
(And most of the VCRs are relatively old, too.)If cameras add ten pounds, why would people want to eat them? -
CC is on some VHS movies, look for the logo on the sleeve or tape. It can also be recorded if the player was made after 1992, CC decoders were also mandatory on tv's after 1992.
However you can only view it with a composite or S-Video connection, component or HDMI cannot carry the signal on line 21.
http://www.buzzle.com/articles/closed-captioning-the-early-struggles.html -
Thanks, Moviegeek, I run it through HDMI. Didn't know it required an S-video hook-up. Thanks again!
Yes, VHS does support CC. It's on most commercial releases, and it even records it on most (all?) VCRs. They don't have to be Hi-Fi VCRs either. I even capture the CC from VHS tapes to get the show transcript. I see it on tapes that I get from other people too. It's there even on low quality tapes recorded at SLP, and even second gen copies.
Darryl -
I have now hooked up through S-video, and the closed captioning works fine!!
Thanks again, Moviegeek!
Closed Captioning in Europe
By Headway in forum DVD & Blu-ray PlayersReplies: 12Last Post: 5th May 2010, 09:10 -
Hardcoding closed captioning as subtitles?
By merciscool in forum MacReplies: 0Last Post: 28th Jan 2010, 05:12 -
TMPGEnc Has a Problem with Closed Captioning
By jeanpave in forum Authoring (DVD)Replies: 10Last Post: 30th Apr 2009, 17:02 -
I am stuck with closed captioning/subtitles?
By Rjupiter in forum DVD RippingReplies: 7Last Post: 3rd Aug 2008, 15:21 -
closed captioning problem
By jeffreyslike in forum DVD & Blu-ray RecordersReplies: 4Last Post: 12th Oct 2007, 11:09
![Computer details: winxp
intel [?]
160gb
Comp](/images/buttons/computer.gif)
