Ive been recently recording some Japanese (NTSC) videos from my VHS player, through a Digital video stabilizer and into a standalone DVD recorder. Im in Australia, so my recorder will be PAL, but it supports NTSC, as i can watch and record NTSC signals/DVDs.
Anwyays, When i record the VHS video onto the DVD recorders HDD or onto DVD. It plays fine on the original standalone DVD player, BUT when i play it on the computer, or rip it into VOB using DVD decrypter, there is severe deinterlacing going on. its really jaggy with all those missing horizontal lines showing, especially during high motion scenes.
Why is this? its fine when watching the original NTSC VHS tape, and even when i watch the recorded footage on the DVD recorder. But on the PC, its all deinterlaced and bad.
Is there a way to fix this, is it the VHS player's fault? or the DVD recorders? i make sure the setting on my DVD recorder (pioneer DVR-530H) is set to NTSC mode.
any help would be awesome, thanks![]()
Results 1 to 11 of 11
I think your interpretation is backwards. The DVD recorder or TV is deinterlacing so you see no comb artifacts, whereas the computer isn't so you see comb artifacts. Try using a player that deinterlaces on the fly.
Post a short sample where the problems are obvious. -
Post short part.
Later edit:
Try other player: Media Player Classic Home Cinema. -
ok here we go guys
so when i watch the original VHS, its normal, no issues, but when i record the VHS into DVD using my standalone DVD recorder, the resulting captured DVD plays fine on the standalone recorder, no visible issues, BUT this is it on my PC. The deinterlacing is bad mainly in areas of high movement, (because they are music videos, its frequent).
here are some screenshots.
http://img114.imageshack.us/i/vlcsnap2009101201h14m15.png/
http://img39.imageshack.us/i/vlcsnap2009101201h16m06.png/
http://img39.imageshack.us/i/vlcsnap2009101201h18m22.png/
edit: ok so this ^ is without any interlacing filters on in VLC media player, if i play it in a higher end player like WINDVD then the deinterlacing isnt noticable much, but what i want is the original DVD / VHS footage im playing to be recorded by the DVD recorder without any of this deinterlacing happening. im not so worried about the playback, moreso i just want the best quality recording of the tapes without this deinterlacing happening. Anyone know how to fix it? I dont know whether its the settings of the DVD recorder, or if its the VHS player, or whether its what happens when you record NTSC with PAL player, using PAL60. (my player supports NTSC though i think). Maybe this wouldnt happen if i used a NTSC DVD recorder?
thanks guys
I was hoping you would post a short video sample, But, yes, it appears the problem you are having is that the computer is not deinterlacing. So you see both fields at the same time, rather than one field at a time. Use a player that deinterlaces on the fly, like VLC. Enable its deinterlacing with Video -> Deinterlace -> Bob, or any of the other deinterlacing algorithms.
Vlc player don`t do deinterlace by default. Set one method from Video>>Deinterlace or try Media Player Classic Home Cinema.
Second time jagabo is fastest.
Pal60, vcr or recorder has nothig to do with your false problem. -
VHS is an inherently interlaced system. So you can't have the DVD recorder record progressively unless it has such a feature. But I've never heard of a DVD recorder that can inverse telecine or deinterlace before recording.Originally Posted by ramrod1234
ahhh k, seems everything recorded by the player is interlaced the same. PAL or NTSC. So i dont think there is anything i can do. Would the same thing happen with every DVD recorder? Anything coming from a analogue / vhs/ video 8 tape will have this happen right?Originally Posted by jagabo
The DVD recorder is doing exactly what it should do. It is not a fault. Deinterlacing the footage to put it on DVD would lower the quality and throw half the spatial resolution away.
You just need to use appropriate playback software on your PC.
Most PC DVD playback software deinterlaces automatically by default. No idea why yours doesn't.
Cheers,
David. -
Ahhhh, thanks for that
that explains why it doesnt do it on VLC media player but will on DVD player!
Deinterlacing a PAL DVD sourced from NTSC properly
By Mephesto in forum DVD RippingReplies: 15Last Post: 7th Feb 2012, 13:16 -
Getting film look on BFF PAL DV video without deinterlacing?
By arminio in forum RestorationReplies: 0Last Post: 17th Sep 2010, 04:21 -
playing PAL Hi8 tapes in NTSC camcorder output to PAL DVD recorder?
By interlooper in forum Capturing and VCRReplies: 2Last Post: 17th Jan 2009, 15:36 -
PAL Video Cassette Recorder or [Multisystem VCR] for PAL->NTSC playback
By quantass in forum Newbie / General discussionsReplies: 10Last Post: 12th Dec 2008, 14:47 -
Recording a NTSC VHS Tape with a PAL DVD Recorder??
By Lanno in forum DVD & Blu-ray RecordersReplies: 10Last Post: 5th Sep 2007, 04:42
