Does anyone have a playlist file that they've confirmed will work on the WD TV Live?
Questions:
PLS or M3U ?
Forward / or Back \ slashes for directories?
Version of Firmware?
thx
Results 121 to 150 of 182
"Quality is cool, but don't forget... Content is King!"
You forgot the number one change in 1.01.24:
* Removed ability to playback HD YouTube files
Also:
*Ignored all the main user requests for fixes -
Youtube doesn't allow non browser based players to play HD content - since the old firmware allowed that, they had to remove it or get sued. There are also certain labeling rules to follow if you wish to playback Youtube so they had to do that first.
Not true.
They have said they will, to me that has more validity that you being negative. -
Link?
<edit>
Found one:
http://community.wdc.com/t5/WD-TV-Live-Ideas/idb-p/idea/status-key/pending
Not a lot there though.
</edit>Last edited by jagabo; 21st Feb 2010 at 20:55.
An "issue" is a legitimate bug (at its not a bug when people can't figure out how to configure their network - its a network streamer) not that people want a lot of functions which were never promised. And those 'pending' are suggestions they have have now suggested they will implement.
As for promising to fix bugs of course they do, have posted it several times - and no, i'm not going to look for links. -
1.02.14 - I'd wait a bit, though.
http://www.avsforum.com/avs-vb/showthread.php?p=18190900#post18190900"Quality is cool, but don't forget... Content is King!" -
Or you could link to the official prerelease page http://www.wdc.com/wdtvlive_prerelease/
Here's a tip for those who want nice thumbnails for their movies that approximate the original DVD or Blu-Ray box:
(1) Go to AMAZON.COM and look up the title (including the term DVD or Blu-Ray as needed -- for example "Wargames DVD"). What's nice about using Amazon is that it will bring up pretty much every major release of a given movie -- including discontinued ones, because it will also show used DVDs for sale -- this is great for DVD's you bought 10+ years ago, to get the matching box art.
(2) When it brings up the box art, you can usually click on it to get a larger view - do so (9 times out of 10, it is a truly larger view, not just a zoom).
(3) Use the "Snipping Tool" (available in both Windows 7 and Vista) to grab the image of the box, being careful NOT to include any white space. Note: you cannot just download the image of the box from Amazon's site as it typically is a SQUARE with a lot of white space on each side of the box itself. To make this quicker, in Windows 7, I put the shortcut to the Snipping Tool as the first item on my taskbar, so pressing Win+1 brings it up. There's no need to be too exact with your selection, I usually end up a pixel inside each side to be on the safe side.
(4) I be sure to name the resulting JPG file the same thing as any given .ISO or .m2ts and place it in the same directory as the movie.
With the above, I haven't bothered to worry about overall pixel sizes or exacting ratios -- the WDTV Live handles them all just fine. You do not need to resize anything yourself! Each JPG ends up roughly 75k in size, so it's not a big deal.
Now, on a LOCAL drive, the movie will now have the JPG image show up in place of the default icon. On a NETWORK SHARE, the JPG will show up first by itself and then, when you scroll down to the .ISO's, those same JPG's will be used as the icons for the movie. Just set your WDTV Live to show file EXTENSIONS and or SIZES to be sure you are getting the proper file. -
Found this in another forum:
Wanna remove those sometimes annoying white bars around the pictures you use from the various Amazon sites then heres what to do....
Here we have an url with the bars:Then all you have to do is just remove the SS500_ from the url and you're done.Code:http://images.amazon.com/images/P/B000FJH5M2.01._SS500_SCLZZZZZZZ_V50666971_.jpg
After:With Bars:Code:http://images.amazon.com/images/P/B000FJH5M2.01._SCLZZZZZZZ_V50666971_.jpg
Without Bars:
[QUOTE=branch;1962269][QUOTE=RdM642;1962175] I am not being negative. It is a fact that the last three updates added essentially nothing.
1) The third to last bricked units.
2) The second to last did nothing except fix the bricking issue
3) the last one removed Youtube HD capability.
Stop throwing terms around like "being negative" when what I posted is a fact.
Fact: The main affect, and the one everyone noticed of the last firmware was the removal of a feature. The last three firmwares have had a little net effect but to remove function.
I own several brands of streamers and WD is clearly not up to par with attention to firmware update (either from the standpoint of testing firmware before release or addressing issues) and is either understaffed or underfunded when it comes to firmware update.
On their own site they have a listing of top fixes and firmware requests. they hve to do with things like menu and chapter support (which the competition has), shortcuts in navigation, less problems with networking, etc. These have not been addressed in firmware.
Don't call people "negative" for pointing out competitive disadvantages and the obvious screw ups with firmware.Last edited by RdM642; 28th Feb 2010 at 10:22.
That isn't the case at all. A bug is a bug. An "issue" includes competitive disadvantages, missing commonly used features in other devices etc.
There are WD acknowledged bugs with networking, and there are a quite a few "issues." Pleas look at our own tools lists etc. on videohelp, very commonly listed are competative disadvantes betwen competing products (software and hardware). When someone cites a feature common in the competition, but missing in a device or piece of software in the same exact market segment, the citation is quite legitimate. -
Then you need to rephrase how you put things. I point WD has said on forums they are working on bug fixes, and you simply dismiss that because you don't want to believe it.
Lets just get one thing straight, its not relevant what previous updates fixed. The point is you just dismiss that they are going to fix bugs, thats being negative.Originally Posted by RdM642
On some devices, by no means all. But because of this everything else was put on hold and delayed, they needed to fix this first.Originally Posted by RdM642
I would not call it nothing that they prevent our devices from bricking.Originally Posted by RdM642
As has been said they have to do this, contractual obligation to Google - the only other choice would be to remove Youtube entirely.Originally Posted by RdM642
You didn't post a fact, you posted an emotional statement, you said " There is no evidence they are going to be addressing any of the main issues people are having. " something which seems to be in contradiction with truth, when their product manager has posted they are now going prioritize bug fixing now that the patcher should be solid, and they fixed the youtube situation (before getting a lawsuit probably)Originally Posted by RdM642
Especially since the firmware in prerelease now has a lot of fixes.
