I have some questions about the following Hauppauge HD PVRs.
http://www.futureshop.ca/catalog/proddetail.asp?logon=&langid=EN&sku_id=0665000FS10081833&catid=
http://www.futureshop.ca/catalog/proddetail.asp?sku_id=0665000FS10107259&logon=&langid=EN
First question is: There is quite alot of highlighting that these cards record in .h264 and I would prefer the Mpeg2 format that I get with the Hauppauge 150 that I have on my current computer. So do you have a choice of which format to record in, as I don't have a HD Receiver and I am not interested in HD?
Second question: Since these transfer the captured video and audio via a usb cable is there an issue wth the audio and video being out of synch.
Third question: On my Hauppauge 150 Card it captures with componet and s-video. My satellite receiver has componet outputs and I know componet is much better than composite and s-video. Does this result in much clearer captured video and audio though. My family might be able to pick up one of these up for me in the city tommorow. The cheaper of the two, is it much good or it basically kind of crappy. If the cheaper one could perform adequately, I would much rather get it to save money. Thanks in advance for answers to these questions.
Results 1 to 17 of 17
Any reason why you posted a link the WinTV-HVR-950 "HVR USB Stick"?.
No dosen't support MPEG2 at allFirst question is: There is quite alot of highlighting that these cards record in .h264 and I would prefer the Mpeg2 format that I get with the Hauppauge 150 that I have on my current computer. So do you have a choice of which format to record in, as I don't have a HD Receiver and I am not interested in HD?
But you do have a choice of which audio format you like AAC or AC3
NoSecond question: Since these transfer the captured video and audio via a usb cable is there an issue wth the audio and video being out of synch.
Yes you should see a much clearer captured videoThird question: On my Hauppauge 150 Card it captures with componet and s-video. My satellite receiver has componet outputs and I know componet is much better than composite and s-video. Does this result in much clearer captured video and audio though. My family might be able to pick up one of these up for me in the city tommorow. The cheaper of the two, is it much good or it basically kind of crappy. If the cheaper one could perform adequately, I would much rather get it to save money. Thanks in advance for answers to these questions.
If like go to shspvr.com there a review of it and some clips
there min other site that did review have look at http://blog.arogan.com/2008/06/hauppauge-hd-pvr-model-1212.html
By the way the 150 dosen't have componet did you mean composite
What you mean by cheaper of the two? if ref to HVR 950 that is not Hardware encoder like HD-PVR. -
SHS: Thank you for the information you have provided. You are right my Hauppauge 150 has composite input, I wrote componet by mistake. To your knowledge is there a Hauppauge USB Product that lets one record in Mpeg 2 and has componet input for the sharper video?
I really am pleased with my Hauppauge 150 on my current computer. I was just thinking of the future, and I am having trouble finding someone localy that can build a custom made computer. So I was thinking USB would be handy if I had to buy a brand name computer and couldn't find someone to install a hauppauge card.
I record to mpeg2, edit with Womble Mpeg Video and then convert to .divx with a product from Tmpgenc. I would convert to .xvid but the resulting video is jumpy. For some reason by using the home theater profile in Tmpgenc my video stays stable; I have never figured it out. Someone at videohelp once speculated it could have something to do with the way Hauppauge records interlaced. Thank you advance for any further help you can be on this matter. Have a nice day! -
Far I know of nobody has a USB Product that has componet input and a Hardware MPEG2HD encoding for HD 1080i recording and the one that are out they costing an Arm & Leg and there not USB but there are number USB Product that do have componet input but they are mostlee AVI/DV format only so Hauppauge HD PVR is the only one out there that base on Hardware Encoder even knowing it can't do MPEG2HD.
There is a few 1x PCIe with componet input but there limited to 480i/p only, there the Compro VideoMate E800 which has hardware MPEG2 encoder and not to long ago newegg sold them so cheap it wasn't funny which gone for something like $10 if I recall rigth just to get rid of them and 2nd possable is Kworld PE360-A but as far I can tell it a non hardware encoder.
