    Aug 2003
    Canada
    Each time im using MENcoder with directshow encoding i get the sound but no voice. we hear the music and backgrounds but no voice.
    But it works fine if i dont enable directshow or if i use
    what are the settings for directshow?
    Apr 2004
    Miskatonic U
    It depends what the source audio is, and therefore what DirectShow filter is being used to decode it. It sounds like you have multi-channel audio, but are using a DirectShow filter that is not configured to play all the channels. For example, if you have a 5.1 AC3 audio track, but your AC3 DirectShow filter is set up to only read the left and right channels, most of the dialogue will be gone. (This is an example. I am not saying you have AC3 audio).
    If it works without using the DirectShow filter, don't use it.
    Read my blog here.
