I want to buy some UK dvd's and I have a Toshiba SD-3960SU from 2004 to play them on which is attached to my TV. Do I need a different player and, if so, want do I look for?
Results 1 to 12 of 12
Your Toshiba won't work, buy an OPPO:
www.oppodigital.com
Or one of these:
http://www.bhphotovideo.com/c/buy/Multisystem-DVD-Players-Recorders/ci/2159/N/4294543255 -
Two problems: The UK videos would be in PAL format and in the US, NTSC is used. And the region coding on the DVDs would be wrong, assuming they have region codings. Most all commercial DVDs do.
You can rip the DVDs on a computer with a program like DVDShrink and eliminate the region coding, but you would still need a player (And a TV or display device) that can play back PAL video.
Some DVD players available in the US can play back PAL videos and some also have 'hacks' to disable region coding.
And welcome to our forums.
To add to that if your computer is already hooked up to your tv as a htpc (home theater pc) you are set to go once its on your computer. Though of course an uncompressed dvd will take anywhere from 4 to 8gb's per movie.Originally Posted by redwudzDonatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
Philips DVP 5990 and 5992 are easily made region free and convert PAL to NTSC.
i love this subject, and that we had many videohelp posters bemoaning the fact that they could not get a dvd recorder with a HD and here they are !
PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS -
Err..the op was asking about playing pal on dvd players,not sure how your comment is relevant here.Originally Posted by victoriabearsI think,therefore i am a hamster.
I think victoriabears was referring to the link in my first post, still irrelevant to the topic though.
I use a phillips player i really recommend it, it plays both PAL/NTSC on an NTSC only TV, has HDMI out and plays DIVX/XVID files as well. And its only like 60$
It also plays from all regions (if you change the default, which is set to 1 (US))
Phillips DVP5960 -
Thanks All. Ended up buying a Sony for $70US and it works marvelously. Thanks for your help.
how do I know if an avi can be played on a dvd
By flannob in forum Newbie / General discussionsReplies: 4Last Post: 9th Aug 2010, 13:33 -
SD DVD Played on Blueray Player
By wulf109 in forum DVD & Blu-ray PlayersReplies: 5Last Post: 17th Aug 2009, 09:36 -
no audio when played in DVD player? help
By cpeters12 in forum Authoring (DVD)Replies: 2Last Post: 29th Jul 2009, 17:01 -
burned DVD can't be played
By linda.0p in forum DVD RippingReplies: 2Last Post: 19th Sep 2008, 14:18 -
Dvd jumps when played
By Radox The Green in forum Newbie / General discussionsReplies: 1Last Post: 16th Dec 2007, 14:56
