So basically, whatever files I run with VirtualDub/Mod don't use ffdshow, or atleast the system tray icons don't appear, unless I use Avisynth. Is there any way I can load files with ffdshow into VirtualDub without using Avisynth?
Results 1 to 16 of 16
You can use the FFDShow VFW configuration to turn on the vfw features that virtualdub can use. I suspect that the ones you are seeing at the moment are DirectShow filters being called from avisynth.
Read my blog here.
Ah, I see. Then is there any way to get VirtualDub to use ffdshow audio (without Avisynth)?
Check the ffdshow configurations ("Video decoder configuration," "Audio decoder configuration" from ffdshow's Start Menu folder), under "DirectShow control" in both configuration windows. Does VirtualDub show up anywhere in the "Don't use ffdshow in:" boxes?
Of course, it's also possible that something may have given itself higher merit than ffdshow, so VirtualDub would use it before considering ffdshow... but I'd wonder about the above, first.If cameras add ten pounds, why would people want to eat them? -
Nope.Originally Posted by Ai Haibara
I don't think any audio decompressor loads, since there's no audio playback, and under file information I get the following:Originally Posted by Ai Haibara
vdub doesn't use ffdshow audio which is directshow based. You need acm type codecs for audio - and ffdshow doesn't have an acm type equivalent for audio (like it has vfw for video)
e.g. if you have ac3, install ac3acm. if you have mp3, install lame acm
if it's some other type of audio or you don't know, use mediainfo and post the information back here -
You're probably right AlanHK. I remember you had some issues with that on another threadOriginally Posted by AlanHK
But looking at his audio, it is unlikely to be mp3 since it's 6 channel -
Yes, learnt about that the hard way.Originally Posted by poisondeathray
Avisynth just decodes it (if it can), so you get an uncompressed audio stream.Originally Posted by Renegade
So if you open the AVS file with Vdub, you can save the audio as wave, or compress to whatever format you like.
So there wil be a conversion loss when you recompress, depending on what format you choose.
You can also get the Avisynth plugin Soundout, which will pop up an audio panel giving you convenient conversion options. -
As far as I understand, yes.Originally Posted by Renegade
There are many ways to encode, as it's a lossy process, but decoding should be deterministic and give the same result regardless.
Is this the correct way to install ffdshow just for VirtualDub?
By tigerb in forum Newbie / General discussionsReplies: 8Last Post: 25th Nov 2013, 02:23 -
VirtualDub + Quicktime Plugin - is FFDShow mandatory?
By oceanclub in forum Video ConversionReplies: 2Last Post: 10th Apr 2012, 19:30 -
ffdshow + MJPEG + VirtualDub = Blue Man Group!?
By VideoCynic in forum Video ConversionReplies: 2Last Post: 8th Jul 2011, 17:33 -
ffdshow codec in VirtualDub
By funky honky in forum EditingReplies: 2Last Post: 23rd Jun 2010, 12:53 -
Possible to get VirtualDub to open wmv/flv files without ffdshow?
By tigerb in forum Newbie / General discussionsReplies: 5Last Post: 20th Nov 2008, 21:09
