i want to change a 700 megabyte .avi file with tmpgenc,
how do i do that without excending a 750 megabyte limite????
I assume you are making a VCD. Well, if so, not sure what you mean by 750mb limit. Depending on the size of the CD you plan on burning the MPG to the file size will be limited to either 740mb or 800mb. When using VCD MPEG1 standards each minute of video/audio will equal 10mb. Therefore, depending on the size of your CD, you will either be able to fit 74 or 80 mins on one CD. You can always go lower then MPEG1 standard bitarte of 1150bps but this will reduce the quality and make it incompatible with many DVD players which is one of the primary benefits of using VCD over AVI.
Good luck and let us know if you need any more help -
Originally Posted by smokin*1
HTH"The future is no longer what it used to be"
Change default audio in .VOB or .MPG files
By dsmith1984uk in forum AudioReplies: 1Last Post: 4th May 2010, 04:10 -
avi vid too big?
By miilk in forum Newbie / General discussionsReplies: 5Last Post: 7th Oct 2009, 19:42 -
avs (avi to avi) ends up out of sync ... winavi output file too big
By mandy in forum Video ConversionReplies: 1Last Post: 21st Aug 2009, 05:56 -
I can't play a big avi file
By Xp4nd3r in forum Newbie / General discussionsReplies: 6Last Post: 20th Feb 2009, 06:29 -
AVI black borders are too big
By sensini in forum EditingReplies: 13Last Post: 20th Jan 2008, 23:02
