Some how the quick launch bar has disappeared in win 7 64 bit. I can get the quick launch back on the taskbar but can't move it all the way over beside the start button which is where it should be. Anybody familiar with this?
Try sliding it over the other side and then resize it by grabbing the right edge and dragging it back over the left. I've had that happen in XP when I accidently tried to drag it, but caught the edge instead and resized it backwards. I couldn't move it back next to the start button, after.
Quick Launch bar in Win7?
You can pin stuff to the botton, but MS did away with the quick launch toolbar
QuickLaunch was removed from use in favor of pinning shortcuts to the taskbar however it can re-enabled if a user wants to use it.
The directions including images can be found here: http://www.mydigitallife.info/2009/01/14/how-to-enable-or-disable-quick-launch-bar-too...-in-windows-7/ -
hemlok,
Thanks for the reference--it works! I have tucked it away in case it's needed again in the future. I'll bet there are some others reading this that will do the same
regards
My Windows 7 Ultimate x64 installation has several items in the quick launch bar, and all I did was click yes to, "add to quick launch" when installing programs
Quick launch not being part of Windows 7, or having to do anything special to access it is news to me???
ocgw
peacei7 2700K @ 4.4Ghz 16GB DDR3 1600 Samsung Pro 840 128GB Seagate 2TB HDD EVGA GTX 650
https://forum.videohelp.com/topic368691.html -
Don't forget change also this: Make the Windows 7 Taskbar Work More Like Windows XP or Vista
Report: Windows 7 to Launch on Oct. 23
By Soopafresh in forum ComputerReplies: 7Last Post: 2nd May 2009, 22:27 -
Quick Media Converter lifehacker.com most popular free windows app 2008 ?
By balou in forum Latest Video NewsReplies: 77Last Post: 17th Mar 2009, 02:09 -
DVD Architect Pro 5.0 - Problem with Menu launch
By stealers in forum Authoring (DVD)Replies: 0Last Post: 3rd Jan 2009, 10:36 -
using quick time video clips in windows movie maker
By benmar in forum Newbie / General discussionsReplies: 2Last Post: 7th Aug 2008, 10:43 -
SVCD2DVD won't launch after latest Windows Update of MS .net framework
By starkraving in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 23rd Jul 2007, 03:42