Your best beat is to stick with what you all ready have
Is there any reason why you can't install the card your self in new system?. -
SHS: Thank you for this additional information. I wouldn't want the mpeg2 to HD specs, just 720x480 like the Hauppauge 150. It would of been nice to see the difference between S-Video and Componet. I am pretty useless at putting parts into computers, so that is why I asked about the USB. I think I will do more searching in my local area for a technician who can install a card like the Hauppauge 150. Thank you once again.
Oh well in that case
If setup your sat box to output 480i or 480p on the componet output then it will rec 720x480 just like you want.
If you like I can rec two video from the same show using the two difference S-Video and Componet at same time so you can get an idea on the diff is how ever it have to be from the HVR 1600 as I no longer have a PVR 150. -
shs: I am quite curious as to the quality difference; but that seems like alot of work on your part and I don't want to put you through all that bother. My receiver is just a digital receiver it isn't a High Definition one. I record everything with the WinTV2000. Thank you for all the information you have given me. Have a nice evening!
Ok here you go
http://www.shspvr.com/ftp/download/moive_clip/hd_pvr/
TS file need be play in player that support H.264 video and AAC audio like PowerDVD.
Both where rec at same Maxrate VBR 4500kbps
Note the MPEG clip was done with WinTV HVR 1800 -
So as to not make a new thread, I'll post my HD-PVR question here. Hope its okay with the OP.
I'm using the Hauppauge HD-PVR.
I want to watch my TV and record at the same time. Is it possible to connect my STB to my TV with component cables and connect the STB to the PVR with S-Video or Composite. Basically, I want to connect my STB to both the TV and PVR simultaneously.
Is that possible? -
Yes you can do that with SVideo or Composite from your STB.
Or 2nd option STB component output cable going it to PVR component input then from HD-PVR used the component output back to TV. -
I see. But if the S-Video or Composite is going to the PVR, will I be able to capture HD?
This will also depend on your STB. It may not output component and svideo/composite at the same time.Originally Posted by Kite
Svideo/composite is standard definition only. If you want to capture HD you have to go component from the STB to the HD PVR then component from the HD PVR to the TV. Signal degredation is minimal.
Regarding the HD PVR and A/V sync errors: I don't see problems with that with the files directly from the HD PVR. But many editors have problems with the files and may give A/V sync errors after editing (eg, cutting out commercials, etc). -
SHS, what was the source of these? An HD tuner viewing an HD channel downscaled to SD? Or a native SD source?Originally Posted by SHS
Tom, note that most SD satellite broadcasts are at less than full D1 resolution, usually around 560x480i or 512x480i. I wouldn't expect to see much difference between an s-video and component capture with that. With downscaled HD you will see slightly better results (all else being equal -- which isn't the case when you're comparing the HD PVR to the PVR 150) with component.
Note the HD PVR's h.264 encoder will deliver better picture quality than the PVR-150's MPEG 2 encoder -- especially when bitrates are low.
Hauppauge HD PVR
By Susan_T in forum Newbie / General discussionsReplies: 1Last Post: 21st Nov 2011, 16:20 -
Questions on Hauppauge HD PVR recordings to DVD/Blu-Ray
By Quaker2001 in forum Capturing and VCRReplies: 2Last Post: 26th Jan 2010, 23:13 -
Hauppauge HD PVR USB questions
By SatStorm in forum Capturing and VCRReplies: 28Last Post: 16th Jun 2009, 13:01 -
Hauppauge HD PVR
By karebo in forum DVB / IPTVReplies: 13Last Post: 6th Jun 2009, 09:57 -
Hauppauge PVR-350 vs PVR-500MCE
By dphirschler in forum Capturing and VCRReplies: 1Last Post: 11th Mar 2008, 10:04
