  1. I need to resize some AVI file I have to:-
    AVI, 224 x 176, 20.00 fps, video: uncompressed DivX 5, audio: MPEG-1 Layer 3 (stereo, 44100 Hz)
    Could anyone recommed something?
    Apr 2004
    Miskatonic U
    First you have to work out if you want them uncompressed, or divx - you can't both. Divx is a compressed encoding method.
    Is this for a phone ?
    Read my blog here.
  3. Ahh, it's for a Sansa Fuze
  4. Member usta's Avatar
    Jun 2009
    Netherlands
    Any Video Converter Free. Plug those settings and click convert.
  5. Tried using avc based on these setting and it still reported unsupported
    General #0
    Complete name : WAZ.MineToRemember.SansaP layer.avi
    Format : AVI
    Format/Family : RIFF
    File size : 20.0 MiB
    PlayTime : 3mn 26s
    Bit rate : 812 Kbps
    Writing application : InterVideo
    Video #0
    Codec : DivX 5
    Codec/Family : MPEG-4
    Codec profile : Unknown
    Codec settings/Packe : No
    Codec settings/BVOP : Yes
    Codec settings/QPel : No
    Codec settings/GMC : 0
    Codec settings/Matri : Default
    PlayTime : 3mn 26s
    Bit rate : 667 Kbps
    Width : 224 pixels
    Height : 176 pixels
    Display Aspect ratio : 1.273
    Frame rate : 20.000 fps
    Resolution : 8 bits
    Interlacement : Progressive
    Audio #0
    Codec : MPEG-1 Audio layer 3
    PlayTime : 3mn 26s
    Bit rate : 128 Kbps
    Bit rate mode : CBR
    Channel(s) : 2 channels
    Sampling rate : 44.1 KHz
    Resolution : 16 bits
    Writing library : Xing (new)
  6. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    If possible, post the MediaInfo (tree view) information from a video that does work on the Fuze.
    I'm wondering (can't tell from here, of course ) whether or not it would be having a problem with the BVOPs or bitrates.
  7. It might not like multiple BVOP. Find a file that does play and GSpot will tell you whether it has B frames and how many.
    Found this:
    http://forums.sandisk.com/sansa/board/message?board.id=sansafuse&view=by_date_ascendin...d=31558#M31558
    It sounds like AVI-Mux GUI may be able to make your video work.
