Hi people, here are a couple of questions.
1) i downloaded the sample vcd off this site and burned it onto cheap cd. comp usa no name brand using my hp cd burner.
it coms out a little blocky on some parts. any suggestions on what is worng?
2) i used nero's vcd maker to burn an avi to vcd format. the nero instructions said it could do the conversion form avi to vcd compliant. burned it and stand alone dvd player won't read it. any suggestions?
also, my dvd player is apex 500w or 500a. i forget which.
thanks in advance.
Well abou tthe blockiness, i tall depends on how the MPG file is codec, does'nt have very miuch t odo with the burning although im sure a dirty CD or something will not exactly improve the quality. I hav enoticed that when I have re-used my CD-RWs about 50 times they start so act weird.
Why it won't play in your DVS is hard to answer, the times I let Nero convert my Avis to VCD it sucked bigtime so I never use that, stick with TMPGenc. I guess you shoudl check the DVD player compability list to see about media and stuff...
Thanx/
Lars -
md dvd player is compatible. apex all the way baby.
it plays the example one on this site so no problem there. guess i'll try tempgen now to convert and hten burn. i'll see what happens. -
I have enoticed that when I have re-used my CD-RWs about 50 times they start so act weird.
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
I haven't noticed this and I certainly have CD-RW's that I've used more than 50 times. Exactly what's it doing? The only thing I've ever noticed about CD-RW is that on it's first burn it sometimes works in things that normally don't like CD-RW, but nothing else.
No sound when playing playing burned DVD on stand alone player
By ibzomie in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2010, 14:11 -
.SRT Font Size When Playing Using Flashdisk On Stand-alone DVD Player
By randy3101 in forum SubtitleReplies: 5Last Post: 9th Apr 2010, 01:48 -
First Stand Alone RM/RMVB DVD Player
By sushix in forum DVD & Blu-ray PlayersReplies: 13Last Post: 7th Jun 2009, 02:42 -
What stand alone dvd burner is used here by most of you
By 2boot in forum RestorationReplies: 17Last Post: 27th Feb 2008, 21:31 -
Trouble playing burned DVDs on my stand alone
By collin_stevens in forum MacReplies: 2Last Post: 12th Oct 2007, 17:51
