Hi,
I want to author 25 titles DVD with ConvertXtoDVD. My question is how to make title as a chapter? "Add Chapter" section adds chapters for title only. Thanks for help.
Results 1 to 9 of 9
Don't add each one from the main page. Add your first one, highlight it-> CTRL A (or right click-> 'Merge more files..."). A new window will pop up. Add the rest of your files there. When you are done on the main page look at "Chapter', they should all be listed there as separate chapters.
Now I have one problem here. "Merge more files..." feature can't load files with diffrent audio tracks. If the first one is AC3 5.1 channel track, second 2.0 lpcm track can't be added. Is there a possibility to do something? Or someone knows how to do this? NeroVision can do this very well.
Just tell me how to make jump to next title without going back to title menu. I mean using remote control "next track" button? Possible in ConvertXtoDVD? Or someone can recommend DVD authoring software with audio level normalization and merge/join feature from diffrent VOB's? That's all i need. Otherwise I'm using NeroVision 4 to make DVD's. But Nero can't normalize audio level
So, I bought ConvertXtoDVD. But...
P.S. I want to ask one more question. How to gain audio level in VOB or MPEG-2 files without demux? I'm searching software like MP3gain for MP3 files volume level normalization. I would be thankful for any help -
Originally Posted by guns1inger
Originally Posted by KTV86
Add your file-> Edit, then double click on the blue Video Track. The volume adjuster should pop up. You can adjust by ear or to make things more uniform get this free little app and run it concurrently.
http://www.darkwood.demon.co.uk/PC/meter.html
With CX2D play around with the Menu options.
Question about ConvertXtoDVD
By ccm2 in forum Newbie / General discussionsReplies: 3Last Post: 8th Aug 2008, 03:06 -
Convertxtodvd Question
By OhSnap in forum Newbie / General discussionsReplies: 4Last Post: 1st Jun 2008, 20:59 -
ConvertXToDVD 3 Question
By Maikeru-sama in forum Authoring (DVD)Replies: 12Last Post: 29th Apr 2008, 11:48 -
Question about new ConvertXtoDVD v3.00... overscan?
By andre477 in forum Newbie / General discussionsReplies: 7Last Post: 9th Mar 2008, 13:44 -
ConvertXtoDVD question
By kostnkost in forum Video ConversionReplies: 13Last Post: 30th Dec 2007, 10:26
