I have this simple but useful grade calculator program
http://rapidshare.com/files/291006462/GRADE.EXE.html
that doesn't have a unique icon associated with it (see screenshot).
My question is, how can I modify the software so that there is a permanent icon (almost any icon will do).
The present default icon makes it look like a virus.
As a one-off on your desktop, right-click and select Properties, then click on Change Icon and browse for a new one. Icons can be stored in an .ico file, or in a .dll or an .exe file.
If you want a permanent change then you need to do this before you compile the program. Your development environment should allow you to assign (and hopefully embed) an icon so it goes with the program.Read my blog here.
I want to permanently (embed) a different icon. I didn't make the software. All I have is the EXE. Could you look at the software EXE (see above link) and tell me if this can be done easily? The terms compile the program and development environment are beyond me at this time. However, if this software icon can easily be changed, I think I could learn a lot by learning how to do it.If you want a permanent change then you need to do this before you compile the program. Your development environment should allow you to assign (and hopefully embed) an icon so it goes with the program.
google RESOURCE EDITOR (though it looks like a command-line program; adding icons may not work)
Trevor
Change MKV icon
By xxxThiefxxx in forum Video ConversionReplies: 1Last Post: 31st Mar 2012, 20:01 -
Change Icon In System Tray?
By DarrellS in forum ComputerReplies: 7Last Post: 8th Feb 2011, 23:36 -
Is it possible to change the icon for scanners and cameras in my computer?
By Denvers Dawgs in forum ComputerReplies: 2Last Post: 8th Nov 2010, 08:13 -
Icon change: Divx -> QT ?
By rotuts in forum MacReplies: 5Last Post: 20th Jul 2008, 15:52 -
CCE, OGM and Icon in Systems Tray Question
By Maikeru-sama in forum Newbie / General discussionsReplies: 6Last Post: 6th Jun 2008, 13:01
