Results 1 to 9 of 9
    Mar 2001
    Hell
    I know that there are programs like camtasia but i want something that saves it directly from the source, becuz some sites there is videos available that are made for great broadband connections and will give u better resolution on the movie clip. I have tried to right click and save but it doesnt work. i only get a small file which will give me directions to the source but it is in some strange format and will not let me connect to it.
    Please help me this is of great importance to me.
    Thanks.
  2. What type of streaming file are you talking about? WindowsMedia, Real, QT?
  3. Get Slack disturbed1's Avatar
    Apr 2001
    init 4
    There's a program called hyper cam that captures footage from an active window, with sound.
    You might have to do a google search.
  4. CAMTASIA - This s/w creates as an AVI file. It is really nice s/w.
    I know you are taking about saving ASF video.
    ASFRecorder can able to save ASF in harddisk.
    Mar 2001
    Hell
    Sorry people i was talking about realplayer video files
    and as i was saying i didn't want camtasia i would like to save the file as if it was a file and not streaming hmm.
    Becuz i need like 2mbit connection to get full quality and i know that they keep files in all kinds of connections
    56k 128isdn DSL etc.
  6. Get Slack disturbed1's Avatar
    Apr 2001
    init 4
    For the link that activates the stream you should be able to right click on it and choose save as.
    Once that file is on your drive, open it with notepad, and look for the web address.
    Then open a new text document and create a link to it
    for example
    click here
    save that as a html file, open with IE, right click, and save as.
    This only works against some real servers. If it's an http server you shouldn't have a problem
  7. Member spidey's Avatar
    Apr 2001
    U.S.A.
    Use Streambox VCR v 3.1 You can cap no matter what the speed it reassembles the stream for you. Search any xxx movie forum, and you'll easily find it.
  8. Get Slack disturbed1's Avatar
    Apr 2001
    init 4
    To help you out a little more, heres a Cradle of Filth video from metal blade.
    The link was ://...../cradle-of-hi.ram
    I save that .ram file to my HD.
    I opened it with notepad it said
    http://www.metalblade.com/real/realvideo/cradle-from-hi.rm
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    I change it to say
    click here
    Saved as whatever.html. Open with IE and right clicked, save as. I confirmed (watching the vid now) that it works.
    Mar 2001
    Hell
    i know http links work but most of the streaming videos i need are on this kinda links try to save this one to ya harddrivr rtsp://live1.sonera.se/ftp/tv4/tv4gbg0724volvo.rm
