Just a quick question guys, im thinking of buying JVC HR-DVS1 SVHS player, im wondering, are all SVHS players these days able to play PAL and NTSC tapes, im needing to record them and need to make sure it will play both, I believe the player is European/Australian.
thanks guys.![]()
Pal models can play NTSC tape but the output is not true NTSC or true Pal signal. Is a mixt between both, so-called Pal60. This keep timing from NTSC (29.97FPS) and colour encoding from Pal. So, for capture this type of signal you need a device that know Pal60. As a general rule capture card with Philips cipset can capture Pal60. I recommend Saa713x (x=0 to 5) and DScaler.
is PAL60 close to the original raw NTSC footage? because im currently using a DVD-recorder to record the VHS videos. I've done it before, on my older VHS player and my current dvd recorder is compaitble with both ntsc and pal. Thanks, im pretty sure the SVHS player is PAL and NTSC compatible.
ahhh ok! well, my recorder does capture the NTSC video, and it works fine, except there is bad deinterlacing happening when i transfer the recorded video to DVD and play it on PC. see https://forum.videohelp.com/topic374180.html
But the standalone recorder does capture the NTSC video at proper speed and picture, just deinterlacing issues :\. So i think that means it records Pal60? -
ok i just checked my recorder, it can play 525 or 625 systems, so PAL60/NTSC and PAL/SECAM.
all sorted, thanks
PAL video on NTSC HD TV Best motion Playback
By Deter in forum RestorationReplies: 7Last Post: 25th Aug 2011, 06:34 -
NTSC -> PAL on NTSC Playback VCR
By Cyberrock in forum Capturing and VCRReplies: 21Last Post: 28th Sep 2010, 04:52 -
JVC VCR both NTSC and PAL?
By Moby2 in forum Newbie / General discussionsReplies: 4Last Post: 21st Dec 2008, 04:26 -
PAL Video Cassette Recorder or [Multisystem VCR] for PAL->NTSC playback
By quantass in forum Newbie / General discussionsReplies: 10Last Post: 12th Dec 2008, 14:47 -
Help me undestand - Same Videos, one PAL one NTSC, same length?
By Killer3737 in forum Video ConversionReplies: 22Last Post: 31st Jul 2008, 18:18