Given that there was suddenly action from January 1, I'm assuming that there has been an internal reshuffle, and new people where hired from the start of this year - I have absolutely no proof of that though - just a feeling.Originally Posted by RdM642
Don't try and twist what you say in order to prove a point which was never there.Originally Posted by RdM642
Exactly - I was trying to tell you (and everybody else) that they have promised to fix bugs, and will presumably fix bugs. But when/if they don't add a DVD menu and people start yelling then those people need to understand they have never been promised such a thing. The Live does what it says on the box. Anything extra which might show up is a bonus. That the device is missing things you think it should have isn't an "issue" - thats just you wanting more, which you may or may not get.
And if people start moaning about "other thing is better" - well then buy that then.
Really? They did? Amazing, most of what i've seen have been people doing things wrong. But good for them.Last edited by branch; 28th Feb 2010 at 18:01. Reason: fixed board bugs
Branchl,
You response is emotional and a bit shrill. I don't see a single fact in it at all. I posted facts. I posted consensus from WD own users.
You are responding with a strange impressionistic and emotional response. It makes no sense.
It is a fact that the least three updates did nothing but brick units and remove touted capabilities.
As far as doubt on WD commitment to firmware, there are other users here saying the same thing and WD own forums are full of people amazed at what a botch WD has made of it. That isn't "negative" -- it is a reporting of the facts.
You said this and user jagabo responded
That is an rational response. Sure.
Why you have to be so negative is beyond me. -
Here's a better list of what's in the upcoming release:
http://wdtvforum.com/main/index.php?topic=4951.msg36720#msg36720 -
Before people start asking if this adds a washing machine simulation and high score, here is their list of things done:
· Added Windows 7 Support.
· Added larger subtitle font size options.
· Added European language input for keyboard.
· Added serial and part number to About page.
· Added support for embedded subtitles in mpg files.
· Added new category in Photo/Video to view by date.
· Added a field in network settings for changing the workgroup name.
· Added ability to play a video from the preview window without restarting.
· Added username/password feature for SAMBA security.
· Added Wireless LAN strength bar in Network info page.
· Changed default browsing by date to start with the latest files first.
· Changed video browse default to "Preview Mode" instead of thumbnail mode.
· Corrected several language translations issues.
· Resolved issues with subtitle sync adjustment.
· Resolved abnormal display of BMP photos through a media server.
· Resolved Audio channel information shows up in AutoPlay mode.
· Resolved Blu-ray ISO subtitle not displaying throughout VIDEO playback.
· Resolved Blu-ray slow playback across SAMBA.
· Resolved camera files not enumerating correctly in mass storage.
· Resolved login issue with SAMBA after exiting screen saver.
· Resolved DVR-MS black screen problem on resume after forward and rewind.
· Resolved external sub/idx subtitles flashbacking issue.
· Resolved playback across media server failures.
· Resolved hard drive icon from disappearing in the video list under preview mode.
· Resolved issue of HDMI becoming jittery after long time play.
· Resolved M4V files not supporting fast forward and rewind.
· Resolved manual network addressing issue.
· Resolved missing shuffle & repeat icon for slideshow within Flickr.
· Resolved music search not displaying playlist names.
· Resolved network devices (SAMBA) disappearing without warning.
· Resolved PTP issue of unsupported video file formats DX6490,DIMAGE Z2 & X1, Optio
555 and DMC-FX2.
· Resolved Sony Walkman not showing photos within directory.
· Resolved unsupported file formats not showing an error message.
· Resolved video playback overscan issue for CRT TVs.
· Resolved WIFI Belkin F6D4050 with RAlink 3070 chip and Linksys WUSUB100 Ver 2.
· Resolved WIFI ZyXel NWD-270N dongle not enumerating.'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie -
Ron, that is the update that ruins mkv playback, right?
Confirmed, it is the one that makes you wait 10 minutes for an mkv to start. -
That is ridiculous. Wait 20minutes to stream a two-hour film? My LG BD390 player, which plays mkv and doubles as network streamer plays everything instantly. Why would a media center, which main objective is to stream files, be different?
Something seems to be wrong in that firmware if that is so. -
But speaking of buggy firmware, there is a new beta prerelease for those interested.
Version 1.02.19: http://www.wdc.com/wdtvlive_prerelease/
I wonder if Lenovo Multimedia Remote w/ Keyboard will work with WD player
http://shop.lenovo.com/SEUILibrary/controller/e/web/LenovoPortal/en_US/integration.wor...id=pg_57Y6336&
WDTV Live Plus or PS3?
By tj1182 in forum Newbie / General discussionsReplies: 12Last Post: 31st Jul 2010, 22:31 -
A few questions about the WDTV Live...
By DVinci in forum Media Center PC / MediaCentersReplies: 3Last Post: 15th Feb 2010, 07:28 -
DTS on WDTV LIVE?
By bagmand22 in forum Media Center PC / MediaCentersReplies: 3Last Post: 28th Jan 2010, 11:09 -
Help with few WDTV Live questions
By tigerb in forum Newbie / General discussionsReplies: 5Last Post: 6th Jan 2010, 06:34 -
WDTV Live - 5.1 Audio
By yamatosoul in forum Media Center PC / MediaCentersReplies: 1Last Post: 25th Nov 2009, 17:35
