Hey,
I would like to make dual audio movies from two separate avi files which contain the same video, but different audio tracks. I put the audio tracks in one file using AVI-Mux GUI but the secondary audio track is quite out of sync. I'm gonna need a software to fine-tune the generated dual avi file's A/V delay (without re-encoding anything, of course). A graphical tool (where I can slide the audio tracks below each other or the video track) would be more helpful.
Any ideas?
Zuja
Most media players can impart a + or - delay with keys (usually the +/- keys) , so play your avi and figure out the delay in ms when it syncs up
Then in avimux-gui, enter that delay value
This will only work if it's a constant delay issue (AV offset).
If there is a progressively worsening delay, the A/V lengths probably don't match or there are glitches somewhere in the A/V or it's a different cut. -
What do you mean "more efficient?" It takes a few seconds to do this, and maybe a minute to "fix" it in avimux guiOriginally Posted by zuja9
Unless you have a case of the other audio problems I mentioned...
You could use a NLE like vegas or premiere which shows it graphically on a timeline, but it will re-encode and you will lose quality
The fastest/easiest way with no quality lost is the method I described. -
Is this the way dual audio releasers do it (with movies available on e.g. torrent sites)?The fastest/easiest way with no quality lost is the method I described.
synchronizing video and audio in a remuxed MKS
By wsw70 in forum Video ConversionReplies: 0Last Post: 18th Jul 2011, 06:37 -
synchronizing an new audio stream on a video file
By gouletjo in forum Authoring (DVD)Replies: 5Last Post: 15th Feb 2010, 18:47 -
Synchronizing video and audio...? Best way?
By massimou in forum EditingReplies: 1Last Post: 4th Aug 2008, 12:43 -
Problem synchronizing audio and video
By weareone in forum Newbie / General discussionsReplies: 11Last Post: 20th Mar 2008, 18:20 -
Synchronizing audio/video with FFMPEG
By beyondthegrave in forum EditingReplies: 2Last Post: 13th Nov 2007, 08:32
