  1. Member DVDONE's Avatar
    Jan 2005
    I am editing a video and I imported video clips into Adobe Prmiere CS4 and the taskbar is cluttered with them. How can I fix them?
  2. You're probably using format that are not natively supported by Premiere, so it is resorting to directshow decoding, or avisynth import plugin and directshow to import
    You can disable the icons in the ffdshow configuration. You will probably have to restart premiere for this to take effect
  3. Member DVDONE's Avatar
    Jan 2005
    Ok, I am going to do it as soon as I finish what I am doing.
    That was a really fast reply. Thanks.
  4. Banned
    Aug 2002
    beautiful
    I don't understand wat do you want to "fix"? Remove the clutter of ffdshow icons? Well, each video you opened was opened with ffdshow video and audio codec. Either you use different codecs for them, or in ffdshow's codec options select "none" to show tray icon and you won't see any of them (if that's what you were asking about)
    /edit
    wow, i type to slow LOL
  5. ffdshow settings - tray - no icons
  6. Member DVDONE's Avatar
    Jan 2005
    Fixed. Thank you.
