been using convertx for about a year now all great but the last week
every time i use it my pc crashes old and new versions works fine till u get
to 25%-45% then pc locks up and u cant even reboot it u got to
switch of at the mains and start again any help would b grateful
starting to tear lumps out of my hair lol![]()
regards derek
Why don't you join and post on the VSO forum? Lots of useful information there. It's in English as well as French
http://forums.vso-software.fr/SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
It might be an overheat problem. Do other encoders cause a similar problem? If you can monitor CPU temps, check them during the ConvertX encoding.
It could also be failing RAM or something else within the computer. But if other similar encoders work without problems, then I would uninstall and reinstall ConvertX and see if that helps. I would also check to see what software was installed right before the problems started, though failing at 25% - 45% sounds more like an overheat problem.
VSO ConvertXtoDVD is turning 155 mins into 95
By Calavera33 in forum Video ConversionReplies: 7Last Post: 25th Apr 2011, 11:32 -
VSO Blu-ray to DVD
By Bonie81 in forum Newbie / General discussionsReplies: 0Last Post: 20th Jan 2011, 12:40 -
Slower encoding with VSO than it used to be
By Brainstorming in forum Video ConversionReplies: 8Last Post: 28th Dec 2010, 20:52 -
PowerISO and ConvertX
By Aristocles in forum Newbie / General discussionsReplies: 1Last Post: 28th Oct 2009, 22:45 -
convertx to dvd
By thecrock in forum Newbie / General discussionsReplies: 1Last Post: 26th Feb 2008, 13:54
